Shar2 Posted July 23, 2015 Share Posted July 23, 2015 KRAZ-6322 Heavy Utility Truck Takom 1:35 HistoryThe KrAZ-6322 heavy utility truck was developed by the Ukrainian AvtoKrAZ. This military truck evolved from the previous KrAZ-255 and 260 models, but has been upgraded to meet today's standards. It is a reliable and proven design. Vehicle is produced since 1999. It is in service with Ukraine, Angola, Egypt, India, Indonesia and Yemen. A large number of these military trucks were ordered by the US Government for the new Iraqi Army. It is also in service with Iran and possibly some other countries.The KrAZ-6322 has a payload capacity of over 10 t. Vehicle can tow a trailer with a maximum weight of up to 30 t on hard surface roads. It can also tow aircraft with a maximum weight of up to 75 t on the airfields. This heavy-duty military truck is intended for different loads and troop transportation. Basic design can accept a wide variety of body types. The standard body is fitted with drop sides and a removable tarpaulin with bows. Wooden bench seats may be fitted for troop transportation. Vehicle can carry up to 24 troops. A three-person cab is standard across the range. It is very similar to that of the earlier KrAZ-260.The KrAZ-6322 is powered by Russian YaMZ-238D (EURO 0) turbocharged diesel engine, developing 330 hp. This engine is fitted as standard, however this truck is also offered with improved YaMZ-238DE2 (EURO II) diesel engine. Other engine options are available, including Cummins, Deutz, Volvo or others, to suit customer requirements. This military truck has considerable cross-country mobility. Centralized tyre inflation system and 12 t capacity self-recovery winch are optional.The KrAZ-6322 is proposed in a number of variants, including KrAZ-6135V6 long wheelbase version, repair and recovery vehicle, BM-21U multiple launch rocket system, fitted with Grad launcher, KrAZ-6446 tractor truck and other specialized vehicles. Another interesting variant is a KrAZ-6322 Raptor truck, fitted with local armour protection and armoured cargo module. This variant was jointly developed by Ukrainian AvtoKrAZ and Canadian Streit Armoured Group. It was revealed in 2007. Vehicle can carry 20 fully equipped troops and provides protection against 7.62-mm rounds, landmines and IEDs. Troops use a number of vision blocks and firing ports. Raptor has a payload capacity of 6 tonne. If necessary, the armoured cargo module can be removed.The ModelThe kit comes in a sturdy top opening box with a artistic impression of the vehicle in use in a battlefield environment. Opening the box reveals eight sprues of green styrene, two sprues of clear styrene, two small photo etched brass sheets, seven vinyl tyres and a small decal sheet. The mouldings for all the parts are superb, with no sign of flash imperfections and very few moulding pips. As with most truck kits there are a lot of parts that will probably never be seen, particularly the very detailed chassis, suspension and engine, but in my view it’s better to have them than not. The build begins with the assembly of the gearbox, which is provided in two halves, and then finished off with a sump plate; this is followed by the two part engine block to which the gearbox is attached. Since the truck is powered by a V8 diesel there are two cylinder heads to assemble, again each of two halves, to which the injector rails and coils are attached. These are then fitted to the engine block, followed by the alternator, water pump pulley and fuel filter. The exhaust manifolds are next, followed by the CDR valve and oil filter. The turbocharger is assembled from three parts, the turbine housing, compressor housing and attachment plate; the assembly is then fitted with the outlet pipes. The completed sub-assembly is then fitted to the engine with each outlet pipe being attached to the intake manifolds and the turbo intake to the exhaust manifold. The oil cooler is then fitted to the engine block, along with the fan, accessory belt pulley and the exhaust pipe, to which a two part silencer section is fitted to the end, is attached to the turbo. To enhance the engine further the modeller could/should add the ignition/electrical harness and the auxiliary drive belts. The next part of the build is the assembly of the chassis. This consists of the two long chassis rails, to which the engine assembly is fitted at the front along with the radiator, whilst two thirds to the rear a cross member is attached. The front differential gear housing is assembled from two halves, to which a two part gear cover and universal joint are attached. Each wheel hub is made up of an inner and outer steering ball joint, hub backing plate, inner axle, and brake drum. These are then fitted to the ends of the differential along with the brake accumulators and steering rack. The two leaf spring parts are then fitted via four U bolts and clamps, much like the real parts. The front axle is then fitted to the chassis, as are the shock absorbers, front crossbeam, made up of four parts including the front towing eye, radiator fans housing and grille. There is a cable drum affixed between two crossbeams and fitted with a motor and control lever, this