Mike Posted April 30, 2015 Share Posted April 30, 2015 PzH2000 Update Set (for Meng)1:35 ET Model Meng continue to give us great kits, and their PzH2000 (reviewed here) was welcomed with open arms, consigning many a Revell kit to the "for trade" bins. ET Models have now created an update set that should improve the kit further, adding parts in Photo-Etch (PE) that just can't be done as finely in injection moulded styrene. Arriving in ET's usual thick polythene flat pack, with a black card back and green folded instruction sheet, you get three sheets of PE brass, plus a length of soft copper braided wire for the towing cables. A significant quantity of parts are used up in upgrading and replacing the pioneer tools and their tie-downs, with some substantial work going on, such as adding a realistic blade to the bow-saw, blades to shovels, and complete replacement of an unknown tool that features prominently on the glacis plate. The attachments are superbly detailed, and will of course require a little care in putting them together. The front deck has a number of small parts shaved off to accommodate more detailed PE assemblies, and the single part rack full of snow cleats for the tracks is replaced by an empty rack made completely from PE.Something seems to have gone awry with the instructions on my review sample, as there is no diagram depicting the various assemblies being added to the rear bulkhead, but they are shown being built up, so a little guesswork will see you right if you are similarly affected. The grating step-plates on the rear are replaced with highly detailed PE parts that are part-cut to ease construction, the handles on the rear doors are replaced (this is actually pictured). The number plate holder and convoy light assembly is completely replaced by a complex PE unit, and two square unit markers are added, although it isn't clear where. The side-skirts have all their locking handles shaved off to be replaced by PE parts too.The turret has an open-fronted basket on the starboard front, which is replaced and has tie-down straps added, with a new grill placed over the louvers on the port side. The gun mantlet cover that is a single PE part in the kit is replaced by a more detailed assembly with hinge detail, with more tie-downs added to the sides of the turret. The gunner's hatch has a new cupola added, utilising the stand-off legs from the kit part, but replacing the C-shaped rail and fixtures. The commander's hatch gets the same treatment, and the machine gun is supplied with a highly detail ammo box (with ammo) and receptacle. At the rear of the turret a large mesh basket is built up and added to the brackets on the sides, next to which are a couple of brackets and grab-handles that replace some moulded in parts.ConclusionA great set, and I'm sure that the instruction faux pas will be sorted by the time you can get the set online.Very highly recommended.As ET Model don't currently have a UK distributor that we know of, you'll be best off looking for the set on eBay using the product code, or an overseas supplier. We'll update this review as and when a UK supplier breaks cover. Review Sample courtesy of Link to comment Share on other sites More sharing options...
