roymattblack Posted August 26, 2016 Author Share Posted August 26, 2016 (edited) When I make symmetrical parts, as in the two side panels here, I cut one, then stick it to a sheet of plastic with a few squares (about 10mm) of double sided tape. Then I cut round the first shape. Next, file or sand the two pieces while still stuck together until they look like one piece. Carefully peel apart, remove the d/s tape and voila - two identical pieces. (...and no - the 'Boss' is too kind although extremely appreciated) Roy. Edited August 26, 2016 by roymattblack 2 Link to comment Share on other sites More sharing options...
sharknose156 Posted August 26, 2016 Share Posted August 26, 2016 "The Boss" is earned and deserved Link to comment Share on other sites More sharing options...
roymattblack Posted August 26, 2016 Author Share Posted August 26, 2016 (edited) Sorted - removed. Edited August 28, 2016 by roymattblack 2 Link to comment Share on other sites More sharing options...
TGA Posted August 27, 2016 Share Posted August 27, 2016 When I make symmetrical parts, as in the two side panels here, I cut one, then stick it to a sheet of plastic with a few squares (about 10mm) of double sided tape. Then I cut round the first shape. Next, file or sand the two pieces while still stuck together until they look like one piece. Carefully peel apart, remove the d/s tape and voila - two identical pieces. (...and no - the 'Boss' is too kind although extremely appreciated) Roy. I was thinking about sticking my bulkheads together and sanding them as one so good to hear this is being used by the pros too! Lovely offer on the resin engine by the way. Worth some serious thought!!! 1 Link to comment Share on other sites More sharing options...
Brandy Posted August 27, 2016 Share Posted August 27, 2016 When I make symmetrical parts, as in the two side panels here, I cut one, then stick it to a sheet of plastic with a few squares (about 10mm) of double sided tape. Then I cut round the first shape. Next, file or sand the two pieces while still stuck together until they look like one piece. Carefully peel apart, remove the d/s tape and voila - two identical pieces. (...and no - the 'Boss' is too kind although extremely appreciated) Roy. I do pretty much the same when making tail pieces for my aircraft, but because they're a lot smaller, instead of taping them together I simply use a clamp to hold them tight. Ian Link to comment Share on other sites More sharing options...
roymattblack Posted August 31, 2016 Author Share Posted August 31, 2016 Work is pretty sporadic at present as the weather has just been too nice... However - rear under body now fitted but detailing is still needed. Also - couldn't resist adding a few decals at the back. It makes it look like more of a car. Roy. 5 Link to comment Share on other sites More sharing options...
ElectricLightAndy Posted August 31, 2016 Share Posted August 31, 2016 Looking fantastic Roy and I like the way you did the gearbox tunnel. Andy. Link to comment Share on other sites More sharing options...
kpnuts Posted August 31, 2016 Share Posted August 31, 2016 Roy, what can I say, that is gorgeous, and the colour is sublime. Link to comment Share on other sites More sharing options...
CrazyCrank Posted August 31, 2016 Share Posted August 31, 2016 Finally, Roy, watching your great scratch-work, my fingers are itching too. I think I'll try in the foreseeable future, to build entirely from "nothing" Thanks for the inspiration and Hats off ! Link to comment Share on other sites More sharing options...
roymattblack Posted September 6, 2016 Author Share Posted September 6, 2016 (edited) Thanks guys. It's nice to know my scratchings are helpful. Slow work here still - nice weather, wife with broken foot etc... Beginning to make up some of the rear suspension parts now. Once the axle and diff are in I'll get the engine installed. The rear bits are all made up from sheet plastic, and screwed/bolted together so it all moves allowing the axle to go in and getting the parts lined up later. I've also been casting some resin parts for the Lister Knobbly for the next build so I've sorted the fuel filler for this one. Roy. Edited September 6, 2016 by roymattblack 3 Link to comment Share on other sites More sharing options...
Pouln Posted September 6, 2016 Share Posted September 6, 2016 Great stuff as always. Enjoying very much to see how you build this beauty Link to comment Share on other sites More sharing options...
D1fuN0 Posted September 7, 2016 Share Posted September 7, 2016 Very nice indeed Roy Mad Steve Link to comment Share on other sites More sharing options...
