gregax
me-163 komet (Revell + CMK) 5.10.
Me again!
Revells 1/48 Me-163 komet with CMK detail set. I am not going to use the whole lot. Here are the pics...
Extensive CMK set. (Photoetched parts not shown here)
And it fits reasonably well into the kit...
Edited by gregax
Many resin for power eggs. Just looking forward to this. Must be looking great, when finished. Good luck. Cheers
Cockpit is painted. Rlm 66 for the cockpit an Rlm 02 for the fuel tank and machine guns placements. So far so good...
Ok, some minor progress on the wings. Slats are moulded separately, but on the real thing, they didn't move but more or less served as somekind of lift aid. So it had to be glued and sanded smooth.
And I knew that something is not going to fit - tail section that is. So lots of putty and sanding... and regraving will follow. Also, that nose cone looks really strange, so I think it will need some attention as well....
Lovely workmanship! The nose cone seems to have a bit of shrinkage around it's base and I think that it is that which is making it look a bit odd. A quick fill, sand and re-scribe should sort that out.
Martin
Superb work on the cockpit.
I am havinga headache... after sorting the rear tail section, which now looks ok, i did manage to assemble the wings, the fit was pretty fine there,
but after checking the refferences, the nose seems to be completly off.
So, many layers of Squadroon Green had to be applied. It will take a while to dry, so i might start working on another kit...
Ok, nosecone is corrected, I still have to rescribe all the lost panel lines. I've also made masks and glued the landing flaps in position.
I hope I will start paiting soon...
Nice progress on the Komet.
Not the easiest of kits, despite it's diminutive size, but you're mastering it.
Karl
So, I am almost ready for some paint. But which one should I do?
What are the options to chose from?
Martin
Changing subjets a bit. Was fed up with su-27 the other day, so I took komet from the shelve and enjoyed spraying paint for an hour or so. Nothing special, RLM04 for the nose,
RLM76 for the lower portions and a RLM82 & 83 combo for the upper ones. So, decals are next on the list.
