tom271282 Posted April 14, 2015 Share Posted April 14, 2015 (edited) Hello folks, Here it is the one you have undoubtedly been waiting for. In the making for over 3 years, having survived moves from Cambridge to Oxford, back to Cambridge, and finally completed here in Hong Kong. This has been a very lengthy build, some of it due to moving about, and probably most due to my own procrastination and silly mistakes. Overall it was an enjoyable build, but sometimes I lost interest when I seemed to do lots of work and no progress was being made. The work in progress is here: http://www.britmodeller.com/forums/index.php?/topic/234919457-airfix-148-canberra-raf-pr9/ however progress was so glacial that almost everyone lost interest! Anyway, the build; it’s a 1/48 scale Airfix Canberra PR9 of 1PRU RAF Wyton circa mid 80’s. What I wanted to create was something like this: http://www.airliners.net/photo/UK---Air/English-Electric-Canberra/1600302/L/&sid=e1f9a0e44ea2365c9f06358982cb3aec The kits flaws are well known, but I wanted to make it as accurate as I possibly could. This involved numerous changes and modifications plus aftermarket items to make it look right. The main effort was to remove the vast majority of the overly prominent panel lines, which you cannot see on the prototype (unless exceptionally close) due to the Canberra having a very aerodynamic fuselage. This was the most time consuming part: filling, sanding and priming and repeating until it all looked good. Canberra’s of this time look remarkably shiny and well looked after. Consequently weathering is very light indeed, mostly on the lower light grey surfaces. The kit misses several parts or models them incorrectly; consequently the other corrections and modifications are listed below: · Fill panel lines · Re-scribe underside and rudder · Fill strange lines on the rudder · Replace vortex generators on the fin · Add pairs of vortex generators on underside main wings · Add numerous pitot tubes, intakes etc. to fuselage · Add HF antenna · File down oversize upper wing surface vortex generators · Correct intakes on engine pod sides (Airfix have them on opposite sides) · Correct navigators windows · Scratch build cockpit · Re-profile base of fin · Add brake lines to main gear · Mask and spray roundels (mainly as it was impossible to get decals to conform over the VG’s) · Add fuselage strengthening plates · Add beacons · Add loads of nose weight (the total of the model is about 480g) · Strengthen main and nose-wheel axles with brass rod · Finished in Tamiya and Xtracrylic paints with Alclad varnish Aftermarket: Pavla ejection seat Masterclass PE flaps CMK (I think) wheel bays – these are superb, although I didn’t use the nose gear bay as the fuselage was together by the time I got them. Xtra Decal and Aviation Workshop transfers Well that’s about the lot, here are some pictures. I apologise for the quantity, but I have been experimenting with RAW images and a basic Canon photo editor. I hope you enjoy them. Next on the bench is the Kitty Hawk Jaguar. I’m setting a 6 month time limit on this build!! Edited April 14, 2015 by tom271282 42 Link to comment Share on other sites More sharing options...
ForestFan Posted April 14, 2015 Share Posted April 14, 2015 Now that's a beauty! All your hard work has paid off. Looks so much better with the airfix trenches filled in. Link to comment Share on other sites More sharing options...
Ingo Degenhardt Posted April 14, 2015 Share Posted April 14, 2015 3 years is a long time but it turned out very fine. Reading your correction/aftermarket list reminded me of what I did on my PR.9 - about 90% the same measures. With the resin and the nose weight it got so heavy I do not dare to take it to a model show - for fear the main gear legs might collapse if someone slightly bumped into the table. Link to comment Share on other sites More sharing options...
batcode Posted April 14, 2015 Share Posted April 14, 2015 Fantastic work looks great, very nice job on the scheme and overall ginish , some nice detail work 1 Link to comment Share on other sites More sharing options...
Janremco Posted April 14, 2015 Share Posted April 14, 2015 That is a real beauty, a work to be proud of. Link to comment Share on other sites More sharing options...
HL-10 Posted April 14, 2015 Share Posted April 14, 2015 That is lovely! Link to comment Share on other sites More sharing options...
tom271282 Posted April 18, 2015 Author Share Posted April 18, 2015 3 years is a long time but it turned out very fine. Reading your correction/aftermarket list reminded me of what I did on my PR.9 - about 90% the same measures. With the resin and the nose weight it got so heavy I do not dare to take it to a model show - for fear the main gear legs might collapse if someone slightly bumped into the table. I used araldite to fix the main gear in place, which makes it nice and secure. That coupled with brass rods to attach the hubs to the gear makes it stable enough. That said it still weighs a ton! Thank you for the few kind comments, although I build for myself its also nice to get a modicum of recognition for ones efforts. Link to comment Share on other sites More sharing options...
