Dads203 Posted February 1, 2015 Author Share Posted February 1, 2015 And the second part, having good ref material is vital for this build, as the instructions are not good at all. Dan 2 Link to comment Share on other sites More sharing options...
coneheadff Posted February 1, 2015 Share Posted February 1, 2015 Looking good!!! Link to comment Share on other sites More sharing options...
viper-30 Posted February 1, 2015 Share Posted February 1, 2015 Nice progress on this ive a couple in the stash including the cromwell one which has the interior. Terry Link to comment Share on other sites More sharing options...
Dads203 Posted February 1, 2015 Author Share Posted February 1, 2015 Thanks chaps, Hatch time, the section commanders hatch details, the hatch holding open clamp fitted, used some carbon fibre antenna section as the handle. The damper is damaged in the kit so will need to be sorted with plastic card and rod. And the drivers hatch, added the damper to the side. More to follow later. Cheers Dan 6 Link to comment Share on other sites More sharing options...
longshanks Posted February 1, 2015 Share Posted February 1, 2015 Good progress . . . Are you sure your not going to do the interior . . . . . Kev 1 Link to comment Share on other sites More sharing options...
Dads203 Posted February 1, 2015 Author Share Posted February 1, 2015 Good progress . . . Are you sure your not going to do the interior . . . . . Kev Very 2 Link to comment Share on other sites More sharing options...
Stesca Posted February 1, 2015 Share Posted February 1, 2015 Going very well Dan, nice work. Link to comment Share on other sites More sharing options...
Hamden Posted February 1, 2015 Share Posted February 1, 2015 Thats coming together nicely Looking forward to more of the same Roger Link to comment Share on other sites More sharing options...
Widow 65 Posted February 1, 2015 Share Posted February 1, 2015 Link to comment Share on other sites More sharing options...
Dads203 Posted February 2, 2015 Author Share Posted February 2, 2015 Track bash time, the bit I really love.... not ! Thought it best to get these out of the way so I can get the suspension set up. Cheers Dan 3 Link to comment Share on other sites More sharing options...
Dads203 Posted February 2, 2015 Author Share Posted February 2, 2015 Repairing the hatch damper, used a calibre 35 resin Nut and some plastic card. The plastic rod just needs trimming down. Cheers Dan 1 Link to comment Share on other sites More sharing options...
Dads203 Posted February 2, 2015 Author Share Posted February 2, 2015 5 minutes work. smaller nuts and bolts. Fitted. Cheers Dan 6 Link to comment Share on other sites More sharing options...
Kallisti Posted February 2, 2015 Share Posted February 2, 2015 I think I'm a bit funny as I quite enjoy the sheer mindlessness of the track assembly. I usually sit myself down in front of the telly with a 0.4 drill, wire cutter, metal file and CY dipper to do the assembly, then allow my fingers a day or two to recover 2 Link to comment Share on other sites More sharing options...
Hamden Posted February 3, 2015 Share Posted February 3, 2015 Nice save on the hatch hinge! Putting those tracks together looks just like doing the real thing! Stunning work as usual looking forward to more of the same Roger Link to comment Share on other sites More sharing options...
Dads203 Posted February 3, 2015 Author Share Posted February 3, 2015 Clansman BAE, Base Antenna Element, VHF or antenna pot as we called them. I've added the antenna holder from plastic rod, drilled out the centre so that I can add a Carbon Fibre Antenna (2M Whip) and added the wing nut clamp. Bronco wingnuts, nice little items. Enjoy Dan 7 Link to comment Share on other sites More sharing options...
Wogga Posted February 3, 2015 Share Posted February 3, 2015 Great work Dan and thanks for showing us your extra parts, that's my Chieftan side plates fixing bolts sorted and I have a job for the wing nuts . Link to comment Share on other sites More sharing options...
Dads203 Posted February 3, 2015 Author Share Posted February 3, 2015 Great work Dan and thanks for showing us your extra parts, that's my Chieftan side plates fixing bolts sorted and I have a job for the wing nuts . They are exactly what I used for the side skirts on the Chieftain mate, glade the pictures of the bits n bobs I use are a help :-) 1 Link to comment Share on other sites More sharing options...
Wogga Posted February 3, 2015 Share Posted February 3, 2015 Just got to find the suppliers Dan, it's proving difficult and when I find one there is no stock! Link to comment Share on other sites More sharing options...
Richard E Posted February 4, 2015 Share Posted February 4, 2015 (edited) Just got to find the suppliers Dan, it's proving difficult and when I find one there is no stock! I've found some listed on Ebay - just search for "Bronco 1/35 wing nuts" and select UK only. HTH Edited February 4, 2015 by Richard E 1 Link to comment Share on other sites More sharing options...
coneheadff Posted February 4, 2015 Share Posted February 4, 2015 That is great! Thanks for sharing, Dan! Link to comment Share on other sites More sharing options...
Dads203 Posted February 4, 2015 Author Share Posted February 4, 2015 I think the caliber 35 nuts and bolts are OOP now, I've had mine for a year or two, pretty sure if you look At online stores like Historex you'll find some close enough. Dan 1 Link to comment Share on other sites More sharing options...
Niall Posted February 4, 2015 Share Posted February 4, 2015 Meng do a number of different sizes of nuts and bolts - http://www.modelhobbies.co.uk/shop/plastic-model-kits-military-model-kits-c-27_32.html?page=1&filter_id=439 Link to comment Share on other sites More sharing options...
Wogga Posted February 4, 2015 Share Posted February 4, 2015 I've found some listed on Ebay - just search for "Bronco 1/35 wing nuts" and select UK only. HTH Spotted and ordered many thanks, now for the nuts and boltscalibre 35 lives on.... Hopefully http://www.modelchoice.net/catalogue/afv/afv-accessories/?showPage=2 Link to comment Share on other sites More sharing options...
Dads203 Posted February 5, 2015 Author Share Posted February 5, 2015 Not much going on at the moment, more track done and now the clean up of the running gear. Work is really getting in the way of the build at the moment so I apologise for the slow updates. One problem I have found is the Fruil tracks have a different pitch to the AA Spartan sprockets, these will need modifying to fit correctly, no biggie but a pain. Still they were made for the AFV club Scimitar/Scorpion. Road wheels are now glued and any marks filled using Mr Dissolved Putty. Swing Arms filled. More hopefully later Dan 4 Link to comment Share on other sites More sharing options...
Kallisti Posted February 5, 2015 Share Posted February 5, 2015 Is there a difference between the Spartan and Scimitar/Scorpion tracks then? I remember having a problem getting them to fit on my Scimitar 2 but I solved it simply by chopping off the sprocket tabs which didn't match the track holes - its very difficult to see them anyway once the tracks are on. 1 Link to comment Share on other sites More sharing options...
