vulcanxm603 Posted March 17, 2015 Share Posted March 17, 2015 When my 1/35 Academy Merkava II is completed I can carry on with my latest model - the Revell 1/35 SPz Puma: 1 Link to comment Share on other sites More sharing options...
vulcanxm603 Posted March 20, 2015 Author Share Posted March 20, 2015 Started work on the SPz Puma. So far some of the smaller details done on the upper hull, tracks assembled, lower hull and suspension done, part of the turret done, rear mud flaps (rubber) done, side skirts done. All sprayed in automotive under coat grey at present. Clearance to install tracks later over the upper track guides is fine. Just to be done prior to the side skirts being fitted. 2 Link to comment Share on other sites More sharing options...
HOUSTON Posted March 20, 2015 Share Posted March 20, 2015 Oooh this will be a fine armor build .. LOVE the PUMA color scheme..WAY TO GO IT ROCKS !!! Link to comment Share on other sites More sharing options...
Stesca Posted March 21, 2015 Share Posted March 21, 2015 Great stuff, never seen this one done, looking good so far. Link to comment Share on other sites More sharing options...
GForceSS Posted March 24, 2015 Share Posted March 24, 2015 I have built this kit up to the point of painting. Im wondering how to paint the gun barrel and the inside of its housing and fill the join on the outside of the box housing without messing up the inside with the finished barrel.. It wont insert later I think. Link to comment Share on other sites More sharing options...
vulcanxm603 Posted March 25, 2015 Author Share Posted March 25, 2015 I have built this kit up to the point of painting. Im wondering how to paint the gun barrel and the inside of its housing and fill the join on the outside of the box housing without messing up the inside with the finished barrel.. It wont insert later I think. There is no way the barrel can be inserted once the box housing has been assembled. I have now built and started painting the kit. With regards to the gun barrel and its box housing, I noticed the the area where the barrel shows is only painted green. Therefore I pre-sprayed the box housing and barrel prior to assembly. Once assembled I touched up the areas where the joint is using the green on a paint brush. The problem I have had with this vehicle is that the one track was a very loose fit and required some of the links to be removed. 2 Link to comment Share on other sites More sharing options...
Stesca Posted March 26, 2015 Share Posted March 26, 2015 This is coming along nicely, look forward to seeing the end product. Link to comment Share on other sites More sharing options...
vulcanxm603 Posted March 28, 2015 Author Share Posted March 28, 2015 WIP - 1/35 Revell SPz PUMA. Camo pattern now done, but still a few small details yet to be completed: ie - antenna. The blue is where the armoured windows are. Unfortunately at present this is the only blue I have in my paint selection and so it will be changed to a darker blue when I get some. Gloss clearcoat to be done, then decals installed, then the matt clearcoat. Link to comment Share on other sites More sharing options...
