North American T-6G detail Set part 2. 1:32
Eduard 1:32
Last month we reviewed three etch sets for the Kittyhawk T-6 Texan HERE. Eduard have now released a fourth. This new set covers the exterior of the model and also includes a complete set of flaps.
Exterior and Landing Flaps (32354)
This single sheet set contains additional detail parts for several areas of the model. Firstly the engine is taken care of with new webs that fit between the cylinders, just below the rocker covers. There is also a new retaining ring that fits inside of the cowling; to fit this requires the removal of some internal detail from the kit part. Next area is the undercarriage bays with the installation of new bay skins for the front, rear and inside bulkheads plus a section of the bay roof. The undercarriage legs also get some treatment with replacement eye brackets and scissor link, whilst to the rear of the aircraft a new exit plate and rudder control rod, complete with control horn is fitted.
The majority of the sheet is taken up with the replacement flaps which also require much of the moulded kit detail to be removed before fitting. The flaps need to be carefully folded to achieve the correct shape around the end pieces. The central flap section looks to be the most problematical, (I know I keep saying this, but care and patience are the watchwords with this kind of assembly). To create the best possible result these parts will need to be annealed whereas you can get away without this with most of the other etched parts. The flap bays are quite simple, but will look very effective under a coat of paint.
Conclusion
With the addition of the previously reviewed sets the Kittyhawk Texan will look great; this set is really the icing on the cake. The set is as we have come to expect from Eduard, with nice relief etching and fine details. The flaps themselves look a little fiddly, but in this scale shouldn’t be too hard for those with experience of using etched parts. Highly recommended.
