Shar2 Posted March 24, 2015 Share Posted March 24, 2015 Chance Vought F4U-1A Corsair detail Sets Eduard 1:32 The Tamiya 1:32 Corsair F4U-1A is a fantastic model straight out of the box as are all of this series of 1:32 kits, but there are always more ways to gild the lily. This is Eduard come in with their range of update sets for it, six in fact if you include the zoom and mask sets, and there’ll probably be joined by others in the near future. Each set is held in the usual poly sleeve packaging with a card insert to prevent damage, and the instructions still leave a lot to be desired. Typically some of the kit details need to be removed before the brass parts can be added.Interior Set (32828)Contained on two sheets of relief etched brass, the larger one is unpainted whereas the smaller one is not only pre-painted but self adhesive as well. The unpainted sheet contains items such as the rudder pedal heel and toe plates, rudder cable attachments, side console inside faces, document pockets and additional fittings not included in the kit. On the engine bulkhead there is a pair of new cable runs and pipes, whilst the foot rests/”floor” troughs are fitted with more detailed bulkhead fittings complete with lightening holes. There are a large number of instrument boxes fitted around the cockpit, on the side consoles; coaming and side walls onto which the pre-painted faces are attached. The instrument panels are also pre-painted complete with the instrument faces on the backplate. A little dab of aqua clear will give them the appearance of glass fronts. The fire extinguisher and oxygen bottles receive new straps and supports and the canopy is fitted with new frames fore and aft and latching handle. Interior Zoom Set (33144)This zoom set contains only the above pre-painted sheet and allows the modeller to build a well detailed cockpit without the hassle of getting bogged down with detail that might otherwise be deemed superfluous. Engine Set (32365)To really enhance the details on the kits engine this set provides a wealth of additional and finer parts for the job. Quite a few areas need to be cut away before the etched parts can be added, particularly around the cowling mounting bulkhead between the cylinder banks. Holes need to be drilled into the cylinder banks ready to accept the new wiring harness which is pretty complex and care will be needed as whilst the instruction diagram is better than usual, it could have been clearer. The exhaust manifold receives new flanges and jubilee style clips. Another complex area of the build is the fitting of the individual cowl flaps and cowl flap ring. Each cowl flap is fitted with a three piece etched actuator which will need a very steady hand to assemble and fit. The front cowl mounting ring is also provided as are the interior rib detail for each of the opening cowling panels. Exterior (32366)This single sheet set contains some very nice additional detail for the exterior and open areas of the kit. There are quite a few parts dedicated to the interior of the tailwheel bay, especially on the mounting bulkhead which has new mounting fixtures and fittings for the tail oleo, whilst the foreward bulkhead is fitted with new fittings which include the rudder cable arm and mounting bracket. The tailwheel bay doors are fitted with new hinges panels and attachment links.The main wheel bays also get a dose of additional detail with the fitting of new panels around the bay walls and roof along with additional cabling and pipe work. If you’re building the model with wings folded then you have the option of adding new end plates to the flaps and ailerons along with replacement brackets and web pieces. The wing fold areas have a host of new hoses and pipework fitted which will really make the areas look not only more accurate but busy. Placards (32829)This small single sheet set contains much of what is already on the interior sets pre-painted sheet and naturally the zoom set, which is rather annoying to be honest. There are a few parts different that the modeller could use in the cockpit, but not nearly enough to make this set worth being separate to the interior sets. Masks (JX176)To complement the sets mentioned above, Eduard have also released a set of paint masks for the F4U-1A, which helps masking the clear areas a whole lot easier. ConclusionAs with most of Eduards releases there are questions as to why some sets are so comprehensive yet still missing vital parts that are held back to make up other smaller sets. The placard set should be contained in the interior pack as should a set of seatbelts which will probably be released later. The quality of these sets is superb, and will certainly help to the making of a super detailed model. Highly recommended. Review sample courtesy of Link to comment Share on other sites More sharing options...
