Rich F Posted May 9, 2014 Share Posted May 9, 2014 Hi everyone, My entry to the STGB will be the Revell/Hasegawa Harrier GR7/9 converted to a GR5. I first saw these back in 1990 at RAF Gutersloh when i was on summer camp with the ATC. Happy daze. Some reference material... And some goodies. I'll be using the AMRAAM conversion set for the nose. A choice of 3 seats. AMRAAM's, Pavla's and Aires. I'll probably go with the Pavla one as i think it look the most like a MB Mk.12 to me. And a couple of the aforementioned ATC Summer Camp shots... Hopefully i will be starting this one over the w/end. 4 Link to comment Share on other sites More sharing options...
Alex Gordon Posted May 9, 2014 Share Posted May 9, 2014 That's going to look soooo good in two greens! Link to comment Share on other sites More sharing options...
xffw45343tg Posted May 9, 2014 Share Posted May 9, 2014 Hi Rich. If the Aires seat is rightmost in your picture, I'd say this looks a little more realistic than the middle one (in which there are quite a few shape errors). That being said, the PEC is in the wrong place, so you can't have it all! Kirk Link to comment Share on other sites More sharing options...
heloman1 Posted May 10, 2014 Share Posted May 10, 2014 Good choice, I'll follow your build with interest. Good luck. Colin Link to comment Share on other sites More sharing options...
SaintsPhil Posted May 10, 2014 Share Posted May 10, 2014 Great to see a GR5, especially with a personal touch! On the seat issue here's some useful reading http://harriersig.org.uk/models/HarrierGR9T12MB12HSeat48thv2.pdf 1 Link to comment Share on other sites More sharing options...
Caerbannog Posted May 12, 2014 Share Posted May 12, 2014 Great! I wanted to add a 1:48 GR5 in Pegasus Test livery but found I have less time for building than I hoped so will decide later this month if I give it a try. Anyway - I will follow your entry with interest. Rene Link to comment Share on other sites More sharing options...
robvulcan Posted May 12, 2014 Share Posted May 12, 2014 Lovely stuff I do love the GR5 its my favourite MK of the 2nd Generation Harriers. (Its what I grew up with and the green scheme rocks) Link to comment Share on other sites More sharing options...
Rich F Posted May 15, 2014 Author Share Posted May 15, 2014 Thanks for the interest Guys. Re the seat, I originally was going to go with the Aires seat, but it is more like 1/72! It is quite small compared to the other 2. I can live with the inaccuracies on the Pavla one. Anyway progress has been made. First off I worked on the pit, this is a combination of Aires, Eduard and a bit of my own work! The thingies on the port side of the coaming. And the map holder on the starboard side. Almost finished! Ignore the seat, its still not finished! I decided to open up the aircon ducts. AV-8B hole filled and formation lights reduced. Blanked off the open space behind the nozzles. When i was measuring up the AMRAAM nose i noticed that it didnt match up with the panel lines on the Hasegawa kit, It was made for the Monogram kit. So i had to make the cut just forward of the the panel line, After a bit of sanding it was finally ready to match up with the resin, trying to line it up was another matter but i got there in the end. I couldnt resist a test fit of all the bits together. Oh, I forgot to mention that I'm using the Aires wheel bay aswell which was abit of a pain to get it to fit, lots of grinding going on. I'm now thinking of choosing different markings for this one, maybe 3Sqn or 233OCU, not sure yet. Cheers 3 Link to comment Share on other sites More sharing options...
Harry Lime Posted May 15, 2014 Share Posted May 15, 2014 Rich, Some nice detailing going into that pit! However, the angle of the nose looks a little off to me, it seems to come down too steeply and doesn't curve up enough on the underside. I don't know if it'd be possible, but maybe cutting along the first panel line on the plastic from the underside and inserting a wedge of plasticard might go some way to making it look less off? Regards, Mark. Link to comment Share on other sites More sharing options...
SaintsPhil Posted May 15, 2014 Share Posted May 15, 2014 Rich, I hate to say I agree with Mark, it looks a little droopy! That IP looks ace though! Link to comment Share on other sites More sharing options...
