SeanM Posted March 17, 2015 Author Share Posted March 17, 2015 8 parts per segment on the plow blade. Very small... Very complex assembly considering the size. One done! Getting the angle consistent is not going to be easy either.... Right, I better get cracking on the other 20 Link to comment Share on other sites More sharing options...
SeanM Posted March 18, 2015 Author Share Posted March 18, 2015 Change of tack on doing the blade segments: I'll attach the two plates & springs to the plow arms and the orther two plates to the back of each segment. That will leave just the connectors to connect the two pairs of plates (if that makes sense?) At least it will give me something to hold whil attaching rather than this fiddling around with 8 tiny parts trying to get them alligned and glued... However, to ensure correct allignment of the blade segments i'm going to have to get the wheels on the vehicle and the plow attached. That way I can tell of it's going to be flush with the ground. Link to comment Share on other sites More sharing options...
SeanM Posted March 26, 2015 Author Share Posted March 26, 2015 OK, the plow is not going great... I had to attach it to the vehicle to ensure the blades were at the correct angle to the ground. That in itself didn't go well and needed to surgery & repair work. Then attaching the blades has broken some of the hinges as they are so fragile. Got frustrated and left it for a few days. Noe back at it....I have to cut off the lugs on each side of the connectors which would ensure exact placement and just position them by sight and glue. Then wait for it to dry before doing the next in line....it's going to take a while... Link to comment Share on other sites More sharing options...
phildagreek Posted March 26, 2015 Share Posted March 26, 2015 Very frustrating! These things are sent to try us. Soldier on. 1 Link to comment Share on other sites More sharing options...
SeanM Posted March 26, 2015 Author Share Posted March 26, 2015 I'm not giving up....Getting there....slowly but surely! 1 Link to comment Share on other sites More sharing options...
Stesca Posted March 27, 2015 Share Posted March 27, 2015 Keep at it Sean, it will be worth it, you are going well. Link to comment Share on other sites More sharing options...
SeanM Posted March 29, 2015 Author Share Posted March 29, 2015 At last! All built and base coated. Now just to add detail and weathering.... 2 Link to comment Share on other sites More sharing options...
Stesca Posted March 30, 2015 Share Posted March 30, 2015 Oh yes looking very good now. Link to comment Share on other sites More sharing options...
SeanM Posted April 7, 2015 Author Share Posted April 7, 2015 I've not forgotten about this build....just slowed down a lot as life gets in the way. Some small bits & bobs added. The marker dispensers, jerry cans, lights, tools, tow-rope etc Soon be at the weathering step and that's the bit I keep putting off..... 1 Link to comment Share on other sites More sharing options...
Areos Posted April 7, 2015 Share Posted April 7, 2015 Very nice build! Which green have you used as green base color? Cheers Link to comment Share on other sites More sharing options...
SeanM Posted April 7, 2015 Author Share Posted April 7, 2015 Thanks Areos, the colour is Humbrol 155 Matt Olive Drab acrylic rattle can and then some parts touched up with enamel tinlet & hairy stick Link to comment Share on other sites More sharing options...
SeanM Posted April 8, 2015 Author Share Posted April 8, 2015 Started weathering the plow... Link to comment Share on other sites More sharing options...
SeanM Posted April 12, 2015 Author Share Posted April 12, 2015 Started doing the decals then just need to weather the upper half and the aeriaks, gun, mirrors, tow-bar, spare wheel and lots of stowage from the spares box and straps, lots of straps, made from Tamiya tape 2 Link to comment Share on other sites More sharing options...
phildagreek Posted April 13, 2015 Share Posted April 13, 2015 Looks the biz. Link to comment Share on other sites More sharing options...
SeanM Posted April 20, 2015 Author Share Posted April 20, 2015 (edited) Thanks Phil! Some slow progress on washing & weathering Now just to add all the gear, mirrors, more stowage, aerials, some packs, tow-bar, a few crates, spare wheel, some boxes and we’re done…. until the chains arrive. Still not even dispatched Edited April 20, 2015 by SeanM Link to comment Share on other sites More sharing options...
SeanM Posted April 23, 2015 Author Share Posted April 23, 2015 On the home stretch now...just have to sort out the stowage that's to be added. Been playing around with different combinations. Definitly going for the well loaded look. Lots of Value Gear and other bits from the spares boxes. 2 Link to comment Share on other sites More sharing options...
viper-30 Posted April 28, 2015 Share Posted April 28, 2015 That value gear stuff look good,and I have to say your model is really nice.got one in the stash with interior and full slats to build 1 Link to comment Share on other sites More sharing options...
SeanM Posted June 23, 2015 Author Share Posted June 23, 2015 The springs finally arrived. I can now finally finish off this baby Link to comment Share on other sites More sharing options...
SeanM Posted June 23, 2015 Author Share Posted June 23, 2015 That value gear stuff look good,and I have to say your model is really nice.got one in the stash with interior and full slats to build A full interior would be nice but I don't envy you doing all that slat in PE. I have the Bronco Bufallo with Slat on order but at least it's plastic slat Link to comment Share on other sites More sharing options...
SeanM Posted June 30, 2015 Author Share Posted June 30, 2015 Started on the springs. The small plastic U shackles that come with the original kit are very small and fragile and I kept breaking them. And the small size chain was too small so switched to a slightly larger size. (Daughter is wondering where her necklace is gone Just kidding). Got the 2 side chains on which kwwp the plow close if it gets blown off. One is slacker than the other but they are actually both the same length. That’s how fiddely they are Then started on the springs & chains in the front. Will attach all the chains to the PE at the end of each arm before fitting onto the plow. As I had no U-shackles left I opened a link at each end of the chains and fed this through the hole in the PE before closing. Very delicate work and while not exactly accurate is the best I can come up with. And then disaster strikes Don’t ask, but I think it can be recovered…. Link to comment Share on other sites More sharing options...
SeanM Posted July 3, 2015 Author Share Posted July 3, 2015 Managed to repair the damage and the springs are now fitted. The plastic U shackles provided in the kit were useless so I just opened a chain link at each end and attached them to the PE directly. Not 100% accurate, but it works for me. Just nees to touch up the paint work and paint the chains then reattach the plow to the vehicle. 1 Link to comment Share on other sites More sharing options...
SeanM Posted July 10, 2015 Author Share Posted July 10, 2015 All done and posted into Ready for inspection! Thanks for watching & commenting Gents 2 Link to comment Share on other sites More sharing options...
jgrease Posted July 10, 2015 Share Posted July 10, 2015 Great work - very fiddly-looking plow but you got the job done. 1 Link to comment Share on other sites More sharing options...
