Russian T30 plus T40 Amphib light tanks
foxy
Hi well these two tanks are the same for some minor difference's. One being a land Recce tank and the T40 an Amphibious one.
As you will see there are some difference's.
First its the T30, this come's with some PE as well as decals.
Pictures.
I am think on the lines of this for the T30.
T40.
Reminds me of the Japanese tanks I built some time ago.
Maybe they got the idea from each other in there early conflicts.
The chassis is strait forward, but placing the wheel supports is tricky, there very flimsy, and some had to be reinforced with plastic card strip's. The left to dry for 24hrs.
Basic frame made up.
The tracks come in singles, so some work there to make up the full chain.
The vents have to be placed in before assembly of the hull.
Here shows the PE used for this kit, all come's with the kit, have already primed the PE with Tamiya primer.
Then its a primer next.
Not a bad kit to build, if you don't mind the track links.
Foxy. :coolio:
Hey Frank Have you been taking some kind of medication you are on a speed feast with these little Russian gems at the minute Nice little pair to be getting on with :bouncy: you know I just had to get that one in :evil_laugh:
Beefy
'Yeh me to Beefy mate', Might find an excuse one day lol.
Cheers SS, yep these little gems go together so well.
Well sprayed two coats of Russian green and added tracks. painted these with Tamiya grey iron, then its AK track wash.
Tracks all on.
Turret guns are little gems in themselves.
With care they move too.
Then after a wash and then some cleaning up, on goe's the three other colours.
Figure just for show at the moment, have others in the pipe line with Hornet heads.
Foxy :coolio:
Nice little build going on there.
I am glad that the trauma of putting the tiny track links together has kept you sane!
Track sag looks really good as does the rest.
Good Job
K
Thanks guy's.
Yep its always difficult to get that sag, but doing the track in pieces helps.
Made up of five or six then added a single one when still wet.
foxy :coolio:
It's looking great foxy.
I know not everyone will agree but I'd be happy to put up with the slight loss in detail and have link and length tracks with a pre-moulded sag rather than have the faff of trying to wrap glued lengths around the wheels.
Those Russian light tanks did have inconsiderately small track links. If only they'd thought of future modellers when they designed them
Andy
See what you mean by complex in 1/72nd Sgt. S.
I have plenty of kits in that scale to build, but none that would compare with this ESO kit.
Mostly resin one's.
Andy. that's the price of scale, but once you get going its not that bad, the hardest is joining up the first two links, once done, its surprising how quick it becomes when two makes four and so on.
I find these are painted better by hand to start with, then a spray over later.
foxy :coolio:
Thanks Dan.
Well added the disruptive pattern of two coats.
The kit comes with an array of numbers, I chose 4, 'don't know why'!!!!.
Lost the rear light when taking pictures, did not realise the wind's strength !!!.
foxy :coolio:
Nice to see some extra colour on Soviet stuff! :thumbsup:
TBH, nothing compares to that ESO kit.....I've wanted one for ages, just to remind me that whatever I'm currently building (& thus moaning about), really isn't that bad! The scariest thing I've handled so far were 1/72 T-26 links (on a Fiat Ansaldo M13/40), so positively massive compared to the TKS tankette! :winkgrin:
Cheers guy's.
Well its finished till I use for a Diorama one day.
Managed to find a replacement for the missing rear light.
Had some M5 one's left over from my M3/5 builds a while back.
I drilled out the PE and added plastic rod, this should do the trick.
Thanks for looking folks.
Next it the T40, this will be in Finnish or German hands.
Cheers foxy :coolio:
Ok next its the T40.
This is an amphibious version of the T30.
So the superstructure will be similar to the T30.
The differences will become apparent in the pictures.
But the solid wheels is one.
To the chassis.
Made up the basic parts and added some PE.
Not added the propeller just yet.
A coat of primer to the PE and later some green primer once the top hull is in place.
A picture of the captured tank I might do, or a Finnish captured one.
That's it so far.
Well moved on a touch with the second T40.
So as not to bore with the same detail build as the T30, will keep this build with only the T40 details.
Added primer and started on the hull, plus the tracks are all made up ready.
Solid wheels for this one and cavity for the propulsion.
foxy :coolio:
Cheers Kev, Dan and Sgt S.
I have decided to make this a German captured one, this was taken early in the invasion of Russia and sent back to a workshop for repair and a paint job.
Then issued to the 1st Panzer Div as a recce tank in Von Klests Army.
The paints I used for the colour and shading are:-
Vallego in all, but some Life color for the wheels etc.
First after the green primer I added some Vallego Russian green.
Then used the grey colours for the final coats.
This picture should give you some idea of the layout of the propulsion system and rudders plus the paint colour.
Tracks are on and now working on the upper structure which is near as dam it the same as the T30.
So the next pictures will be when its together and Decals added.
Foxy :coolio:
Right got the T40 near done with just some weathering and finish the figure for the turret.
As this was so near the T30, I have not shown the full build,(might bore you!!!).
Note this is a captured Russian to get away from the green and white so many dislike!
Note the MG34 instead of the Russian one.
When finished proper, will show in the RFI.
  • 3 weeks later...
