Shar2 Posted March 10, 2015 Share Posted March 10, 2015 Armour Detail SetsOrangeHobby 1:35 OrangeHobby are producing a fine selection of detail sets and their ever increasing range appears to have something for every 1:35 armour modeller. The five sets reviewed here are some of their newest and include aerials, machine gun barrels and even hydraulic actuators.[G35-118-36] The first set contains a replacement 20mm cannon barrel for the Meng AMX-30B2 and consists of a simple drop in replacement for the kit part. The main barrel is turned complete with the prominent recoil spring and really does look the part. Once the separate muzzle brake is attached, complete with the drilled holes, it will make a great addition to the kit. [G35-119-48] This set contains a selection of German aerials, four long and two short and come complete with four turned brass parts that represent the rubber mounts. There appears to be a slight amount of flash on the bottom of some of the aerials which will need to be nipped off before use. The mounts are simply glued into position on the particular aerial the attached to the model via a pre drilled 0.5mm hole. As with most metal aerials these are very sharp, and care should be taken when displaying the model as anyone getting too close a look could take their eye out. [G35-120-58] This set is very similar to the previous set, only it provides a set of aerials as used on modern Russian vehicles. There are four long and two short aerials contained in the poly bag along with the two part aerial mounts. The mounts are assembled, after which they just slip on to the base of the aerial and added to the model. Unlike the German set, these aerials are completely flash free and can be used straight out of the pack. The general warning about using these aerials is as per the above set. [G35-128-58] This set provides a replacement barrel and fittings for any kits version of the NSV 12.7mm heavy machine gun, both tripod mounted, and in the AA role as fitted to tanks like the T-72, T-64 and T-80. The kit parts will need to be modified to allow the fitting of the turned brass barrel and recuperator, plus the etched nickel straps, sights and clamps. If the modification is done correctly it will make a world of difference to the standard parts found in most kits. [G35-134-48] This final set is designed to replace the pistons and actuators in the Meng D9R “Doobi” armoured bulldozer. The clever part of this set is that the turned alluminium parts are then moulded into the resin fixture rings, making them direct replacements without the need to cut or modify the existing kit parts, although the resin sections do require a bit of a clean up. The two long turned alluminium parts are again direct replacement for the kit parts and slide into the kit fittings. Overall these parts will not only give extra strength to the completed model but the metal will not need to be painted, only weathered. ConclusionAlthough these sets provide a varied selection of parts, it does show that OH aren’t just trying not to copy what a lot of other companies are releasing. The quality of the parts is very high and what with the ease of use, they should be able to be used by all but the most novice of modellers. Very highly recommended. Review sample courtesy of Orange Hobby.com Link to comment Share on other sites More sharing options...
Shermaniac Posted March 10, 2015 Share Posted March 10, 2015 I must admit, I do like the look of set [G35-134-48] for the D9 Dozer. I wonder who in the UK has them for sale? Link to comment Share on other sites More sharing options...
Mike Posted March 10, 2015 Share Posted March 10, 2015 especially the Doobi set Link to comment Share on other sites More sharing options...
Panzer Vor!!! Posted March 10, 2015 Share Posted March 10, 2015 Those aerials for my Panzers look tasty , the rubber mount looks good Link to comment Share on other sites More sharing options...
