Vince1159 Posted February 10, 2017 Share Posted February 10, 2017 She's a beauty 5054,a real credit to your skills and the 'Blue Max' adds a bit more (have one next to Von Richthofens Dr-1).... 1 Link to comment Share on other sites More sharing options...
k5054nz Posted February 11, 2017 Author Share Posted February 11, 2017 Thanks Vince! I have since also done a movie Fokker D.VII and am working on a "German" Tiger Moth: 2 Link to comment Share on other sites More sharing options...
SeaVenom Posted February 11, 2017 Share Posted February 11, 2017 (edited) On 08/02/2017 at 5:24 AM, k5054nz said: The other one uses a Tiger Moth fuselage frame as its base, so it's longer than it should be. Apparently it's quite nice to fly so TVAL uses it for training their pilots. But as a model it'd mean a lot more work. 'TIJ needs a four cylinder engine plus support struts between the fuselage and lower wing. Thanks for that. I don't know if you've had a close look at the Encore 1/32 kit but you can build either the movie version (using the resin parts) or the historical and literary version. Does G-ATIJ have that distinctive pointing upwards exhaust or does it have a more accurate pointing downwards exhaust? I can't seem to tell from the photo. Is G-ATIJ a lot more accurate to the original machines than TIJ or only a bit? P.S. (Love your DVII replica too) Edited February 11, 2017 by SeaVenom Link to comment Share on other sites More sharing options...
k5054nz Posted February 13, 2017 Author Share Posted February 13, 2017 Thanks! G-ATIJ - Hillbourne/Bellamy - is a LOT more accurate. G-ATIF is the other one (not sure if I got that right earlier). You can just make out the exhaust in my first photo of the real one - mounted to port, slanting up then horizontal. This photo shows it even better. I remember reading the Encore kit had a four-cylinder engine. Link to comment Share on other sites More sharing options...
SeaVenom Posted February 15, 2017 Share Posted February 15, 2017 Cheers for that! It looks like they've both got similar exhausts. I've been trying to find a photo of the 2 replicas side by side but have had no luck so far. Link to comment Share on other sites More sharing options...
