Work In Progress Posted December 30, 2017 Share Posted December 30, 2017 On 29/11/2017 at 6:48 PM, Smithy said: I can still remember when I first saw the difference between a .303, .50 cal and a 20mm shell - very eye-opening. And then I saw Watanabe's illustration in actual scale of the different types of 30mm German cannon shells. It's quite sobering when you consider just how much damage such sized ammunition could do to an airframe, let alone aircrew. Slightly retro of me, but this part of the thread isn't complete without a link to this page http://quarryhs.co.uk/RAF guns.htm and this pic from about 40% of the way down From the left: .303 British; .50BMG; 20mm Hispano, and the rest are German - see article for much discussion 4 3 Link to comment Share on other sites More sharing options...
StevSmar Posted January 6, 2018 Share Posted January 6, 2018 On 2017-12-30 at 3:07 AM, Work In Progress said: Slightly retro of me, but this part of the thread isn't complete without a link to this page http://quarryhs.co.uk/RAF guns.htm and this pic from about 40% of the way down From the left: .303 British; .50BMG; 20mm Hispano, and the rest are German - see article for much discussion That's an interesting page, thanks for posting the link! Link to comment Share on other sites More sharing options...
Max Headroom Posted January 14, 2018 Share Posted January 14, 2018 Looking for a picture of a Turkish Spitfire Vc with a pointy tail, I found this......... Not seen one in those markings before. Trevor 1 Link to comment Share on other sites More sharing options...
Troy Smith Posted January 15, 2018 Share Posted January 15, 2018 4 hours ago, Max Headroom said: Not seen one in those markings before. I did post this exact picture years ago, asking if anyone knew about possible colours, I even tried emailing the Turkish air museum about the colours, as this is clearly a post war full repaint. Never got a reply, I've not found any other information about possible colour from other Turkish aircraft either. Though the thought occurs, though I have not seen it on a Tigerhead decals sheet, as they would maybe be the best bet being Turkish. 1 Link to comment Share on other sites More sharing options...
Troffa Posted January 15, 2018 Share Posted January 15, 2018 Quick Query- Hurricane Mk1 Serial P3386 was delivered to 43(F) Sqn in May 1940 and is described as the Squadron's "first Rotol Propeller Fitted Aircraft" (In Andy Saunder's Osprey book on The Fighting Cocks) Is this likely to have been a "Spitfire" Rotol type spinner/ prop or the specific Hurricane Rotol, that I understand was a later production item? (And would Quickboost 48447 be of any use in modelling this particular aircraft?) Cheers, Mark Link to comment Share on other sites More sharing options...
Troy Smith Posted January 15, 2018 Share Posted January 15, 2018 (edited) 3 hours ago, Troffa said: Is this likely to have been a "Spitfire" Rotol type spinner/ prop yes. http://www.britmodeller.com/forums/index.php?/topic/234980181-hawker-hurricane-propellers-and-spinners-a-modellers-guide/ 3 hours ago, Troffa said: (And would Quickboost 48447 be of any use in modelling this particular aircraft?) for what base kit? This says for the Italeri, all their 1/48th kits have horrible spinners, and the kit is so riddled with silly small errors I gave up counting them. http://www.britmodeller.com/forums/index.php?/topic/234935596-sea-hurricane-148-italeri/&do=findComment&comment=1390213 Also, save your money, both the old and new tool Airfix Mk.I kits come with two entire prop units, so there are oodles in spares boxes. If it is for the italeri, the nose ring is too big, so some sanding and scraping is needed. EDIT for this kit? try getting a leftover Airfix spare, and adjusting the nose ring Edited January 15, 2018 by Troy Smith 1 Link to comment Share on other sites More sharing options...
Troffa Posted January 15, 2018 Share Posted January 15, 2018 Thanks Troy, the italeri kit it is im afraid, but im going to plough on with it as my time for the hobby is so short I generally go with whats in the box and live with it. I havent built a hurricane in 1/48 and dont recall if i have an airfix example in the stash ( i have the revell rebox of the hasegawa mk2 and the hobbycraft tankbuster) but i will have a look tonight for any airfix lurking about. Cheers. Link to comment Share on other sites More sharing options...
rob Lyttle Posted January 22, 2018 Share Posted January 22, 2018 Two Hurricane airframes are catching my eye from the pages of a book. First, the original.... K5083 with a big Watt's 2-blade prop and 6 exhaust holes each side. Second, Hawker's G-AFKX, started as L1606, used for testing Rotol props and engines. Both have beautiful polished front panels. But what about the wings. Fabric covered I'm sure, but how much? No gun- bays, I'm sure. Has anybody got good info on these early Birds? Any good builds of either, on here? I got a great picture of George Bulman flying K5083 on test, wearing a Trilby hat. Link to comment Share on other sites More sharing options...
