Peter Marshall Posted October 18, 2014 Share Posted October 18, 2014 Started today the Dragon Tiger And some Fruilmetal Tracks Then followed a full day of drill, pin, glue - repeat....... At least that's over with..... Peter 3 Link to comment Share on other sites More sharing options...
Matt182 Posted October 18, 2014 Share Posted October 18, 2014 Nice start on the tracks. Watching with interest. What's your plan for the zimmiert? Link to comment Share on other sites More sharing options...
PlaStix Posted October 18, 2014 Share Posted October 18, 2014 Great stuff - I'm interested in Tigers since building my 1/72 version. I shall follow this with interest. Those tracks do look rather good - not sure I'd have the patience though. Link to comment Share on other sites More sharing options...
Ozzy Posted October 18, 2014 Share Posted October 18, 2014 Nice start, can't wait to see how it turns out. Link to comment Share on other sites More sharing options...
HL-10 Posted October 19, 2014 Share Posted October 19, 2014 Link to comment Share on other sites More sharing options...
snapper_city Posted October 19, 2014 Share Posted October 19, 2014 Good job Peter. I have found doing all the drilling in one hit. Then the flash clean up. Then construction. It seems a lot quicker to me not having to switch tools all the time and I can get into a better rhythm. 5 cents worth. Looking forward to seeing this come together. 1 Link to comment Share on other sites More sharing options...
Parabat Posted October 19, 2014 Share Posted October 19, 2014 You don't muck about! Those tracks are lovely, well worth the effort IMO. Link to comment Share on other sites More sharing options...
andygif290368 Posted October 19, 2014 Share Posted October 19, 2014 Did you make up both packets completely? They'll be way too long if you did, see my mid prod version thread. http://www.britmodeller.com/forums/index.php?/topic/234962694-tamiya-tiger-tank-mid-production/?p=1675120 Link to comment Share on other sites More sharing options...
Peter Marshall Posted October 19, 2014 Author Share Posted October 19, 2014 Did you make up both packets completely? They'll be way too long if you did, see my mid prod version thread. http://www.britmodeller.com/forums/index.php?/topic/234962694-tamiya-tiger-tank-mid-production/?p=1675120 Made up 96 links per side - same as the DS tracks, so should be pretty close - if not it's easy to remove links if required. Link to comment Share on other sites More sharing options...
Peter Marshall Posted October 19, 2014 Author Share Posted October 19, 2014 Right - today's work. First started with the chemical processing of the tracks - used Gun Blue - nasty stuff but works well, after degreasing the tracks. Then adding all the torsion bars for the suspension, glued the ends with CA to lock the interior ends solidly. Then made and tidied up all of the road wheels, idlers and drive sprockets Then dry fitted the wheels, and sprockets and tested the tracks. Looks like the 96 links wasn't a bad guess, as the return idler is at the maximum tension set. Peter 1 Link to comment Share on other sites More sharing options...
Parabat Posted October 19, 2014 Share Posted October 19, 2014 That's looking great. Link to comment Share on other sites More sharing options...
snapper_city Posted October 19, 2014 Share Posted October 19, 2014 Looking good. I finished assembling one side of my M113 tracks this evening. The kit rubber band style have 69 links but I only required 62. Strange... Looking forward to next update. IMG_4327 by Snapper_city, on Flickr 1 Link to comment Share on other sites More sharing options...
Peter Marshall Posted October 25, 2014 Author Share Posted October 25, 2014 More done today - first started with the exhausts and rear plate. Then the radiators and fans, and added into the main hull Finally for the day, I fitted the main engine deck, and the glacis plate. Still a lot of bits to add to the deck. Peter Link to comment Share on other sites More sharing options...
Peter Marshall Posted October 26, 2014 Author Share Posted October 26, 2014 Today's work - first added the tools and the tow cables Then built up the turret Next weekend - Zimmerit ...... Peter 2 Link to comment Share on other sites More sharing options...
Ozzy Posted October 26, 2014 Share Posted October 26, 2014 Looks good so far, what are you going to use for the zimmerit? I used the Tamiya's self adisive sheet, there was a little bit of size difference in some areas but nothing a sharp craft knife couldn't sort out. And it's transparent, which is good to see the holes that are required. Link to comment Share on other sites More sharing options...
Peter Marshall Posted November 1, 2014 Author Share Posted November 1, 2014 Today's work brought to you by Apoxie putty, a sheet of acrylic and acrylic rod, and Trumpeter Zimmerit tools. Mix the putty, then roll with lots of talc to stop it sticking, then use some Tamiya extra thin on the plastic, and place the putty sheet. Press down, trim the edges then apply the pattern with the tools. Not too tricky, but just takes ages....... Just need to wait for the putty to cure overnight now. Peter 1 Link to comment Share on other sites More sharing options...
andygif290368 Posted November 1, 2014 Share Posted November 1, 2014 The exhaust shrouds probably would not have zim applied to them, they were only relatively thin sheet metal. 1 Link to comment Share on other sites More sharing options...
Ozzy Posted November 1, 2014 Share Posted November 1, 2014 Wow, Zimmermitastik, nice job, your braver than I sir. Like Andy said, I can recall seeing any zimmermit on exhaust shrouds. But looks good non the less. Cheers ozzy Link to comment Share on other sites More sharing options...
Peter Marshall Posted November 2, 2014 Author Share Posted November 2, 2014 Today's work - first added the other cable, along with the truly horrible PE hangers. Then sprayed everything with Alclad Grey Primer Including all of the wheels Then sprayed everything with a basecoat of Ammo Dunkengelb Ausf 44. Not had a problem with the Ammo paint, just add a couple of drops of thinner, and spray in light coats. Peter 3 Link to comment Share on other sites More sharing options...
PlaStix Posted November 5, 2014 Share Posted November 5, 2014 Peter that is stunning!! I don't know how you have the patience to do that zimmeriit! I have had an idea for a Tiger kit I'd like to build but I've made sure there's a PE zimmeriit set available. I'm very impressed with yours. Well done. Link to comment Share on other sites More sharing options...
Peter Marshall Posted November 7, 2014 Author Share Posted November 7, 2014 Got the day off, so got some more done First sprayed the Olivegrun Then the Rotbraun Then finally a coat of klear over the top. Peter 1 Link to comment Share on other sites More sharing options...
Ozzy Posted November 7, 2014 Share Posted November 7, 2014 Looking good, how did the mig paints go through you airbrush? Link to comment Share on other sites More sharing options...
Peter Marshall Posted November 7, 2014 Author Share Posted November 7, 2014 Looking good, how did the mig paints go through you airbrush? Fine - just add a about 10% AK / Ammo thinner and spray at 18psi - just needed to clean the tip quite frequently. Link to comment Share on other sites More sharing options...
Ozzy Posted November 7, 2014 Share Posted November 7, 2014 (edited) Peter thanks, I've been looking at the life colour or vallejo RAL paints but may give mig a go. I've been watching your build as I'm also building a dragon tiger late kit but the 6263 one, I've just got a bit left before I will paint mine, I wasn't as brave to do my own zimmermit. I've got AFV club tracks and going to try AK interactive set 00087 to make them look slightly rusty, watching your build with interest. Ozzy Edited November 7, 2014 by Ozzy Link to comment Share on other sites More sharing options...
Peter Marshall Posted November 8, 2014 Author Share Posted November 8, 2014 Done some more today - first a green filter over the top Then on with the decals, then a brown wash over the top. Slotted the wheels on to allow the wash on the wheels. Need to let all of this dry. Peter 1 Link to comment Share on other sites More sharing options...