is then fitted to the rear of the chassis along with a curved crossbeam further forward. The transfer box is assembled and fitted just aft of the front axle and connected to the engine and front differential with two drive shafts. The rear suspension is now assembled from two suspension plates, two leaf springs, four U bolts and clamps. To this the two part rear differentials, which are 90o opposed when compared with the front, are fitted, along with their associated gear housings each made up of four parts, drive shafts, with separate universal joints, and suspension bump stops. The rear wheel hubs are much simpler affairs, made up of only an inner and outer brake drum and an internal axle. Once these are fitted to the differentials the completed rear suspension is attached to the rear chassis. The next stage includes the building of a number of sub-assemblies; these include the twelve part spare wheel cage which is attached to the six part generator housing, two seven part accumulator bottles and racks, two five part fuel tanks, six part oil tank and its rack, plus the three part cab foot step and six part tool box. These are then attached to their respective positions on the chassis along with the rear towing hook and end plate, reflectors and their outriggers and the rear lower crossbeam. With the chassis and suspension complete the build moves onto the truck bed. This is made up from the main bed, back panel and two side panels and rear panel. On the underside there are seven structural braces fitted, whilst on the back and sides there are twenty four tilt ties. Also on the underside the four mudflaps are attached, two forward of the rear wheels and two aft each with their support rods. The front mudguards are styrene whilst the rears are PE bent to shape. The completed bed is then fitted to the top of the chassis and the spare wheel, made up of a vinyl tyre plus inner and out hubs is slid into its cage on the right hand side. The last major assembly, the cab and bonnet begins with the windscreen frame/front bulkhead is fitted with the two windscreens, and wipers. On the inside of the bulkhead the inner panel/instrument binnacle is attached and fitted with the steering column, steering wheel, and pedal plate. The doors are then assembled from the door frame, “glass” and separate door card, whilst the rear bulkhead is fitted with the rear screen. The front and rear bulkheads plus the doors are then joined together before the roof, with its associated light fittings is attached. The interior floor is then fitted out with the bench like passenger seat, made up of separate squab and back which is then fitted to the base via the seat frame. The drivers seat which consists of the frame, squab, back and adjustment lever is fitted to the floor via a five piece spring like framework. The interior is completed with the fitting of the gearstick and the whole assembly is glued to the to the cab assembly, which is finished off with the addition of the two wing mirrors and their mounting supports. The bonnet wings are glued to the grille and fitted with the separate front bumper which includes the light clusters pre-moulded,, but requires the fitting of the three footplates, light lenses and front ID plate holder. The completed assembly is then fitted to the front of the vehicle and finished off with the fitting of the bonnet. If you wish to have the bonnet raised to show off the engine you will have to scratchbuild your own hinges and gas struts. The finishing touches are the assembly of the six wheels, each with a vinyl tyre, inner and outer hubs, which are then fitted to the axles. Each of the vinyl tyres is very well moulded and look realistically chunky, but they do have a cross shaped section that needs to be cut away before the hubs can be fitted, but it shouldn’t take too much to clean them up, especially as the hub rims will cover the areas concerned. DecalsThe small decal sheet provides decals for five different colour schemes. Whilst there aren’t any external placards other than the number plates, the instrument faces are provided. The decal sheet is beautifully printed, with the colours appearing ultra vibrant and yet in register with excellent colour density and little visible carrier film. The camouflage choices are:- Ukraine National Guard in a three colour scheme of green, grey and black Ukrainian Army, (ATO), in green overall and white identification stripes on the doors, bonnet creating a cross on the roof. Ukrainian Army, (ATO), in dark green, light green, and black, with one thick and two thin white stripes over the bonnet, cab roof and rear turck bed panels. Georgian Army, in dark green, yellow grey, and grey. Donetsk Peoples Republic, (DNR) in overall dark green. ConclusionThis is great looking kit, and with the choice of several different colours schemes it will certainly be an interesting addition to a collection. It could also be used in a variety of diorama situations. The truck bed is crying out for a load to be added, perhaps with a tarpaulin or camouflage net included. Very highly recommended. Review sample courtesy ofUK Distributors for Link to comment Share on other sites More sharing options...