Troy Smith Posted January 23, 2018 Share Posted January 23, 2018 54 minutes ago, rob Lyttle said: Two Hurricane airframes are catching my eye from the pages of a book. First, the original.... K5083 with a big Watt's 2-blade prop and 6 exhaust holes each side. Second, Hawker's G-AFKX, started as L1606, used for testing Rotol props and engines. Both have beautiful polished front panels. But what about the wings. Fabric covered I'm sure, but how much? No gun- bays, I'm sure. Has anybody got good info on these early Birds? Any good builds of either, on here? I got a great picture of George Bulman flying K5083 on test, wearing a Trilby hat. scale? G-AFKX is a standard earlyish Mk.I except for the new prop, IIRC it had modified nose panelling for better streamlining google "G-AFKX" note this from @Graham Boak Quote Note that the nose ring is wider to match the diameter of the Rotol spinner. This also seems to have been large enough to avoid the small bumps at 5/7 o'clock on the standard nose ring. see also https://forum.keypublishing.com/showthread.php?74537-Hurricane-G-AFKX-question K5083 is the protoype, and varied in appearance during it life. Making an accurate model of this is a MAJOR undertaking. The best reference are the Arthur Bentley plans, which clearly show all the differences between K5083 and even a very early Mk.I note this has a scan if the Bentley drawings in post #7, and more from me in post #8 one point I missed, the original canopy is deeper as well. note the differences just to GAFKX above, tottaly different engine and side panels, different nose (no bumps) deeper canopy, retractable tailwheel, no rudder horn and the list goes on, no gun bays at this stage either, this is a very early pic, without the extra canopy bracing As for kits, in 1/72nd you could use the Airfix fabric wing kit for G-AFKX, I think there are decals for this. In 1/48th, a lot more work, as there is not a good fabric wing base kit, thopugh this boxing has G-AFKX decals, but not for the inwgs https://www.cybermodeler.com/hobby/kits/ca/kit_ca_4103.shtml HTH T 1 Link to comment Share on other sites More sharing options...
dogsbody Posted January 25, 2018 Share Posted January 25, 2018 While perusing the Interweb, looking for intel on the first 20 Hurricanes delivered to the RCAF, I came upon the Wikipedia entry for the Hurricane. Looking through the provided pictures, I found this one: https://en.wikipedia.org/wiki/Hawker_Hurricane#/media/File:Hawker_Hurricanes_at_Lille-Seclin_-_Royal_Air_Force_1939-1945_Fighter_Command_C460.jpg I clicked on it and got an enlarged version: I noticed the rear view mirror fitted to the upper edge of the windscreen, but inside, not outside. I've never seen this before. Anyone else see it before me? Chris 3 Link to comment Share on other sites More sharing options...
rob Lyttle Posted January 26, 2018 Share Posted January 26, 2018 47 minutes ago, dogsbody said: I noticed the rear view mirror fitted to the upper edge of the windscreen Beats me, but that is a seriously early Hurricane, isn't it? Great picture of the top of a fabric covered wing - no roundels...!? I know that the Canadians started building them from the outset, are you reading this as a Canadian plane? I'd better go and have a read through. Link to comment Share on other sites More sharing options...
stevehnz Posted January 26, 2018 Share Posted January 26, 2018 VY-P or F, possibly also R of 85 sqn pre-war. Nice photo Chris, thanks. Steve. Link to comment Share on other sites More sharing options...
Troy Smith Posted January 26, 2018 Share Posted January 26, 2018 1 hour ago, stevehnz said: VY-P or F, possibly also R of 85 sqn pre-war. not pre war, France phoney war, winter 39/40, the jpg name gives it away.. https://upload.wikimedia.org/wikipedia/commons/0/01/Hawker_Hurricanes_at_Lille-Seclin_-_Royal_Air_Force_1939-1945_Fighter_Command_C460.jpg suggest VY-B or E, as there is bar at the bottom of the letter if you look carefully (enlarge pic if need be) inspection by the King note same roundels. The mirror is a good spot Chris, also of note the plane still has an instrument venturi. again, proving that there is plenty of Hurricane information still being collated. 1 hour ago, rob Lyttle said: Great picture of the top of a fabric covered wing - no roundels...!? Odd lighting angle, look at the shadows, the outer part of the wing is overexposed,bleaching out the detail. there are example though of early Hurricanes and Spitfire with only one upper wing roundel there is a colour pic of other 3 Sq planes here cheers T Link to comment Share on other sites More sharing options...
dogsbody Posted January 26, 2018 Share Posted January 26, 2018 (edited) 2 hours ago, rob Lyttle said: Beats me, but that is a seriously early Hurricane, isn't it? Great picture of the top of a fabric covered wing - no roundels...!? I know that the Canadians started building them from the outset, are you reading this as a Canadian plane? I'd better go and have a read through. I know it wasn't one of the RCAF Hurcs. Something else linked me to the Wikipedia page on the Hurricane. I took a gander through the pics and there I found it. On enlargement, that mirror jumped right out at me. Is that a gas patch circle below the cockpit? Chris Edited January 26, 2018 by dogsbody Link to comment Share on other sites More sharing options...
