SleeperService Posted September 8, 2014 Share Posted September 8, 2014 Hi All What do you use to make a female vacform mould please? I want drop tanks and similar and the guys at the dental laboratory will mould them if I make the mould. If it works then I'd like to start more complex things later. TIA Nick Link to comment Share on other sites More sharing options...
CarLos Posted September 8, 2014 Share Posted September 8, 2014 The proper material is an acrylic resin mixed with aluminium powder to dissipate the heat; But for small items plaster will do, and you can do it at home using the vacuum cleaner. Unless you are asking about the material for the master? Here you can use anything you have access to, depending also on the tools you have. I've used all sorts of wood (even balsa) finished with cyano glue or varnish, styrene, resin... Carlos Link to comment Share on other sites More sharing options...
Black Knight Posted September 8, 2014 Share Posted September 8, 2014 As Carlos says, also polymer clay, aka FIMO or Sculpey. Easily shaped, then cooked at 130 degrees, Its then [moderately] heat proof, it'll take the temperatures needed for vac forming. Link to comment Share on other sites More sharing options...
SleeperService Posted September 8, 2014 Author Share Posted September 8, 2014 Thanks for the fast and helpful replies. I'll go and see them tomorrow with Chocolate hobnobs in hand to get something set up. As I work with machine tools I'm getting the master spun up in mild steel, brilliant but rather heavy for the model's undercarriage.... Link to comment Share on other sites More sharing options...
