goon Posted April 21, 2015 Share Posted April 21, 2015 Hi all, I've made a mess of my Spitfire's port wing, and could do with stripping some of the Hataka paint off. Will the Fairy Power Spray method and a scrub with a toothbrush allow me to just remove the area I want. Will it only work if it is enclosed in a box for a while, and will it affect the other areas of paint? If this not the best method, how would I best go about removing just a select area of paint. It's over Alclad grey primer. Cheers, Gareth Link to comment Share on other sites More sharing options...
Black Knight Posted April 21, 2015 Share Posted April 21, 2015 The FPS is best used by coating a kit and sealing it in a bag. For local areas I use meths and some cotton balls. Any alcohol will soften and remove acrylics. If the paint is freshly done it shouldn't take much to remove it. 1 Link to comment Share on other sites More sharing options...
blikkey Posted April 21, 2015 Share Posted April 21, 2015 I used Dettol to strip acrylic off before, it might work with cotton balls Link to comment Share on other sites More sharing options...
cruiserguy Posted April 21, 2015 Share Posted April 21, 2015 Hi Goon, Black Knight is right. Fairy Power Spray is great at removing acrylics. Spray on, rub off with a soft toothbrush, and rinse - paint gone. Best Wishes, Will. Link to comment Share on other sites More sharing options...
goon Posted April 21, 2015 Author Share Posted April 21, 2015 Cool, thanks for the ideas. I'm hoping to minimise the damage to other areas so need the best stuff for a localised effect and no fall out for the plastic etc. Link to comment Share on other sites More sharing options...
Stuck Posted April 22, 2015 Share Posted April 22, 2015 Just this evening by sheer mistake I found while cleaning a clear part on my current build with a Lidl optical wipe it removed the vallejo paint which had been on there for over a fortnight, havnt tried it on anything else yet but worth a go. Link to comment Share on other sites More sharing options...
