Beaconroot Posted June 25, 2014 Share Posted June 25, 2014 Love it John! Keep up the great work. Looking forward to your next update. Jim Root Link to comment Share on other sites More sharing options...
Martian Posted June 26, 2014 Share Posted June 26, 2014 This is turning into one magnificent build! Martin Link to comment Share on other sites More sharing options...
Andrew.S Posted June 26, 2014 Share Posted June 26, 2014 Very good job indeed! Link to comment Share on other sites More sharing options...
RMCS Posted June 26, 2014 Share Posted June 26, 2014 really enjoying watching this build, awsome Link to comment Share on other sites More sharing options...
SaintsPhil Posted June 26, 2014 Share Posted June 26, 2014 Looking very good, while you're still scribing panel lines don't forget the double engine access panel lines like this http://www.airforceworld.com/fighter/gfx/harrier/harrier_frs_mk2_1.jpg Phil Link to comment Share on other sites More sharing options...
John the Yank Posted June 26, 2014 Author Share Posted June 26, 2014 Got it Phil! Thanks, prolly missing a few other scribes. Going to review the drawing in SAM's SHAR book before priming & do what I can. Working small access panels & other glue ons tonight. The fences took an evening to fabricate and and set in place. A little clear colored resin for the nav lights. Here is a little FYI: The Q sprue for the Hasegawa F-111 has a clear window for the Pavetack Pod. If you did not use this part, it has a shape similar to the starboard side camera window. It just needs a little reduction, thinning & polishing. 3 Link to comment Share on other sites More sharing options...
HL-10 Posted June 27, 2014 Share Posted June 27, 2014 Impressive work, really enjoying this build! Link to comment Share on other sites More sharing options...
SaintsPhil Posted June 27, 2014 Share Posted June 27, 2014 That's a top tip about the glazing, that's another reason mine stalled as I had all sorts of issues trying to fabricate that part... Good work on the access panels, and fire access slots Link to comment Share on other sites More sharing options...
Mattlow Posted June 27, 2014 Share Posted June 27, 2014 Nice work on this. A question from someone with no knowledge of these kits. Why substitute the Monogram fuselage? Accuracy, finesse..? Certainly going to look good when finished. Matt Link to comment Share on other sites More sharing options...
John the Yank Posted June 27, 2014 Author Share Posted June 27, 2014 Nice work on this. A question from someone with no knowledge of these kits. Why substitute the Monogram fuselage? Accuracy, finesse..? Certainly going to look good when finished. Matt Both kits are old molds by today's or even the 1990's standard. The shape of both kits are remarkably accurate, however the Monogram kit is superior in terms of surface detail and overall mold quality. If you have both, the difference is obvious. Saying that, some nice Airfix SHARS have been made but extra effort will be required. There are chaps here who have outstanding Airfix SHAR builds. I got lucky and picked up some 2nd hand Monogram AV-8A kits at a couple shows for $5.00 each and decided to go this route. I was going to do an FA.2 but Kinetic announced theirs so I went with the FRS.1. Lets hope they do justice to the early SHARs, but this is my plan B. John 1 Link to comment Share on other sites More sharing options...
John the Yank Posted June 30, 2014 Author Share Posted June 30, 2014 (edited) Installed the Pavla intakes and they fit well, a little Tamiya Polyester Putty on the inner fuselage joints to blend the joint. Externally a little smoothing and CA to seal and smooth the seam. Really coming together now, going to pin the Pavla Stabs next, already reworked fuselage stab joint to accept new pins. Should be ready to prime after a few antnnae are added and some masking. John Rear deck details, decided to go with canopy open. Edited June 30, 2014 by John the Yank 3 Link to comment Share on other sites More sharing options...
Caerbannog Posted July 2, 2014 Share Posted July 2, 2014 Very nice! Rene Link to comment Share on other sites More sharing options...
John the Yank Posted July 4, 2014 Author Share Posted July 4, 2014 Primed and curing, needs Micro Meshed (3600) and a couple of spots smoothed with MS 1200. Doesn't look cobbled together now, soon it will look like "La Muerte Negra". Not a bad Bodge job, might get through MOT. John 2 Link to comment Share on other sites More sharing options...
Brad-M Posted July 4, 2014 Share Posted July 4, 2014 Fab work there! Thanks for taking this project on, now someone will come out with a mainstream kit of the aircraft Brad Link to comment Share on other sites More sharing options...
kwaterous Posted July 5, 2014 Share Posted July 5, 2014 Of course, as soon as you finish this, Kinetic will announce that they're going to release one... K Link to comment Share on other sites More sharing options...
Pete in Lincs Posted July 5, 2014 Share Posted July 5, 2014 Close enough for Government work! Looks good to me too. Link to comment Share on other sites More sharing options...
heloman1 Posted July 5, 2014 Share Posted July 5, 2014 Looking very good indeed. Link to comment Share on other sites More sharing options...
Tomjw Posted July 5, 2014 Share Posted July 5, 2014 I think this is great. Skillful work on display. Cheers, Tom. Link to comment Share on other sites More sharing options...
John the Yank Posted July 9, 2014 Author Share Posted July 9, 2014 Finished the camera port cover, needs a little polishing, then liquid masking before painting. A drop of future for a final finish. John Drilled the vent holes, shell eject ports, & added barrels to Monograms cannon pods. Primed & ready for install. 2 Link to comment Share on other sites More sharing options...
phildagreek Posted July 9, 2014 Share Posted July 9, 2014 Looking good. Link to comment Share on other sites More sharing options...
Caerbannog Posted July 10, 2014 Share Posted July 10, 2014 Very nice. Link to comment Share on other sites More sharing options...
John the Yank Posted July 11, 2014 Author Share Posted July 11, 2014 (edited) More fodder for this WIP. Cleaned up the camera port cover, just a little future after painting. Mounted the cannon pods, had to use a little MS to smooth the joint, A few small details and it will be ready for paint. Edited July 11, 2014 by John the Yank 4 Link to comment Share on other sites More sharing options...
Tomjw Posted July 11, 2014 Share Posted July 11, 2014 Looking good. Is the surface painted or primed. I ask because it looks very immaculate for a model in product. At that stage mine tend to look like I had just gone at it with a load of power tools. Keep up the good work. Tom. Link to comment Share on other sites More sharing options...
RNoAF Aerobatic Team Posted July 11, 2014 Share Posted July 11, 2014 Outstanding work again... amazing work on the details. Link to comment Share on other sites More sharing options...
John the Yank Posted July 11, 2014 Author Share Posted July 11, 2014 Looking good. Is the surface painted or primed. I ask because it looks very immaculate for a model in product. At that stage mine tend to look like I had just gone at it with a load of power tools. Keep up the good work. Tom. Thanks Tom, it still is in primer. I use gray automotive lacquer primer out of a spray can, (the cheapest I can find) and wet sand with 1600 grit & Micro Mesh 3600 grit before paint. Everything else is airbrushed. There is no substitute for fit and alignment, I do not use putty as filler, I use CA mixed with talc or straight CA. If a gap needs bridged I use strip or scrap styrene. Mr. Surfacer works wonders for blending and smoothing joints too. John 1 Link to comment Share on other sites More sharing options...
