jhutchi Posted August 6, 2015 Share Posted August 6, 2015 Hi all. I'm looking to strip an old model and repaint. What is the best / easiest way of doing it please? Thanks Link to comment Share on other sites More sharing options...
spruecutter96 Posted August 7, 2015 Share Posted August 7, 2015 Hello. Hannants sell a product called "Model Strip" (if I remember correctly). It comes in a plastic container, very roughly half the size of a Coke can. It's about £5.00. You paint a good, thick layer of the stuff on the area you want to remove paint from, wrap the model in a plastic-bag and leave overnight, then wash the product off the next morning with cold water and an old tooth-brush. In my experience, it removes just about anything. You can also use some domestic cleaning-liquids (Tesco's Value Household Cleaner is a decent, very cheap example), but I have found these rather slow and not effective on all types of paint. Hope this helps. Chris. Link to comment Share on other sites More sharing options...
cruiserguy Posted August 8, 2015 Share Posted August 8, 2015 HI Jhutchi, Homebase and B&Q sell a good gel paint stripper for less than £10 a pot. You brush it on, let it work, and wash it off. It doesn't have the odour of some other paint strippers. Failing this, Fairy Power Spray, and the Tesco Cleaner "stickied" on the forum are good too. The Tesco stuff is rather slow so an overnight soak is required. Powerspray will strip most acrylics in an hour or so. Best Wishes, Will. Link to comment Share on other sites More sharing options...
jhutchi Posted August 8, 2015 Author Share Posted August 8, 2015 Thanks guys. Is the ModelStrip a paste? Does it brush on fairly easily please? Link to comment Share on other sites More sharing options...
