So how do i build a lunar/mars regolith grinder,oven/cooler/dispersal machine?
As the bit at the top says,how do you go about building,the said machine,well a quick look around the nasa sites,and you can find this,
si guess that will have too do?...and it does look like a military vehicle as a starting point,so out with the spares box
guess that will do for starters?
Don
i made these crap wheels a few month ago,for a lunar rover,so i will use these for the teeth/grinding wheels,?
so thats a few bits to start with.
so im thinking something like this????
maybe,but its got to fit under a automated lander for delivery,
make a start,cutting aputure for conveyor belt,and grinder.
extra bit of support on
might use this or not?
in the end ive re instated,a portion of the hull for support,
this is where supposedly the conveyor with dust enters the oven section?
going to use one of martins resin doodly bobs,as a conveyor support,i think its a hose reel really?
in there somewhere
give it some undercoat,see what seams are showing,,
need to work out the coolant section,and the grinding wheel end??
i,ll do a bit on the conveyor system whilst thinking..
now what does a coolant plant look like,quick reference to the space section,on cooling plants and distillation in deep space section...
back to the conveyor,my head hurts..
enough of that,back to the coolant plant section....
so the conveyor goes under there on its way out..
now how the hell am i going to put the grinding wheels at the head of this?????
maybe..
very frogs leggy..
measure up some panels for the belt sides and walkway??
still need to work out some things,my head urts...
need to raise the height of the control cab..
still need to work this out.........ugger
cheers Don
Oh No! It had to come, 'Panzers on Mars'!
Don, Film trailer on You tube, P 51 dragon fighters.
Mustangs v Nazi dragons in the desert!
This one is looking seriously good.
BTW, I liked those 'Crap' wheels.
Keep them coming.
Pete
Cheers pete,
had a bit od a redesign.i cant believe i said them words?...ok in reality i found some bits,that fit different ways,so i stuck them on.i still cannot figure out how to mount the grinding wheel,but it will come to me?..
so how far did i get last night,well...i now need to fit some tank holders along the sides,and allow them to hinge and drop,to change them??
making some hinges for the truss,dont know where im going after that?
i reckon that will do...
right how do i get the rear end to discharge its load?...another conveyor....
to fit the backend discharge,i need to chop some more out???
stick a few bits of plastic on...
hi,sorry things are not working as they should,
so sticking some plastic on.....
right thanks for looking,need to have a rethink on the backend design,
cheers Don......from the darkside
stuck a few more bits on,took a few bits off,...stared at it for a while,it did,nt get any better,so ive gone with these additions,hey ho...
so starting from here,
so chopping a few holes init...
so first version,like this..
so trying the backend conveyor..
so sticking some rollers on..
so final bit on,and the base of the coolant plant on
looks about right,
first prob noticed,its a bit low to get the conveyor out,...could put it on a sled type thing ,could put wheels on for support,or could refigure...
cheers
Don
Well after a bit of delibiration..thought,and trying two or three different ways to attach the grinding head in a realistic manner,ive finally settled on a jcb type, linkage/ hydraulic attachment,...thank uck,im pulling my hair out ,mulling this one over,?
so partly assembled the grinding wheel in its housing..
found an attachment block,...one of martins models resin bitsandbobs...
cut to fit the pipe....ish
so aluminium gun barrel in,now to get it to lower and raise the grinding wheel???
so shorten the barrel
going to use a resin at at foot,as the connecting bit...so drilled and tapped that to accept the barrel
doesent look too bad,need to build a bit more attachment points and some hydraulic rams,and a happy sat bunny.?
cheers ..
Don...on the darkside...
well,ive nearly built one,??? of sorts...putting last few fuel tanks and hoses on tonight,the trouble seems to be......where to stop??
still got a few more bits to stick on,..
cheers
Don. posting from the darkside.
well,i dont know,just how far this will go but getting a bit fed up now,time for something else?
anyway so far...
storage tanks
cheers don.
looking at others ways to stick bits together,with a spacy theme?
cheers chaps for commenting,its getting a bit bulky and heavy at the moment,time to start on the base and finish it methinks?
comments appreciated...good...bad..indifferent..always welcomed?
cheers Don
To echo that is very impressive, looks more like an Alien Nostramus hold item than anything, so very appropriate :thumbsup2:
I can't believe how fast you've built this :yikes:
Just the right balance between rugged and designed to operate at lower g than Earth normal. I really look forward to the painted item.
well thanks chaps, and as for blowing it up pete,the kids will do a great job without explosives?,,,,dad these wheels dont go round?
anyway last few pics,going to decal tonight,and as for painting,well might slap some little bits on,but not going over the top?
the pigging lander that carry,s this is hooge?
front
side
back
tother side..
thanks for looking,just going to finish its lander,then on with the tunnel borer?
cheers,
don,from the darkest depths of the darkside.
  • 4 months later...
That is a marvellous build....Your design is way cooler than those concept images! :thumbsup:
Have you read the Mars trilogy by Kim Stanley Robinson? :hmmm:
no i hav,nt is it worth reading,would much prefer that good historical book "How humans colonized mars" but dont think i,ll ever see that one printed..lol
don
The trilogy between them paint an interesting picture of how such a colonisation effort might progress, the technology involved is all very plausible by and large, although a few 'novelties' are required to maintain the plot.....Have a look, I think you might enjoy them. :shrug:
