wellsprop Posted August 1, 2014 Share Posted August 1, 2014 (edited) Well I got back from my hols in Turkey at 3AM this morning and (after a decent amount of sleep) I started work on a new project - Revell's 1/72 Spitfire V (plus conversion kitbash).I'm going to build ES127 seen here,Fuselage halves together and front cockpit addedFront cockpitInternal constructionBrianthemodeller kindly donated a couple Spit props and spinners from the Airfix kits and also an oil cooler, I removed the bad Revell one and installed the Airfix partI drilled out the opening to the oil cooler to make it look less industrial and more akin to realityThe wings have been put on and the Airfix Mk V trop radiator added (the Revell nose is too wide so it will take a lot of sanding and filing to sort this out). More to follow...Ben Edited August 10, 2014 by wellsprop 4 Link to comment Share on other sites More sharing options...
woody37 Posted August 2, 2014 Share Posted August 2, 2014 Now this is a bit different, great choice. As much as I'd love to fly in a spitfire, being offered that front seat would make me think a little bit!!! Link to comment Share on other sites More sharing options...
nimrod54 Posted August 2, 2014 Share Posted August 2, 2014 Great start, I look forward to seeing more. Link to comment Share on other sites More sharing options...
jean Posted August 2, 2014 Share Posted August 2, 2014 A brave undertaking, to say the least, and I am sure the end result will be great. I have built the Promodeller Spit V, which I believe is the same as the Revell one, and beside the oil crummy cooler that you changed, there was no gull wing effect on the wing underside. Are you going to address that problem? Keep on with it! JR Link to comment Share on other sites More sharing options...
wellsprop Posted August 2, 2014 Author Share Posted August 2, 2014 A brave undertaking, to say the least, and I am sure the end result will be great. I have built the Promodeller Spit V, which I believe is the same as the Revell one, and beside the oil crummy cooler that you changed, there was no gull wing effect on the wing underside. Are you going to address that problem? Keep on with it! JR Hey Jean, I'm only addressing the kits main issues, being the awful prop and spinner, poor exhausts and poor oil cooler. The lack of gull wing is of little concern to me as it will not be visible because I will present the model the right way up without a mirror beneath. I've had very few difficulties with the build so far as all I'm really doing is cutting a hole in the top and adding a large air filter More progress; It looks ok after the first fill and sand (then primed). Next job is to put another, thinner, layer of filler over then use fine grit and wet amd dry to acheive what should be the final finish. Now back to the housework (preparing to sell and move), Ben 3 Link to comment Share on other sites More sharing options...
wellsprop Posted August 2, 2014 Author Share Posted August 2, 2014 Worth a read 2 Link to comment Share on other sites More sharing options...
wellsprop Posted August 3, 2014 Author Share Posted August 3, 2014 (edited) I have the front and middle section for the canopy in clear plastic (from the spares box) so I cut off the rear section of revells canopy, sanded it before usign it as a master to plunge mold a nice thin canopy. POLL; I have already attatched the elevators, however, I might remove them and drop the control surfaces, what do you think? Ben Edited August 3, 2014 by wellsprop 1 Link to comment Share on other sites More sharing options...
Mitch K Posted August 3, 2014 Share Posted August 3, 2014 You could leave it. It's not as if it needs anything much more to make it stand out from the run of the mill crowd of other Spitfires Link to comment Share on other sites More sharing options...
wellsprop Posted August 3, 2014 Author Share Posted August 3, 2014 You could leave it. It's not as if it needs anything much more to make it stand out from the run of the mill crowd of other Spitfires Cheers Mitch, I think I'm going to put it in a diorama, but we have yet to see that far. Most Spits seen parked with the canopies open tend to have deflected elevators, but I think I'll leave it as it is Ben 1 Link to comment Share on other sites More sharing options...
