brewerjerry Posted October 26, 2014 Share Posted October 26, 2014 (edited) Hi Decided on doing typhoon ZH-L, JP906, 15 october 1943, 266 squadron, harrowbeer. Would it be three blade prop, small tailplane, fishplates ? Type of cannon barrels ? Cardoor or bubbletop ? Cheers Jerry Edited October 26, 2014 by brewerjerry Link to comment Share on other sites More sharing options...
ben_m Posted October 26, 2014 Share Posted October 26, 2014 Hi Jerry, My guess is: Three blade cardoor, but no aerial through it, as whip aerial used instead (same as bubbletop one) Fully faired exhausts (the fairing with skirt) Full cannon fairings Fishplates Small tailplanes Sky spinner and tail band Typhoon id stripes under wings No yellow band on upper wings No rockets 250 or 500 lb bombs, with rack in early, slightly inboard position Both landing lights in wing leading edge. Link to comment Share on other sites More sharing options...
ben_m Posted October 26, 2014 Share Posted October 26, 2014 Other small things: Two cockpit vents on port side. Probably had original tailwheel, not the anti-shimmy one (not sure when they were introduced actually) Gun camera on starboard side of radiator fairing (earlier cardoors had it in the wing) Blade IFF antenna (forget the proper code name) under fuselage Link to comment Share on other sites More sharing options...
brewerjerry Posted October 26, 2014 Author Share Posted October 26, 2014 hi Many thanks for the replies, ideal, so it seems the only parts i need to make, seem to be exhausts and maybe a tail wheel. And of course a canopy which i will try to do first. Cheers Jerry Link to comment Share on other sites More sharing options...
ben_m Posted October 26, 2014 Share Posted October 26, 2014 I'm sure the kit includes three types of exhausts- unfaired, full fairing and the unskirted fairing.The cardoor canopy also needs a smaller cutout under the windscreen, so some filling of the deck in front of the windscreen will be needed. It'll also need a triangular head armour piecepiece, and other bits under the canopy. Link to comment Share on other sites More sharing options...
brewerjerry Posted October 26, 2014 Author Share Posted October 26, 2014 Thanks again I will check the box after brekkies :-) Jerry Link to comment Share on other sites More sharing options...
Chris Thomas Posted October 26, 2014 Share Posted October 26, 2014 Hi Jerry Ben ha spec'ed the Typhoon correctly but if you want a photo you'll find one in Osprey Ace no. 27, and a profile. Drop me a pm with your email as I think I have another ref I can send. Chris Link to comment Share on other sites More sharing options...
