Remodel_Remake Posted January 23, 2015 Share Posted January 23, 2015 Hi Folks Just a quick question, when you add W&N Galeria Retarder to paints like xtracrylic or vallejo for spraying is it just a couple of drops or is there a ratio to be considered? Never used it before, but I've heard it recommended quite a bit. Cheers E Link to comment Share on other sites More sharing options...
Greenshirt Posted January 23, 2015 Share Posted January 23, 2015 I'll check tonight, when I can verify my recipe, but I believe it's 20-1 water-retarder. I put a drop or three in a milk lid and dip my brush as needed. For airbrushing I put a drop in the paint bowl and mix with the thinned paint. Works good with both Humbrol's and Vallejo's acrylics. Tim Link to comment Share on other sites More sharing options...
Phil Podmore Posted January 23, 2015 Share Posted January 23, 2015 Just a few drops in the cup works well for me Link to comment Share on other sites More sharing options...
fingers Posted January 23, 2015 Share Posted January 23, 2015 I'll check tonight, when I can verify my recipe, but I believe it's 20-1 water-retarder. I put a drop or three in a milk lid and dip my brush as needed. For airbrushing I put a drop in the paint bowl and mix with the thinned paint. Works good with both Humbrol's and Vallejo's acrylics. Tim 20 to 1 sounds about right, too much and you can get strife. It's good stuff a 250ml pot lasts a long time. I've used it with Revell aqua as well as those already mentioned without problems. Link to comment Share on other sites More sharing options...
Greenshirt Posted January 26, 2015 Share Posted January 26, 2015 Yep, 20-1 per the label. Tim Link to comment Share on other sites More sharing options...
kev67 Posted January 26, 2015 Share Posted January 26, 2015 Just a small drop would be sufficient Link to comment Share on other sites More sharing options...
