bar side
Building a HAS
492 posts in this topic
Still not sure if harrier with aim-9s looks the way I want, or if it should have rocket pods too.  4 rocket pods look right on the toom though.
Maybe a 1000 pounder on the centreline would be realistic? Or just another Harrier next to it for company?
1000 pounder on the centre line sounds doable.  Tried out the older hunter rocket pods on it today.WP_20170128_13_23_50_Pro_zps6adyjixi.jpg
Have also been playing with painting pilots today.  They look quite at home in the phantom.
Well trying out the centre line bomb load for size.  And the pilot sitting in the cab
2 people like this
Not doing much in terms of aircraft building at the moment so decided to make some more clutter.  Someone said pallets, and I thought packing cases & a couple of bits came together. Not perfect but should make good scenic clutter
4 people like this
Not much progress to report, but a little ebay purchase arrived this week.  Not really after another Esci Northrop F-5, but it comes with the support group that I have been after for a while.
Lots of nice little clutter bits for the HAS in that
Now I have heard that the USAF in Germany used Ford tractors as tow tractors.  Ford tractors were on RAF bases but I don't know for sure if they were used for towing.  Also I am not sure if they were green or yellow.  Time for some internet digging.
1 person likes this
Liking the clutter that builds up with the new trolleys - not painted yet but fitting in nicely
When you start to realise your stock of bits is getting a little out of hand...
That's not even all of it.
Edited by bar side
4 people like this
My scratch build project is taking most of my time at the moment, but I have been doing bits with the ESCI ground crew set.  So here are some pics with the HAS, the Phantom and about as much clutter as I can come up with.
The Phantom has interchangable noses - the black nose cone is inside the HAS.  Partial appearance by the Bedford tanker on the left.
And an odd angle but I quite liked it
5 people like this
The HAS is looking very business like ! What is next on the project list ?
Nige
Nige
Well Nige the next project is a new aircraft and its taking a while as its a scratch build.  It's a Dominie & progress is over in the aircraft wip section.could take a while though!
Edited by bar side
Superb work, looks great! The lighting adds a lot to the effect.
Cheers James - just daylight this time, no internal lights or anything else, even though they do work
Very cool photos.
1 person likes this
With regard to the HAS equipment I believe it was correct to position it in marked bays along the sides of the HAS.  This Tonka gives an idea of the marking out I was thinking of
But this Lossiemouth Typhoon takes it to another level.  I assume this amount of colour & marking out came along more recently - I was thinking about 1980 ish
RAF-Lossiemouth-Typhoon-hangar-Hardened-
Not sure if the Wattisham HAS is painted as per operations or as a museum space
I guess yellow & red denote different items stored - yellow edged or solid yellow could be ground power / tools / ladders and red edged or solid red for weapons?  Might experiment with some lining with tape before painting things on
1 person likes this
Fire points are  red with white outline. CO2, BCF, Foam, Dry Powder Extinguishers, buckets of sand.
Check the pic with the Typhoon.
Edited by bzn20
Thank you - that's a good place to start.  Have seen them inside the front door on the left.  I guess thats a usual location
I imagine it would be in a HAS. When the Fire Alarm goes the drill is to get out immediately take all the fire fighting gear with you. That's so we can be brave and run back in help fight it before the Fire Section turn up. In a HAS its closest to the main door. In hangars it could be anywhere, there were several but we knew where they were. In Base Hangar at Brize they were at the back of the 6 bays, probably 8-10  fire points full of gear I mentioned above plus Asbestos (ARGH!) Fire Blankets. Depending on year of course. they wont have them now and in a HAS anytime, probably went with the 70's. You'll need to get the right colours for extinguishers...Blue for Dry Powder, Black for CO2, Foam Cream, BCF kind of Olive Drab, Red for Water, Sand Buckets Red. Then some are trolleys (like the Typhoon pic but I don't understand the colour! It wont be water) some on two wheels (CO2) and a Lance (engine fires on runs)
Edited by bzn20
2 people like this