Black Knight Posted August 3, 2014 Share Posted August 3, 2014 If you were wanting to recreate the b&w photo, you'd need to drop elevators and deflect ailerons; but cutting now at a built airframe may cause other damage. I'd say, at this stage of the build, leave it as it is. Link to comment Share on other sites More sharing options...
wellsprop Posted August 3, 2014 Author Share Posted August 3, 2014 If you were wanting to recreate the b&w photo, you'd need to drop elevators and deflect ailerons; but cutting now at a built airframe may cause other damage. I'd say, at this stage of the build, leave it as it is. Thanks I had considered recreating the b&w photo but I want a little more freedom (hence considerign the elevator). Startign to think about a diorama now... Ben Link to comment Share on other sites More sharing options...
wellsprop Posted August 4, 2014 Author Share Posted August 4, 2014 MORE WORK! First two coats of Humbrol Dark Earth I'm off to the LMS on Thursday with the gf to; a) Buy some Middle Stone & Azure Blue, and Get a model for her to build In the mean time I'm going to start work on the prop and spinner as well as the undercarriage. Ben 3 Link to comment Share on other sites More sharing options...
HOUSTON Posted August 4, 2014 Share Posted August 4, 2014 Nice work. Link to comment Share on other sites More sharing options...
nimrod54 Posted August 5, 2014 Share Posted August 5, 2014 That's quick work wellsprop, I can't believe that you at the painting stage already. Link to comment Share on other sites More sharing options...
FalkeEins Posted August 5, 2014 Share Posted August 5, 2014 neat work Ben, what are you doing for codes ? Link to comment Share on other sites More sharing options...
wellsprop Posted August 5, 2014 Author Share Posted August 5, 2014 neat work Ben, what are you doing for codes ? I have white squadron codes OI L which are approx the same thickness and, when cut up, they'll look pretty bang on Ben Link to comment Share on other sites More sharing options...
Martian Posted August 5, 2014 Share Posted August 5, 2014 Nice work on a very unusual subject! Martin Link to comment Share on other sites More sharing options...
woody37 Posted August 5, 2014 Share Posted August 5, 2014 Quite fancy doing this in 1/48 after seeing yours. 1/72 spitfire is too small for my eyes these days! Link to comment Share on other sites More sharing options...
wellsprop Posted August 5, 2014 Author Share Posted August 5, 2014 Quite fancy doing this in 1/48 after seeing yours. 1/72 spitfire is too small for my eyes these days! I'd love to have made my Spitfire collection in 48th but lack the space or time. I think that the new Airfix Mk Vb has two sets of canopies and I'm sure it has the DH prop, so you should be able to do that... I'd love to see it! Ben Link to comment Share on other sites More sharing options...
wellsprop Posted August 7, 2014 Author Share Posted August 7, 2014 I am still alive! Went to the LMS today and managed to pick up Mid Stone paint (didn't get any Azure blue so I'll have to mix that). Anyway, I've mostly got the right pattern for the camo, just need to even out the colour coats. Ben 1 Link to comment Share on other sites More sharing options...
wellsprop Posted August 7, 2014 Author Share Posted August 7, 2014 Well thats most the painting done now. Just have to tidy up the cannons the do the u/c. Ben 4 Link to comment Share on other sites More sharing options...
Winenut Posted August 7, 2014 Share Posted August 7, 2014 Wow! Really looking good.....keep up the good work Link to comment Share on other sites More sharing options...
HOUSTON Posted August 7, 2014 Share Posted August 7, 2014 (edited) Ben, Looking very nice..very-well done I see you like To camoflage your nails too. Edited August 7, 2014 by HOUSTON Link to comment Share on other sites More sharing options...
wellsprop Posted August 8, 2014 Author Share Posted August 8, 2014 I see you like To camoflage your nails too. Means I don't need to spend ages trying to match my nail varnish to the appropriate colour chip Well the left side is finished (all except the airframe serial) The right side... Well, let's just say it isnt quite finished yet Ben 2 Link to comment Share on other sites More sharing options...
wellsprop Posted August 9, 2014 Author Share Posted August 9, 2014 Its getting there! Not too much to do, just the weathering, u/c and matt varnish spray. Ben 3 Link to comment Share on other sites More sharing options...
