Popular Post general melchett Posted November 5, 2015 Popular Post Share Posted November 5, 2015 (edited) Hi all, sorry it's quite a long one !....As some of you may know we happy chappies of the Bomber Command sig are commemorating one of the RAF's most iconic aircraft in the form of the magnificent Short Stirling heavy bomber at this years SMW show. The plan is to get as many built for display as possible in the time and we will be displaying them alongside sections of John Lathwell's (12jaguar) fantastic forward fuselage restoration project at the show. Please pop along to the table for a chin wag about just about anything, we have Rob on guitar, Neil on drums, a couple of guys on bass, (pint thereof) and me on valium ! Also talk to John and the lads about the wonderful Stirling Aircraft Projects plans for the future. My contribution is Stirling B.Mk1 R9368 BU-A of 214 squadron flown from RAF Chedburgh 1943. Her final moments are recorded below...... ''9th March 1943 After a couple of aircraft had left with no problems, a new pilot on a night nav exercise swung on take off, collapsed the undercarriage of his Stirling and blocked the main runway. It was decided to use the shorter runway and the crew prepared to leave, not happy as they had had their own U/C problems whilst on air test. The fully laden Stirling lumbered into the air but with the U/C only partially retracted, clipped some trees, took the roof off a newly built house and finally ploughed in near Chevington about a mile away. Miraculously the bomb load did not explode and the crew scrambled out of the burning aircraft. A head count revealed one missing, air gunner John Flack and, without hesitation the crew went back into the aircraft to find him trapped and upside down in his straps. They got him out suffering severe burns in the process later to be awarded the GM for their gallantry''....such were the calibre of the men who flew these great aircraft ! I decided to use Italeri's new 'monster', and I don't mean that flatteringly. This model is a bit of a curates egg in that whilst it has nicely moulded parts several details are missing, this tends to happen when you attempt to make multiple types from a mould and the build sequence is not the easiest I've come across, particularly for a new kit that costs around 40 quid ! The panel trenches and golf ball sized rivets have been mentioned many times so I won't go over that but there are problems with the fuselage cross section and wing dihedral in that the shoulder that runs the length of the fuselage top is too square and needs sanding back to give a gentler shape, this is quite subtle but alters the look dramatically and the wings are basically just too level and need canting up a few degrees at the root. The ailerons don't have the marked outward curve at the outer tips that they should, (good grief even Airfix got that right !) so I shaved some off and added resin to make good. Other problems include having to cut out the window reveals yourself, (the windows are oversize but I'll live with that), having the undercarriage assembled and fitted before gluing the wings together, engine front cowls that are all but impossible to fit after the nacelles are fitted to the fuselage, over flattened tyres and bits missing such as infills for the under engine nacelles where the later marks oil cooler assembly fitted. Having said all that the detail is very good, the engines are nicely done and you do get a lot of plastic for your money......just not necessarily what you might expect. Anyway before your eyes glaze over here's a list of the things I did to mine, Sanded down all surfaces to lessen the effect of the trenches and removed a lot of rivets, (left some to add interest) Re-profiled the fuselage topside section Fettled the outer tips of the ailerons to produce pronounced curve Increased the dihedral of the wings by 2 degrees Lowered the height of the canopy by 2mm Thinned all trailing edges Sanded heavy aileron and elevator rib detail back Added Resin-Art main and tail wheels Added lead wiring as hydraulic brake lines on main gear legs Scratch-built the spar framing of the upper sides of the undercarriage bays to address the 'huge black hole' effect Scratch-built cockpit interior, (things are in the wrong place and sections missing, but in fairness I did use the kit seats) Added more detail to each turret as they were a bit bare Added Little-Cars landing lamps Added missing framing to bombardiers glazing Added missing doors to oil cooler slots on the top of the wing, (between engines) Scrap resin inserts to fill gaps under the engine nacelles where the later marks oil coolers would sit Resin propellors Re position the tall aerial mast behind the canopy as Italeri have it too far forward, (same goes for the 'towel rail' aerial under the rear fuselage) Replaced Italeri's 'canons' with Quickboost resin guns barrels Added PE splitters to oil cooler intakes Squared off the FOD guards to fit the Mk1's carburettor housings Replaced the two oversized blade aerials under the nose Decals from the Xtradecals Bomber Command set Painted using Mr Hobby acrylics, Tamiya NATO black, AK Interactive washes and filters and MIG pastel powders.....aerial line, Uschi 'standard size' elastic thread, (best stuff for the job by miles). I can't say I enjoyed building this one particularly but anyway I got there in the end which is the main thing............a labour of love this was as the Stirling is my favourite of the 'big three', (mind you I'm a bit biased as my late uncle was a flight engineer on them), but come on Airfix...you know you want to ! My thanks to John (12jaguar) for his help with the interior stuff...cheers mate ! Cheers all, , hopefully see many of you on Saturday...... Melchie...(the moocher) Obligatory 1943 'Somewhere in England' shot... And some of the smaller detail stuff Added the curved ends to the ailerons that were missing for some reason.... Edited November 5, 2015 by general melchett 83 Link to comment Share on other sites More sharing options...
