Decalfix uses.
stevej60
Hi folks,I,m a bit gutted as while decaling an Airfix Chinook I,ve dicovered how bad the decals are! I knew the minute one of
the roundels went on they were thick,too matt and the carrier film was a milky gray,I cured the few I did by glossing/sticking
then glossing over but do not relish the thought of this for the many still to do,will Decalfix help? My son gave me a bottle
but I have never needed to use it before.
Edited by stevej60
Hi Steve. I've recently had a long battle with both Tamiya and Airfix decals and I think I found a similar problem to you in that the Airfix decals seemed quite thick and, in my case, very brittle. Any Airfix decal on a flat srface wasn't too bad although I had a few just break up in the water. I did cut away as much carrier film as possible - such as completely cutting out the code letters. If you go down this route you'll need sharp scissors and a knife as I found even a slightly rough cut was possibly the start of a tear. I cut the carrier film away from the outside of the roundels with scissors.
I did use DecalFix but it still took a long time for it to have any effect and then it wasn't brilliant. I ended up doing a lot of touching up with paint and reassembling bits of decal.
Perhaps someone else may have some ideas to help.
What ever you do try and practice with spare decals first if you have any.
Kind regards,
Stix
Edited by PlaStix
Kind regards,
Stix
Thank,s Stix I think I will go with the slower but proven glossing I have used already it,s dried fine I was worried about the large full length
starboard walkway decal but just applied it after cutting in three and it looks great.just a bit tedious!
I hung on recalling the Spitfire I recently built until I got some decalfix. Today I got some from local Hobbycraft. I watched YouTube clip on Airfix sight about how to use it. It seems to have left a shiny residue on the paint finish. Is this normal? How to I get rid of it? Decals went on brilliantly onto acrylic, brushed on, paint. Vid says it is suitable for matt finish but doesn't mention leaving residue. Do I just leave it overnight and dab off with wet tissue or do I need to add a clear (matt) varnish?
Any advice or links welcome.
Pete
Pete
Pete,was the kit glossed for decalling?
Pete
I always leave it to dry over night then wipe off the residue. I always use enamel sprayed with gloss cote though.
Just checked, after letting sponged water dry and it seems OK.
What do others do to get a matt finish after decalling?
I use Vallejo matt varnish Pete,hand brushed on 1/72 kits,sprayed on larger ones,there are a lot of products out there everyone has their faves.
I first spray on humbrol gloss cote (I find it better than klear), then apply the transfers and then finally spray over with matt cote. When you do it this way matt paint doesn't look quite as flat as it would without anything on top but it gains a certain sort of texture that I like. WW2 aircraft were generally not painted in total matt anyway, if you leave a car for example outdoors in all weathers without washing or polishing it then it will lose it's shine naturally, it was a bit like that with WW2 aircraft.
Transfers sit on a gloss finish way better than matt, plus matt paint is rather porous and can stain even with just water.
