sailorboy61 Posted April 20, 2015 Share Posted April 20, 2015 Hi I've picked up the above kit and was wondering if anyone knows of the availability of r right hand drive dash? I've only received it today so not had a look how much work there is in converting whats in the box, but a ready made option might be easiest! Thanks Link to comment Share on other sites More sharing options...
richellis Posted April 22, 2015 Share Posted April 22, 2015 I don't think there are any companies that do RHD conversions for car kits, there are a few that do the 1:24 trucks, but I've never seen a car conversion. I had to do the dash in the tamiya Volvo from scratch Link to comment Share on other sites More sharing options...
sailorboy61 Posted April 27, 2015 Author Share Posted April 27, 2015 I've had a good look and don't think it will be too difficult, can get a matching cut from each side. might need a couple of platicard shims for the saw cuts. I'll ponder a bit longer before taking the plunge! Link to comment Share on other sites More sharing options...
cmatthewbacon Posted April 27, 2015 Share Posted April 27, 2015 Yeah -- I had a look at the one in the stash, and I think you're right. I think there'll need to be two main bits moved -- the binnacle area, which will replace a section switched out from the glovebox, and the much smaller elongated D-shaped panel at the end of the moulding that has the ignition key and some kind of switch in it. I think that one will flip over to go in the same position on the opposite side... bestest, M. Link to comment Share on other sites More sharing options...