Rich G Posted November 5, 2015 Share Posted November 5, 2015 Really nice General, Lots of lovely subtle details, it looks superb, will we see it at Telford? Rich 1 Link to comment Share on other sites More sharing options...
occa Posted November 5, 2015 Share Posted November 5, 2015 Lowered the height of the canopy by 2mm Ah I had the feeling the canopy of the kit has too much height ... Re-profiled the fuselage topside section Have to look into this, thanks for pointing it out that there is a problem there. What a great and convincing build anyways !! 2 Link to comment Share on other sites More sharing options...
JWM Posted November 5, 2015 Share Posted November 5, 2015 Superb! 1 Link to comment Share on other sites More sharing options...
russ c Posted November 5, 2015 Share Posted November 5, 2015 Great looking Stirling there, really nice work 1 Link to comment Share on other sites More sharing options...
crobinsonh Posted November 5, 2015 Share Posted November 5, 2015 Great build and superb finish. I do love the Stirling. Would be great to get a 1/48th version in injected plastic. 2 Link to comment Share on other sites More sharing options...
general melchett Posted November 5, 2015 Author Share Posted November 5, 2015 Thanks chaps, appreciated as ever, Rich, yes it'll be there...(it better had be now I've finally found some time to finish the blessed thing !).....along with many more. occa, yes it's a pain, if you want an accurate Stirling out of the box then this aint it...the fuselage section issue was bought to my attention by John Lathwell of the Stirling Project who has copies of factory plans, he noticed that it looked odd and investigated... Cheers... 3 Link to comment Share on other sites More sharing options...
general melchett Posted November 5, 2015 Author Share Posted November 5, 2015 I do love the Stirling. Would be great to get a 1/48th version in injected plastic. Thanks Colin...totally agree, though preferably by someone who can get in touch with the project to gather data on what the thing actually looked like.. 1 Link to comment Share on other sites More sharing options...
Val_Ukraine Posted November 5, 2015 Share Posted November 5, 2015 Great job, sir! 1 Link to comment Share on other sites More sharing options...
Colin1967 Posted November 5, 2015 Share Posted November 5, 2015 Good afternoon General, I really like this model - I am lookingforward to your next build Thank you for sharing your work with us, kind regards, Colin. Link to comment Share on other sites More sharing options...
dogsbody Posted November 5, 2015 Share Posted November 5, 2015 Beauty! Your modelling skills are undeniable but your aircraft terminology is questionable. The carb intakes are on the upper rear of the engine nacelles, behind the cooling gills. On the mark of Stirling, the oil coolers are the openings in the leading edge of the wings, between the engine nacelles. On the latter marks, the oil coolers were the tubular items under the engines. Chris Link to comment Share on other sites More sharing options...
general melchett Posted November 5, 2015 Author Share Posted November 5, 2015 Thanks guys, Colin I have several waiting in the wings including a certain 1/24th RAF low level strike aircraft that really must be finished !, (but now Tom Probert has gone and ordered me a 1/24th F-4 Phantom for pick up at Telford I really can't say what's going to happen !) Link to comment Share on other sites More sharing options...
general melchett Posted November 5, 2015 Author Share Posted November 5, 2015 Thanks Chris, yes you're quite right, I typed this in a bit of a hurry as I'm also finishing last minute bits and pieces for Telford and will amend 1 Link to comment Share on other sites More sharing options...
dogsbody Posted November 5, 2015 Share Posted November 5, 2015 Ah, yes. I understand completely. I have to make sure I proof-read everything before I hit the " post " button. My weak typing skills have definitely not improved with age. Chris 1 Link to comment Share on other sites More sharing options...
