Jabba Posted September 3, 2014 Share Posted September 3, 2014 I have recently bought some Lifecolor paints which have a UA code, but when I tried to brush paint a model they do not seem to have much colour density, and the colour of the plastic is still showing through after several coats. Showing them to a couple of colleagues at work we have come to some sort of conclusion that these paints are really meant to the used with an airbrush, which is something that I have never done. Could I continue using a brush with these paints athough it would take a month of sundays to actually cover the model with the correct density of colour, or is it the airbrush, or even worse the end of this project as I cannot find the paint colours that I want in enamels? I would be very grateful for any help. Link to comment Share on other sites More sharing options...
Mike Posted September 3, 2014 Share Posted September 3, 2014 Which ones do you have? Names and numbers would be best. Lifecolor is usually quite thick in the bottle, and when I've used it on occasion to brush paint small areas, it's always covered pretty well Link to comment Share on other sites More sharing options...
spruecutter96 Posted September 3, 2014 Share Posted September 3, 2014 Hi, Jabba. In this situation - if you have to use the paints - I would suggest you strip the old paint off, prime the model's surface completely and then paint the kit again. More hassle, it's true, but will lead to much better results. Hope this helps. Chris. Link to comment Share on other sites More sharing options...
Paolo6691 Posted September 3, 2014 Share Posted September 3, 2014 Which ones do you have? Names and numbers would be best. Lifecolor is usually quite thick in the bottle, and when I've used it on occasion to brush paint small areas, it's always covered pretty well I had the same experience of Mike, most Lifecolour colours are quite tick, and two layers are usually more than enough for even the lightest colour. Link to comment Share on other sites More sharing options...
Jabba Posted September 3, 2014 Author Share Posted September 3, 2014 (edited) The one that I have got or should I say trying to use is UA 090 FS33711 Sand. Sorry but I don't think I said that it is Acrylic. Edited September 3, 2014 by Jabba Link to comment Share on other sites More sharing options...
cruiserguy Posted September 3, 2014 Share Posted September 3, 2014 Hi Jabba, From the FS number it's a yellow, and it'll be a pig to paint. I hate brushing yellows of any shade, and the only way I have managed is using several light coats. For Lifecolor in general, I've found they cover well - whether brushing or airbrushing. However, not much help to you with this one. Good luck, and best wishes, Will Link to comment Share on other sites More sharing options...
Tim T Posted September 3, 2014 Share Posted September 3, 2014 As Will says, yellow is a total pig to paint. It's worth using white as an undercoat/primer and applying a couple of thin coats. You are not alone in struggling with this! Link to comment Share on other sites More sharing options...
Jabba Posted September 4, 2014 Author Share Posted September 4, 2014 Thanks. I have noticed that where I painted the U/C bays whte, there has been some over spill of paint (Halford spray can paint) and this has covered well with the paint. Perhaps i should have sprayed the whole aircraft. I will carry on with more light coats. Link to comment Share on other sites More sharing options...
