Shar2 Posted August 16, 2014 Share Posted August 16, 2014 DKM Bismarck Detail Sets 1:200 CMK The big Trumpeter 1:200 kit of the DKM battleship Bismarck has already seen attention from the big detail set manufacturers. Whilst they all appear excellent sets they sometimes don’t go far enough. This is where CMKs Maritime Line comes in. They have released nine packs of detail parts to provide additional detail to the big sets. There is only minor overlap, but even then CMK have given the modeller a choice on how much or little they would like to add. Each set consist of finely detailed resin parts, with the exception of one, in which there are also some beautifully turned brass barrels for the main guns. The way each set has been moulded means that there is minimal clean up required after the removal from the moulding blocks and for some the modeller doesn’t have to do anything other than paint and fit. Each set comes in either a blister pack or ziplock bag with a card header.The largest of all the sets, the Primary Armament set, (NS019) contains the turned brass barrels mentioned above, which in this scale are really quite impressive. Along with the barrels, the kit also contains the individual blast bags for each gun, with nicely moulded canvas folds, and the six rangefinders which were fitted to Bruno, Caesar, and Dora Turrets. The rangefinders originally fitted to Anton Turret were removed due to damage by heavy seas, so check your references, particularly in relation to the date for which the model is being built. Each rangefinder is deeply indented, allowing the actual rangefinder optical face to be seen. Also included is a small fret of etched nickel which contains the rangefinders protective/armoured doors. If you have turned barrels already, as they are included in a couple of the big detail sets then you might just want to buy the blast bags and/or rangefinders separately. Well, CMK have thought of this, and released two further sets with each of these items, Rangefinders, (NS021) and Blast Bags, (NS012). This also allows the modeller to get hold of the extra pair of rangefinders if an earlier build is attempted, of course you will end up with two pairs for the spares box this way. This set does also include the parts that are required for the two secondary armament turrets though. Again and etched sheet is included for the doors. Talking of the secondary armament, set (NS013) provides the blast bags for each of the twelve 150mm guns fitted to the six turrets. Each is nicely detailed with scale folds and the slight sag that each bag had.Making the whole model even more detailed, it’s the small items that can make the difference. To this end CMK have released two sets that comprise of parts to make up just the ships 2 x 8m, (NS014), and 2 x 6m, (NS015), cutters. Each boat has separate hull and gunwhales/thwarts and there are twenty one separate oars to fit them out with. Unusually the rudders aren’t included, but in the instructions the modeller is advised to use the Trumpeter kit part. In addition to the more obvious items CMK have also included a set of paravanes, (NS016). Each paravane, of which there are eight, is detailed up with etched nickel parts, some of which, even in this scale are very small, so care should be taken when cutting out and handling. As an aside, this set also includes ten liferings, which are moulded integrally with their brackets and just require painting before being fitted into position. The last of the ships sets, (NS017), contains nine hose drums with covers, 5 small and 4 large. The drum supports are made of etched nickel with the smaller drums supports being bipods whilst the large are tripod style. The covers are, as per the blast bags, nicely creased, and as such, suitable shading with really make them stand out. The last set is probably going to be the most popular as it contains the parts for two Arado 196 floatplanes. Each resin fuselage comes with separate outer wings, allowing them to be displayed folded, thus being able to be fitted in the hangers. The wings have the appropriate flaps and trailing edge sections moulded in the folded positions. The set also includes clear resin canopies, but, perhaps fortunately, no interiors, which, given these “models” will be displayed in the hanger may not be so important. The windscreens, floats, struts etc all come from the kit parts. Even though the blister pack gives the parts quite a lot of protection, the rudder on one of the review samples had broken off, but since it’s a clean break it will be pretty easy to repair. ConclusionCMK have done a fair few items for the maritime modeller and it’s great to see them release these sets, especially as they given even more options to the big Bismarck builder. The mouldings are very well mastered and will look great painted up and suitably weathered/shaded. Used in conjunction with the big etched sets they will be like adding the cherry on top of an already fabulous cake. Highly recommended. Review sample courtesy of Link to comment Share on other sites More sharing options...
Guest Posted August 17, 2014 Share Posted August 17, 2014 Very impressive,I bought a 1/200 Sovermenny with all the bits for a raining day and its big enough,these battleships are just huge. Link to comment Share on other sites More sharing options...