Strangeways Posted April 18, 2015 Share Posted April 18, 2015 That's superb. Lovely detail and finish Link to comment Share on other sites More sharing options...
burnley63 Posted April 18, 2015 Share Posted April 18, 2015 Now that was well worth the effort - simply stunning PR9 Kevin Link to comment Share on other sites More sharing options...
Gary West Posted April 18, 2015 Share Posted April 18, 2015 (edited) Canberra’s of this time look remarkably shiny and well looked after. Consequently weathering is very light indeed, I love the sound of that, someone that builds what they see. Brilliant build and this is by far the best scheme (of many) for the PR9........... Incidentally, having looked at your build thread I noticed your images showing the dreaded Blu tack oil marks - I used to get that also so I decided that one way to resolve that was to Kleer/Gloss over the firsy (Grey) coat and allow to dry before Blu Tacking - works fine that way. Edited April 18, 2015 by Gary West Link to comment Share on other sites More sharing options...
BerndM Posted April 18, 2015 Share Posted April 18, 2015 The amount of work, resulted in a sharp looking Canberra, makes me want one ! Well done Link to comment Share on other sites More sharing options...
woody37 Posted April 18, 2015 Share Posted April 18, 2015 Pure Canberra inspiration, well worth the wait to see it Tom. Incredibly neat paintwork Link to comment Share on other sites More sharing options...
TheStig Posted April 19, 2015 Share Posted April 19, 2015 That is lovely! great modelling! Link to comment Share on other sites More sharing options...
Buster213 Posted April 19, 2015 Share Posted April 19, 2015 Excellent build, Last model in my 213 Squadron project stash is their final mount, the Canberra B(I)6. Impressed by your detailing so you have set the benchmark for me............ Gulp.... Super model Link to comment Share on other sites More sharing options...
exdraken Posted April 19, 2015 Share Posted April 19, 2015 nice work on a not too easy kit! Link to comment Share on other sites More sharing options...
bar side Posted April 19, 2015 Share Posted April 19, 2015 Very nice build. Built one out of the box a while back in 80s Wyton colours. Like the details on yours. Link to comment Share on other sites More sharing options...
HomerJ_757 Posted April 22, 2017 Share Posted April 22, 2017 Had the pleasure of working on that lady in those colours in the early/mid 80's just before they started changing the colour to that awful hemp with walkways on the wings. You have done her justice, thank you! Ian Link to comment Share on other sites More sharing options...
Gorby Posted April 22, 2017 Share Posted April 22, 2017 Wow! Absolutely stunning job! Link to comment Share on other sites More sharing options...
tonyot Posted April 22, 2017 Share Posted April 22, 2017 What a lovely `old school' Canberra,I love the scheme too. Cheers Tony Link to comment Share on other sites More sharing options...
RMCS Posted April 22, 2017 Share Posted April 22, 2017 Well worth the wait Link to comment Share on other sites More sharing options...
Haggis9444 Posted April 26, 2017 Share Posted April 26, 2017 (edited) That is a fantastic build of a beautiful aircraft.. Well done. Edited April 26, 2017 by Haggis9444 Link to comment Share on other sites More sharing options...
HomerJ_757 Posted April 26, 2017 Share Posted April 26, 2017 Are the black bunched panels on the underwing chaff and flare dispensers? If so, she wouldn't have had them in the mid 80's. Sorry to say that cos she looks fantastic. Link to comment Share on other sites More sharing options...
stever219 Posted April 26, 2017 Share Posted April 26, 2017 My favourite PR. 9; I was allowed to play with her for an hour or so on one of our CCF annual camps at Wyton. At the time I think she still wore 39 Squadron's winged bomb emblem on the fin. You have done her, and those who flew and maintained her and her sisters, proud. Definitely a good idea filling in those horrible trenches that Airfix covered the kit with. Link to comment Share on other sites More sharing options...
Navy Bird Posted April 26, 2017 Share Posted April 26, 2017 Very nicely done! It seems the 1:48 Airfix kit has the same amount of issues to be fixed that I had with the 1:72 version. But you tamed the beast! Cheers, Bill Link to comment Share on other sites More sharing options...
goggsy Posted April 26, 2017 Share Posted April 26, 2017 Lovely. I've built one of these and know what a sod that cockpit is to fair in so I'm impressed with your result. Link to comment Share on other sites More sharing options...
