Madhatter Posted June 10, 2014 Share Posted June 10, 2014 hi all Any ideas where I can get small diameter clear styrene tubing from? I've done a Google search but no one does it except if I custom order some and they come in 6ft lengths which is way more than I need. Be nice if Evergreen or Plastrut did their tubes in clear. What could be a good alternative? Link to comment Share on other sites More sharing options...
Black Knight Posted June 16, 2014 Share Posted June 16, 2014 I haven't come across clear styrene tubing, but small diameter vinyl tubing is available in fishing tackle shops. Minimum inside diameter available is less than 1mm, costs about 99p for 1m. Might this do your job? For other lengths or diameters I drill out clear sprue and sometimes heat stretch it - done carefully one can get a hollow tube. But this is only good for short lengths. Link to comment Share on other sites More sharing options...
Oddball Posted June 17, 2014 Share Posted June 17, 2014 By small, how small are we talking? Certain kiddies drinks cartons have straws which are fairly clear, and they're usually only a couple of millimeters wide. Link to comment Share on other sites More sharing options...
andym Posted June 17, 2014 Share Posted June 17, 2014 As others say what diameter/size are we talking about? And remember larger sizes of styrene tube can be heat stretched to make smaller tubes. I needed some really small diameter opaque tube a couple of weeks ago and I heated the plastic handle of a cotton bud over a tea light and stretched it as you would when making stretched sprue and it worked brilliantly. HTHAndy Link to comment Share on other sites More sharing options...
Madhatter Posted June 22, 2014 Author Share Posted June 22, 2014 thanks for the suggestions guys - I'll look into that piping you get from fish shops The problem I have is I don't know the exact diameter because that part I want to replace is molded in there and I can't get my calipers in there to measure it. If I was to guess, I'd say 7-10 mm or so with a length of about 4cm MH Link to comment Share on other sites More sharing options...