Rich F Posted May 15, 2014 Author Share Posted May 15, 2014 Mark, just been looking at few GR.5 profiles and I think your right. Out with the razor saw! Wish me luck. Thanks Link to comment Share on other sites More sharing options...
Cookenbacher Posted May 15, 2014 Share Posted May 15, 2014 Good luck! Oh, and the cockpit is amazing! Link to comment Share on other sites More sharing options...
Harry Lime Posted May 15, 2014 Share Posted May 15, 2014 Mark, just been looking at few GR.5 profiles and I think your right. Out with the razor saw! Wish me luck. Thanks Good Luck! Keeping my fingers crossed it all works out coz I really want to see a green GR5 in the gallery! Mark. Link to comment Share on other sites More sharing options...
xffw45343tg Posted May 16, 2014 Share Posted May 16, 2014 Blimey - demist tubes and bleed air ducts!! Fabulous stuff! Love the GR5 IP and moving map; you should make a master and see if Ian at Heritage is interested. The little indent near the base of the central pedestal just allows for clearance on the control column and is grey. Dunno if it is moulded on the resin but the GR5 version of the Mk.12 seat does not have the box on the RH upper seat pan (it's for Night Vision Goggle separation) or the (tiny) leg retract line release lever aft of the height adjustment switch on the left hand outboard "leg" of the pan. Kirk PS/ The nose extension piece aft of the nosecone ahead of the bulkhead is actually a continuous part of the skin; don't be fooled into leaving a panel line. Link to comment Share on other sites More sharing options...
Speedman Posted June 3, 2014 Share Posted June 3, 2014 The pit looks great, can't wait to see this progress. Link to comment Share on other sites More sharing options...
Rich F Posted June 5, 2014 Author Share Posted June 5, 2014 Ok, a little progress has been made and i mean a little. Nose has been 'adjusted'. I razor sawed along the panel line then put a little wedge of styrene between the cut then filled the rest with liquid styrene. Whilst this was drying I decided to join the front fuselage together. This was when disater struck, when clamped the halves together i ran some thin superglue in the gaps. Job well done or so i thought. Little did i know that the sides of the fuselage were so thin from sanding that a tiny crack had appeared when i put the clamp in place, yes you've guessed it. When i tried to remove the clamp it was stuck to the plastic, I plucked up the courage and pulled it away, luckily the damage was minimal, nothing a little Mr Surfacer 500 couldn't fix. Anyway this how the nose looks now, much better me thinks. You can see where I've filled and the tiny crack running down to the front U/C bay! Hopefully that's it for the horror stories and I can move this along now... Cheers 2 Link to comment Share on other sites More sharing options...
xffw45343tg Posted June 5, 2014 Share Posted June 5, 2014 Nice recovery. That nose angle is looking much more convincing now. Link to comment Share on other sites More sharing options...
Rich F Posted July 15, 2014 Author Share Posted July 15, 2014 Its been a while since my last post, a little more progress made. i have to say this one is fighting me all the way. This is the first time I've made a Hasegawa Harrier and have to say the fit isn't great, either that or I've done something wrong. Anyway on to the pics, I decided the add a little rivet detail the the kit, if only to add a bit of interest to an otherwise pretty drab colour scheme. I tried to make it look subtle and not jump out too much. You can see from this picture my attempt to try and blend the LERX into the intakes with some Mr Surfacer 500. This has now been blended and the intake fronts have been added. More filler required! I think I'm going to struggle to get this finished before the deadline but I'll keep plugging away... Cheers 3 Link to comment Share on other sites More sharing options...
Dave A Posted July 15, 2014 Share Posted July 15, 2014 Ah, the infamous-yet-much-loved Hasegawa Harrier. I made one once. I've got another 4 in boxes I'm afraid to touch... Link to comment Share on other sites More sharing options...
SaintsPhil Posted July 15, 2014 Share Posted July 15, 2014 Nice to see progress, unfortunately it's the kit not you! I've built a couple and both had dodgy fit, both in different places... Link to comment Share on other sites More sharing options...
Tnjgr57jii9gfdsd34c Posted July 15, 2014 Share Posted July 15, 2014 Looking very good so far, i am ashamed my Hasegawa Harrier was hit by a surface to model desk missile........OK, it had an undesirable air to bin interface! LOL Link to comment Share on other sites More sharing options...
