Mike Posted September 7, 2015 Share Posted September 7, 2015 Mosquito Mk.IV (for HK Model)1:32 Eduard HK Models' new Mossie hit the shelves just before the Tamiya kit, and Eduard have already released these sets to give us some extra detail, added realism and to ease some of the painting tasks that tax us modellers. There are a number of Photo-Etch (PE) sets available to choose from, all of which come in the usual flat-pack with white cardboard protective liner. The bags are self-seal, so you'll still be able to re-pack them once you've had a squint at the instructions, but take care not to get the contents stuck on the adhesive. It doesn't like to let go!Interior (32840)This set that contains a pre-painted and self-adhesive sheet as well as a bare brass sheet of PE is solely concerned with increasing the level of detail within the cockpit, which although cramped is quite visible under the canopy at this scale. It replaces all the moulded-in instrument faces and decals with a set of laminated panels that are pre-printed with dials for your ease. The simple kit rudders are replaced with PE parts that have much better detail, and a backing panel that prevents the see-through look. The throttle quadrant, compass and various other items on the side walls are also upgraded or replaced, resulting in a much improved level of detail. Interior Zoom! (33148)If you'd just like a set of instrument panel faces and control improvements, then this set is for you. You miss out on the skins for the radio boxes, rudder pedals and other parts, because you just get the pre-painted and self-adhesive sheet shown above, with a corresponding reduction in price. Seatbelts (32841)A set of good quality PE seatbelts with pre-painted surfaces are within the bag, with additional details such as loose tabs, extra buckles and a more complete depiction of the whole harness. They are simple to bend, but take care not to bend them too sharply, as the tight radius could bring off the painted surface. A dab of superglue should hold them in place nicely. Seatbelts FABRIC (32839)To me, the fabric belts are the pinnacle of realism in a kit, and are at their best in 1:32. You get a sheet of "material" on a sticky background, which you peel off, scrunch up and then add the nickel-plated PE hooks, buckles and adjusters in the same way as you would on the real thing. They are fiddly at 1:48, and less so at 1:32, but your hard work will be rewarded by a superb set of belts that fall realistically on the seats. Masks (JX182)If you hate masking, or just want to save some time, this pre-cut sheet of yellow kabuki tape is for you. It includes a full set of masks for all canopy components, with the sharper curved areas having the usual framing pieces, with you left to fill-in the highly curved area with scrap tape or masking fluid. You even get a couple of circular masks to cover your wheel hubs. Review sample courtesy of Link to comment Share on other sites More sharing options...
