PhantomBigStu Posted March 11, 2015 Share Posted March 11, 2015 (edited) Still new to this business, mostly sticking with airfix and revell kits, but some point will branch out to others would like to do a tamiya mossie at some point, But do they come with wheels options? Guessing not as it seems most kit makers tend not to aside from the airfix/revell and recent release hasegawa Edited March 11, 2015 by PhantomBigStu Link to comment Share on other sites More sharing options...
Troy Smith Posted March 11, 2015 Share Posted March 11, 2015 given the way the Mossie UC retracts, easy enough to modify. Instructions for kits are usually available online. in a rush, but what scale as well? Link to comment Share on other sites More sharing options...
PhantomBigStu Posted March 11, 2015 Author Share Posted March 11, 2015 opps 1/72 scale Link to comment Share on other sites More sharing options...
Paul J Posted March 11, 2015 Share Posted March 11, 2015 Having built a couple Tamiya Mossies, the only way to have wheels up is to omit the main undercart parts, cut off the pegs that hold the doors in place by the bay and fix the doors shut. Tail wheel can be fitted in the up position before joining fuselage halves together. Hope this helps. Link to comment Share on other sites More sharing options...
Sky Pilot Posted March 11, 2015 Share Posted March 11, 2015 (edited) I have built several Tamiya Mosquitos ( my favoured scale IS 1/48 ) mainly wheels down with a couple wheels up. If you fancy doing OOB bomb bays then go for the B Mk IV. The FBs are also interesting. Both versions look stunning when posed in flight - the stands are simple to make.. My next Mosquito build will be the Tamiya PR version. The kits go together without any problems. Go for it lad. Ooops - sorry ! Not your scale. Edited March 11, 2015 by Sky Pilot Link to comment Share on other sites More sharing options...
PhantomBigStu Posted March 12, 2015 Author Share Posted March 12, 2015 Having built a couple Tamiya Mossies, the only way to have wheels up is to omit the main undercart parts, cut off the pegs that hold the doors in place by the bay and fix the doors shut. Tail wheel can be fitted in the up position before joining fuselage halves together. Hope this helps. good point, thought it might be the case, but obviouss some planes are not so simple so good to know about the brand in general, I will be picking one up in due course Link to comment Share on other sites More sharing options...
Vanroon Posted March 13, 2015 Share Posted March 13, 2015 If you can find one, the Tamiya Seiran is a lovely build. One option is for fixed undercarriage. I like the float trainer. 1 Link to comment Share on other sites More sharing options...
dukdalf Posted March 13, 2015 Share Posted March 13, 2015 Skypilot's assertions on the 1/48 Mosquito also apply to the 1/72 version: remove the pegs and glue the u/c doors shut. Easily done and the doors will fit perfectly in their closed position. Link to comment Share on other sites More sharing options...
