waylander Posted August 3, 2014 Share Posted August 3, 2014 whats the unpainted colour of a t62 hull? im going to make the tamiya model in the next few days and want to try painting it very rsty using the salt chipping method Link to comment Share on other sites More sharing options...
Jeff Leiby Posted August 15, 2014 Share Posted August 15, 2014 What area do you consider unpainted? The underside of the hull is factory painted but does suffer heavy wear. Because of the constant wear, particularly in muddy terrain the rust is minimal as it is sanded off. Jeff Link to comment Share on other sites More sharing options...
Sgt.Squarehead Posted August 15, 2014 Share Posted August 15, 2014 Something like this: Link to comment Share on other sites More sharing options...
Jeff Leiby Posted August 23, 2014 Share Posted August 23, 2014 The added armor plates under the drivers position appear to be "after market" added in Afghanistan and to be painted with red primer only and has started to rust. As is visible in your picture the bottom of the hull was originally painted a the factory with color worn off at the rear under the engine compartment. I would recommend a dark metallic color if you want exposed unpainted surface....pre-rust. Look at the blade of a used bulldozer for the dark bare metal, not the fresh shiny metal from recent use. Hope this helps. Jeff Link to comment Share on other sites More sharing options...