Beard Posted November 5, 2015 Share Posted November 5, 2015 I could only hope to achieve such a fantastic finish. 1 Link to comment Share on other sites More sharing options...
general melchett Posted November 5, 2015 Author Share Posted November 5, 2015 (edited) Ha...Chris, I know what you mean, 'type in haste, repent at...' and all that. I spend most days writing articles for modelling magazines and still have to check the text over and over before showing it to my 'proof reader' daughter, (school teacher) who usually says...'well that hardly makes any sense !'...oh well there's always the delete button ! Thanks Beard, (great handle !)...it's not that hard really. Edited November 5, 2015 by general melchett Link to comment Share on other sites More sharing options...
F4u Posted November 5, 2015 Share Posted November 5, 2015 Hi General, I have been waiting to see your Stirling and you have not disappointed that sir is really nice. 1/48 would be nice and as you say look right too along with a new 1/48 Lanc and Halibag we don't ask for much do we ?? Once again good work. Guy 1 Link to comment Share on other sites More sharing options...
Beard Posted November 5, 2015 Share Posted November 5, 2015 Thanks Beard ... it's not that hard really. For you maybe. 😃 1 Link to comment Share on other sites More sharing options...
general melchett Posted November 5, 2015 Author Share Posted November 5, 2015 Hey, we all had to start with a brush and a pot of paint and no idea what to do next 5 Link to comment Share on other sites More sharing options...
eng Posted November 5, 2015 Share Posted November 5, 2015 Wow, Stirling work you've done there (see what I did there!), what a stunner of a build. Not an aircraft I know much about myself, but from the list of alterations and amendments you've certainly done it proud. Beautiful (just like my puns!) Eng 1 Link to comment Share on other sites More sharing options...
tonyot Posted November 5, 2015 Share Posted November 5, 2015 Very nice indeed,......it really looks the part and the paintwork is sublime! Cheers Tony 1 Link to comment Share on other sites More sharing options...
Snitok1983 Posted November 5, 2015 Share Posted November 5, 2015 So here is that gorgeous girl who has stolen all of the Tornados time!!! Very well done,Sir! 1 Link to comment Share on other sites More sharing options...
general melchett Posted November 5, 2015 Author Share Posted November 5, 2015 Thanks fellas, I think most of us have a liking for the old Stirling.... Eng I was wondering who would be the first and there you are, bold as brass..... Cheers Tony, appreciate that...hopefully see you on Saturday I'll be there along with the other reprobates, co-conspirators and delinquents, it's a 'bring a bottle do' and no, can't can't bring that ! Thanks Egor, yes, you're right it's eaten into quite a few things to be honest as I couldn't leave it as is and only end up making a lot more work for myself, (and to think I've still got the 1/48th FM Halifax B.III to do yet ! )..now I will get back to the swinger.....though it's got stiff competition from a certain Sukhoi swinging product too, (and it's not one of Trumpeters efforts !). Link to comment Share on other sites More sharing options...
rob85 Posted November 5, 2015 Share Posted November 5, 2015 General, I do wish you would stop posting your poor quality work on here, I mean really! Put some effort in!! (Sarcasm was heavily involved in the making of this post) I remember making the Airfix kit as a kid, my grandad (the reason I love aircraft) bought me one for my birthday, I saw a pic of another bomber (Lanc I think) with the saint pic on the side so painted one on my Stirling! Happy to see I wasn't completely off the mark. I my childish mind it turned out just like yours. ....in the real world it was probably a mess of humbrol enamels and silvered wonky transfers. Beautiful model, as ever, shame I won't be seeing it at Telford Rob 1 Link to comment Share on other sites More sharing options...
Mmarchal Posted November 5, 2015 Share Posted November 5, 2015 Superb work, looks very convincing. The extra attention to detail certainly makes a difference. 1 Link to comment Share on other sites More sharing options...
