CedB Posted May 25, 2015 Author Share Posted May 25, 2015 Thanks Stew and Rob - so if it doesn't click then paint and see what it's like? Sounds like a plan... Hi PC - my cutter's a Shesto Model Craft that I bought at some show or other. 1 Link to comment Share on other sites More sharing options...
Spookytooth Posted May 25, 2015 Share Posted May 25, 2015 The black permanent marker run down the seams is another way of checking, especially if you use the squared of tipped ones. A light sanding after should show any problems. Simon. 2 Link to comment Share on other sites More sharing options...
philp Posted May 25, 2015 Share Posted May 25, 2015 Ced, I hear a Flexi file is great for round bottoms (can I get a score 1/2). But they can get expensive. Seen an article where a guy made his own out of some tubing folded into a "U" shape and a couple round headed pins glued in the ends to keep the sandpaper from coming off. Then cut your sandpaper into a thin strip and glue the ends around to make loops. Slide the sandpaper over the ends and ta da, Bob's your Uncle. Actually, don't think I have an Uncle Bob but then it is possible. I did a Google search to see if I could find it (unsuccessful, was probably buried in somebodies WIP) but did find this video made by a good ole boy who did a slightly different approach. I also run paint along my seems to check for sanding and usually use silver as it shows up real well. You can see it in this pic from my P-38 GB thread. See the seam where the radiator will go (and cover it up so I didn't putty it. 1 Link to comment Share on other sites More sharing options...
Nigel Heath Posted May 25, 2015 Share Posted May 25, 2015 Hi PC - my cutter's a Shesto Model Craft that I bought at some show or other. That looks just like the one I have. It works fine with the right technique. Link to comment Share on other sites More sharing options...
CedB Posted May 26, 2015 Author Share Posted May 26, 2015 Thanks Simon, Phil and Nigel, great tips Good news - Belle's seam passed the thumbnail click test so it's on with the wings and on with the bottom coat today. More later! Link to comment Share on other sites More sharing options...
Biggles87 Posted May 26, 2015 Share Posted May 26, 2015 I think you missed one there Ced with " bottom coat " haha. 1 Link to comment Share on other sites More sharing options...
CedB Posted May 26, 2015 Author Share Posted May 26, 2015 Thanks John, I'm not concentrating, obviously Glued the elevators flat and fixed the wings this morning with Liquid Poly, one at a time. Tiny gaps that need attention but, in my excitement (or perhaps I'm just not concentrating) sprayed the bottom without filling the gaps first*: Heck, she's big! OK, I'll admit it, I'm scared to death of rattle cans. I confidently set off to the garage (rattle, rattle) model in hand, stick it in the box* (rattle, rattle) hold the can the required distance away (roughly) and then press the button. All hell's then let loose and everything vanishes in a haze of [insert colour here]. Don't breathe - it says on the tin "May be lethal if concentrated and inhaled". So now you know why I'm not concentrating! (See what I did there. Arf arf, humour). Looks OK and I'm hoping for Cookie's experience with Tamiya in that it looks 'OK' and then settles to the best finish you've ever seen. Fingers crossed. * A bit too close to the mark to score but definitely fnaar fnaar 6 Link to comment Share on other sites More sharing options...
Biggles87 Posted May 26, 2015 Share Posted May 26, 2015 (edited) That reminds me of the Tom Lehrer song about pollution which ends Pollution, pollution, wear a gas mask and a veil. Then you can breath, long as you don't inhale. Fnaar fnaar (sorry) John Edited May 26, 2015 by Biggles87 2 Link to comment Share on other sites More sharing options...
Spookytooth Posted May 26, 2015 Share Posted May 26, 2015 Coming together nicely Ced. The primer coat on the under side will show any blemishes. I think we all get carried away sometimes, I know I have... Simon. 1 Link to comment Share on other sites More sharing options...
Nigel Heath Posted May 26, 2015 Share Posted May 26, 2015 Tamiya rattle cans are definitely my preferred method for coating whole models. The paint can look a bit alarming when first applied but generally dries to a lovely finish. 1 Link to comment Share on other sites More sharing options...
Cookenbacher Posted May 26, 2015 Share Posted May 26, 2015 The 'Belle' is looking great Ced. Good call at not concentrating in that haze. I like to wear this when spraying, just in case the morning's crossword comes to mind on accident, or I have to read something with small letters during the painting process, or if I'm thinking about orange juice. 2 Link to comment Share on other sites More sharing options...
modelglue Posted May 26, 2015 Share Posted May 26, 2015 Nicely done Cookie, Ced, that is also the apparatus the Gov't requires my employer to tell me to wear. Bit of a dodgy fit on my highly geometric pinhead, but it keeps my wife from yelling at me to wear it. I mean, I've had worse things strapped to my face is all. 1 Link to comment Share on other sites More sharing options...
Procopius Posted May 26, 2015 Share Posted May 26, 2015 Nicely done Cookie, Ced, that is also the apparatus the Gov't requires my employer to tell me to wear. Bit of a dodgy fit on my highly geometric pinhead, but it keeps my wife from yelling at me to wear it. I mean, I've had worse things strapped to my face is all. Modelglue in a previous career: 3 Link to comment Share on other sites More sharing options...
modelglue Posted May 26, 2015 Share Posted May 26, 2015 That's twice I've been called princess this week. Link to comment Share on other sites More sharing options...
