Rybeast Posted August 27, 2015 Share Posted August 27, 2015 I've had a few people mention now that they're spray painting their primers or large portions of their kits. I tried on Sunday and failed - lots of splodges, areas without paint other areas with. What would you say are your 'top tips' in order for me to succeed with this? Do I press the spray down fully? Do I have to get a balance? Link to comment Share on other sites More sharing options...
Blitz23 Posted August 28, 2015 Share Posted August 28, 2015 I always use short bursts, you don't want to much paint in one area. Don't be worried about having to give your model a few coats, better to let it fully dry and go back to it then have splodges form where there's to much paint. I always prime the top fully first rotating the base I rest the model on without having to touch the actual model and once dry I flip and do the same with the bottom. Link to comment Share on other sites More sharing options...
Rybeast Posted August 28, 2015 Author Share Posted August 28, 2015 I agree - I don't want too much! How can you get an even coverage using short bursts? How far do you keep away from the model when spraying? A foot (30 cm)? Link to comment Share on other sites More sharing options...
Black Knight Posted August 28, 2015 Share Posted August 28, 2015 Are you using a spray can [aka a rattle can] or a spraybrush? This will determine the distance to spray from. With either, start spraying off the model and pass over the model, stopping the spraying when you're off the model again. Rotate the model a bit and spray again. Rotate; spray, until it has an even but light coating. When that coat has dried, turn the model over and repeat. 1 Link to comment Share on other sites More sharing options...
