Ki-45 Kai Koh Toryu 'Nick' (1/48th Hasegawa)
Started today - Ki-45 'Nick' from Hasegawa - this is a limited edition boxing with a special scheme
Lots of nice details in the cockpit for OOB, as is normal for Hasegawa
Laid down a base coat of Gunze Khaki thinned with Mr Levelling Thinners by 50% so that it sprays in very thin layers.
Picked out the details on the control column, using Vallejo Model colours, and a light oil wash
Picked out the base details in the cockpit, once again with Vallejo Model colour
Drybrushed the Instrument panel with white, then a black oil wash. Then used some Ammo Crystal Colour in the instruments, and pick out some of the switches. Followed by a light brown oil wash to start dirtying the whole cockpit.
Same procedure on the Radio, with the Liferaft painted Olive Drab, and the spare cannon magazine Gunmetal.
Finally picked out the details on the fuselage sides and gave a brown oil wash.
Peter
Today's work - first completed the weathering in the cockpit - added some chipping with a Prismacolor pencil, some dirt with pigments, and some fuel stains around the filler cap.
Then joined the fuselage together - given that this is the fuselage halves, the cockpit, 2 insets and the bulkheads it required some 'help' to stay in place while the glue was drying.
Then on to assembling the nose section.
The gunner's position
Being an inset on a Hasegawa kit, it needed some Mr Surfacer to blend the nose in.
Build up the Nacelles - again insets abound, which makes this slightly tougher than normal.
Rubbed back the Mr Surfacer with a cotton bud moistened with IPA
Weathered down the Nacelle interiours with 'Engine Grime' and 'Engine Oil'
Fitted the wings - was left with a small gap, which was filled with Vallejo Plastic putty.
Finally fit the tailplanes and rudder mass balances, and run some Mr Surfacer 1000 along the upper wing roots.
Peter
looking good ! what an elegant airplane.
I have a Nichimo ( or two..) on my shelves waiting for a destiny.
I guess the Hasegawa is better in some details according to your work.
nice work so far.
olivier
Today's work - started with the Engines. First a coat of Alclad Steel, drybrushed with Metalcote Aluminium mixed with Raw Umber oil, Copper and silver on the ignition harness, and Neutral Grey on the crank case. Finally a wash of Mig Engine Grease
Then made up the cowlings, sprayed the inside with the Khaki interior colour and fitted the engines
Masked the canopies with Parafilm and fitted using GS-Hypo cement
Masked off the gunner's position with Blu-tac
Finally - chose a scheme, i'll be doing this one
Peter
Today - Paint
First, Alclad grey Primer over the top of everything - a couple of touch ups with Mr Surfacer, but nothing major.
Preshading with thinned Black
Sprayed the Grey Green XF76
Finally spots - XF13 Green
Well that was a fun relaxing 2 hours of green spots :hypnotised:
Peter
Today - First a coat of Klear over the top of the cammo
While that was drying, made up all the parts for the Props and Undercarriage and Painted them.
Then the decals. Typical Hasegawa decals, thick, and quite brittle. Set down reasonably well with Mr Softner and Mr Setter, but did need to use some DACO Medium setting solution on the Hinoramu to get them to settle properly. Then another coat of Klear over the top to draw them down and protect them ready for weathering tomorrow.
Peter
Did a bit more today - first assembled the undercarraige
Then an oil wash - Mig Neutral Wash over everything, with some Mig Dark Wash over the control surfaces for some variation
Wiped the wash back with a little white spirit on a tissue
Finally sprayed a matt coat over the top, after fitting the Guns
Peter