CedB Posted May 26, 2015 Author Share Posted May 26, 2015 That reminds me of the Tom Lehrer song about pollution which ends Pollution, pollution, wear a gas mask and a veil. Then you can breath, long as you don't inhale. Fnaar fnaar (sorry) John Thanks John - Tom Lehrer is a long time favourite of mine, although Mrs B bans me playing him when she's around. Another secret pleasure! Coming together nicely Ced. The primer coat on the under side will show any blemishes. I think we all get carried away sometimes, I know I have... Simon. Thanks Simon - no blemishes that I can see apart from that weird seam colour. More tomorrow (in the hope that the seam fairies will clean it up overnight) Tamiya rattle cans are definitely my preferred method for coating whole models. The paint can look a bit alarming when first applied but generally dries to a lovely finish. Thanks Nigel. It certainly seems to have settled to a nice even coat (apart from the seam)! The 'Belle' is looking great Ced. Good call at not concentrating in that haze. I like to wear this when spraying, just in case the morning's crossword comes to mind on accident, or I have to read something with small letters during the painting process, or if I'm thinking about orange juice. Thanks Cookie. I can get those masks easily here but how do you decide what size (S, M or L?) and which filters do you use? Nicely done Cookie, Ced, that is also the apparatus the Gov't requires my employer to tell me to wear. Bit of a dodgy fit on my highly geometric pinhead, but it keeps my wife from yelling at me to wear it. I mean, I've had worse things strapped to my face is all. Thanks Princess MG and Procopius for the picture! This is a boring stage isn't it, waiting for the paint to go off so I can mask tomorrow for the Olive Drab... still, don't want it pulling off do we? * * Speak for yourself! Score 1, fnaar fnaar!! 3 Link to comment Share on other sites More sharing options...
rob85 Posted May 26, 2015 Share Posted May 26, 2015 Its almost like watching paint dry Ced ........ Rob 1 Link to comment Share on other sites More sharing options...
Cookenbacher Posted May 26, 2015 Share Posted May 26, 2015 I use the 6001 filter and it works great. I didn't even know what Tamiya paint smelled like until I hand brushed some a little while ago and didn't bother wearing the mask for it. Edit: As far as fit, I just had to guess. 2 Link to comment Share on other sites More sharing options...
sean Posted May 26, 2015 Share Posted May 26, 2015 This thread is quite mad, entertaining but mad nonetheless, Sean Link to comment Share on other sites More sharing options...
06/24 Posted May 26, 2015 Share Posted May 26, 2015 We're not mad, we're special! 4 Link to comment Share on other sites More sharing options...
sean Posted May 26, 2015 Share Posted May 26, 2015 Of course you are. Now settle down and watch the nice man make his aeroplane Sean 3 Link to comment Share on other sites More sharing options...
kwaterous Posted May 26, 2015 Share Posted May 26, 2015 We're not mad, we're special! Special... With a capital M(ad), or R(aving) Oh, the B-17... What's that? There's a plane here K 2 Link to comment Share on other sites More sharing options...
Nigel Heath Posted May 26, 2015 Share Posted May 26, 2015 (in the hope that the seam fairies will clean it up overnight) I have often hoped that the seam fairies would show up to help me out. I am starting to think they might not exist. What a shame that would be. Nigel 3 Link to comment Share on other sites More sharing options...
philp Posted May 26, 2015 Share Posted May 26, 2015 Ced, Couple tips when using rattle cans. I like to warm the can before spraying (got to be a score 1 in there somewhere) to help improve the flow. Just some hot water in the sink or a bowl and let the can sit in it for 5 minutes. Take out, dry and go spraying. Also, always start your spray off the model then move the can across and end up off the model again. If the paint is going to splatter it will do so right as you start to spray or when you finish. Looking good so far and definitely makes me want to dig mine out and have a go. 4 Link to comment Share on other sites More sharing options...
Nigel Heath Posted May 26, 2015 Share Posted May 26, 2015 I like to warm the can before spraying (got to be a score 1 in there somewhere) Indeed but I am not going to even try to translate what might be going on. 2 Link to comment Share on other sites More sharing options...
CedB Posted May 27, 2015 Author Share Posted May 27, 2015 Morning all! Rob it's exactly like watching paint dry! Thanks Cookie for the mask and filter advice. I'll probably need the 'large' (fnaar fnaar!) Thanks Sean - you don't have to be mad to read this thread, but it helps. Aeroplane? What aero... oh, right, must get on with it!! Thanks Jon and kwaterous (auto-correct wants that to be 'chatters', sorry!) Yes, we are special Thanks Nigel - "What a shame that would be" - cue 'Jaws' music. I may post pics later and ask for advice. Thanks Phil for the tips on rattle cans. I do hold it under my armpit and don't spray in the cold but great tips for an easier life! Oh, and score lots, fnaar fnaar!! OK, I'm going to take those photos and post them ASAP! 2 Link to comment Share on other sites More sharing options...