stevehnz Posted January 26, 2018 Share Posted January 26, 2018 2 hours ago, Troy Smith said: not pre war, France phoney war, winter 39/40, the jpg name gives it away.. https://upload.wikimedia.org/wikipedia/commons/0/01/Hawker_Hurricanes_at_Lille-Seclin_-_Royal_Air_Force_1939-1945_Fighter_Command_C460.jpg suggest VY-B or E, as there is bar at the bottom of the letter if you look carefully (enlarge pic if need be) T Well spotted Troy, I should've seen that too, but I'll blame just finishing nights for blunting my powers of perception. Steve. Link to comment Share on other sites More sharing options...
rob Lyttle Posted January 26, 2018 Share Posted January 26, 2018 (edited) 15 hours ago, stevehnz said: VY-P or F, possibly also R of 85 sqn pre-war. Nice photo Chris, thanks I think I can see the very edge of a bottom bar on that letter. Which would rule out any of these, but could be a B or E (I think those are the only Options if that's the case) Note to self.... pay more attention, and try to keep up! Sorry about that... I Edited January 26, 2018 by rob Lyttle 1 Link to comment Share on other sites More sharing options...
fatalbert Posted January 26, 2018 Share Posted January 26, 2018 (edited) Could anyone point me in the direction of where I can get a 1/72 propeller,that is suitable for a Canadian machine without its spinner..Cheers chaps Neil Edited January 26, 2018 by fatalbert Link to comment Share on other sites More sharing options...
Max Headroom Posted January 26, 2018 Share Posted January 26, 2018 2 hours ago, fatalbert said: Could anyone point me in the direction of where I can get a 1/72 propeller,that is suitable for a Canadian machine without its spinner..Cheers chaps Neil Weren’t they C-47 derived? Trevor Link to comment Share on other sites More sharing options...
Black Knight Posted January 26, 2018 Share Posted January 26, 2018 4 hours ago, fatalbert said: Could anyone point me in the direction of where I can get a 1/72 propeller,that is suitable for a Canadian machine without its spinner..Cheers chaps Neil Narrow blade prop from a B-17 is the right size and shape Thats what I used 2 Link to comment Share on other sites More sharing options...
72modeler Posted January 26, 2018 Share Posted January 26, 2018 5 hours ago, fatalbert said: Could anyone point me in the direction of where I can get a 1/72 propeller,that is suitable for a Canadian machine without its spinner..Cheers chaps Neil From the photos linked below, it looks to me that a B-25, TBF, or A-26 prop and hub would work- a C-47 prop would have too small a diameter, I think. You might have to do some reshaping, depending upon the kit you use for the donor prop. Hope this helps. Mike http://silverhawkauthor.com/images/site_graphics/Aviation/Libarary__Archives_Canada/Hawker_Hurricane_Mk._XII_No._127_F_Sqn_Gander_NL_May_1943._MIKAN_No._3 592489.jpg https://clarencesimonsen.files.wordpress.com/2017/08/hurricane-4.jpg?w=625 1 Link to comment Share on other sites More sharing options...
fatalbert Posted January 26, 2018 Share Posted January 26, 2018 Many thanks chaps,I might have a b25 in the stash some where. Link to comment Share on other sites More sharing options...
stevehnz Posted January 27, 2018 Share Posted January 27, 2018 I've got one filed away from a Revell F4F kit that came with a Hamilton Standard prop, it looks about right to me & importantly, was being asked to absorb much the same power as the HS props on the Canadian Hurricanes. For that reason, I'd be surprised if a C-47 prop wasn't about right too. Steve. 1 Link to comment Share on other sites More sharing options...
Black Knight Posted January 27, 2018 Share Posted January 27, 2018 The main C-47, narrow B-17 and B-25 props are all the same prop http://www.enginehistory.org/Propellers/HamStd/hamstd.shtml IIRC the B-17 prop is 11 foot 7 inches diameter, the one on the Canadian Hurricanes was 11ft or 11ft 3in 1 1 Link to comment Share on other sites More sharing options...
Troy Smith Posted January 27, 2018 Share Posted January 27, 2018 11 hours ago, fatalbert said: Could anyone point me in the direction of where I can get a 1/72 propeller,that is suitable for a Canadian machine without its spinner.. some good response, but the chapmost likely to know is @airjiml2 who very knowledgeable on Canadian Hurricanes and 1/72 examples thereof. Hopefully this will alert him. I'm not that upon the Canadian Hurricanes unfortunately. 1 Link to comment Share on other sites More sharing options...
John Masters Posted January 27, 2018 Share Posted January 27, 2018 I will be building my first Hurricane in the upcoming Hawker GB. I will start with the new mould Airfix, May 1940. Has anyone built this? If so, are there any pitfalls to avoid? Is it correct OOB? Link to comment Share on other sites More sharing options...
