nimrod54 Posted September 2, 2014 Share Posted September 2, 2014 I hope I am asking this question in the right place. I am in the final stages of completing a 120mm Verlinden figure of a Prussian Hussar and the time has come to add the kit supplied lead foil that is used to represent the leather straps for the sabretache. I am concerned that the paint may come off when I add and shape it to the figure. I will prime it first but I am not sure which is the best primer to use, would any primer suitable for metal be OK? I hope that someone can help. Many thanks Link to comment Share on other sites More sharing options...
pigsty Posted September 2, 2014 Share Posted September 2, 2014 It's always a possibility, and primer can come off too. Can you shape the foil without attaching it, then paint it, then attach it? That would minimise the final bending. Link to comment Share on other sites More sharing options...
hendie Posted September 3, 2014 Share Posted September 3, 2014 I always use etch primer when priming metal parts - it etches itself into the metal and adheres better than standard primer Link to comment Share on other sites More sharing options...
nimrod54 Posted September 3, 2014 Author Share Posted September 3, 2014 It's always a possibility, and primer can come off too. Can you shape the foil without attaching it, then paint it, then attach it? That would minimise the final bending. I always use etch primer when priming metal parts - it etches itself into the metal and adheres better than standard primer Cheers guys, thanks for taking the time to respond. I think that I'll give Hendie's suggestion of etch primer a go first, mainly because I am too far down the line with the figure and it would mean a tricky masking job. In the end I might have no alternative but to mask and paint it on the model, but hopefuly not. Thanks to you both again. Link to comment Share on other sites More sharing options...
