Shar2 Posted March 24, 2014 Share Posted March 24, 2014 Kawanishi H8K2 Type 2, Emily Flying Boat 1:72 Hasegawa HistoryAt the same time the type's predecessor, the Kawanishi H6K, was going into service in 1938 the Navy ordered the development of a larger, longer-ranged patrol aircraft under the designation Navy Experimental 13-Shi large Flying Boat. The result was a large, shoulder-winged design that is widely regarded as the best flying boat of the war. Despite this, initial development was troublesome, with the prototype displaying terrible handling on the water. Deepening of the hull, redesigning of the planing bottom and the addition of spray strips under the nose rectified this. Two further prototypes, which were in fact pre-production aircraft, joined the development program in December 1941.The IJNAF accepted the first production version as the H8K1, Navy Type 2 Flying Boat, Model 11, of which only 14 would be built, before the improved H8K2 variant was put into service. The K2 had an extremely heavy defensive armament earned it deep respect among Allied aircrews. The H8K2 was fitted with more powerful engines, slightly revised armament, and an increase in fuel capacity. One hundred and twelve examples of the H8K2 were built and were used on a wide range of patrol, reconnaissance, bombing, and transport missions throughout the Pacific war. The H8K2 was given the Allied code name "Emily".The ModelThis has to rank as one of the oldest kits thats been reviewed by this reviewer. Its original release was in 1968, and it has been re-released at least eight times before this current edition. I remember seeing it as a kid and always wanting one, but never quite being able to afford it. Finally I have it in my hands and the only thing it fills me with is nostalgia. The only areas that have been changed over time are the boxes and the decals. So be aware of the kits origins as you could mistake the shiny new box as a new moulding. Whilst the boxtop has a very nice painting of an Emily flying along through sunset soaked clouds inside are some pretty dark ones lurking. The five sprues of medium grey styrene depict some moulds that are showing their age and wear. Whilst the fuselage and wings still look pretty good, there is a fair bit of flash on the sprues, some parts are showing imperfections and the details are becoming less distinct. Quite a few parts just seem to be lacking in something, which I cant quite put my finger on, but it might just be that Ive been spoilt over the years. Oh, and if you like rivets, you love this model as its rivet central, except where the main decals go, these have been de-riveted for a better fit, something that a lot of manufacturers did. Having said all that there are some parts that must have been state of the art back then and still look pretty good today. The cylinder banks are still good, the aircraft comes with a cockpit interior, which is crying out for some extra detail, but the basics are there. The shape of the model seems to match the real aircraft pretty well and hopefully some enterprising after market company will bring out some bits and bobs for it.Construction begins with the fitting of the fore and aft doors in the port side of the fuselage and the assembly of the nose gun and upper turret. You will need to change the guns as they are more like broom handles on blocks of wood. The fin, rudder, horizontal tailplanes and elevators are all assembled and joined together then put to one side. The cockpit consists of the floor, front and rear bulkheads three seats, joined control columns and yokes. The front bulkhead has the instrument panel moulded onto the front onto which the decal provided is used. With the numerous clear window parts fitted to each fuselage half the cockpit and upper turret are sandwiched between the fuselage halves as it is closed up. The canopy, plus front and rear gun positions are then attached, as are the two waist positions, all of which have the rather wooden guns fitted. The rather interesting and unusual, (for a model), split flaps are assembled and fitted to each lower wing half along with the ailerons. The upper wing halves are then glued to the lower. There is a nicely drawn diagram showing how the flaps are meant to look in the retracted and lowered states. The two cylinder banks for each of the four engines are assembled and slid into position within the cowlings. A long shaft is then pushed into the engine from the front and attached to a cap at the rear. The single piece propellers are then attached to the front of the shaft and capped with the spinners. To finish the engines/cowlings off the oil cooler intakes are fitted to the top of each cowling. The fire walls are then attached to the nacelles and the engine/cowlings are fitted to the firewalls. Another nice inclusion is the servicing platforms, four of which are provided and would give aid in the making of an interesting diorama. Alternatively, the access doors for the ramps can be fitted in the closed position. To complete the wing the clear landing light covers are glued into place. The major assembly now begins, with the fitting of the fin/rudder, horizontal tailplanes, and wing assemblies. The yagi style aerials are fitted to either side of the nose, a pitot probe on top of the nose in front of the cockpit, three aerial masts along the top of the hull and the weapons carriage of two torpedoes, on single pylons, (one each side), or four bombs on twin pylons. The wing floats are then assembled from two float halves and a single piece double strut, which will need to be rigged using suitable material, then attached to the underside of the wings. There is a separate panel that mounts on the underside of the hull just foreward of the step which could cause problems with filling any gaps due to the numerous rivets. The model also comes with beaching gear and towing tractor should the modeller wish to do a ramp scene. The main gears consist of the leg, two wheels, axle caps and floatation blocks, whilst the rear hull trolley is similar it is fitted with two flotation blocks and the single leg is moulded with a vee section to match the hull. Lastly, the tractor is assembled from two body halves, four wheels; the rear ones have separate hubs, the steering wheel and driver. This can be attached to the aircraft with a styrene tow rope. DecalsThe decals look to be pretty good. They are quite matt, but have good density of colour and are in good register. Theres not much in the way of carrier film which is good and the side hinomaru have cut out areas which coincide with the detail in that area. Since there are no rivets in any of the areas where the hinomaru are positioned there shouldnt be any problem with them settling down. The identification numbers on the tail and the yellow leading edge areas on the wings may cause problems though, unless the modeller uses their favourite softening and setting solutions. There are markings for three aircraft from around 1944, two from the 851st flying group and one from the 801st flying group. ConclusionWell, what can one say that hasnt already been said above? In general it looks to be a goodish kit, which could be built straight out of the box if youre willing to overlook the shortcomings. Alternatively it does give the basis of a major increase in detail, particularly the cockpit and machine guns/cannon. It certainly has prospects and with a good paint job, diorama setting and some nice weathering it could, and indeed can be made into something rather nice. Whatever you decide, its still a great looking aircraft and would make an interesting comparison next to a Sunderland.Review sample courtesy of UK distributors for Link to comment Share on other sites More sharing options...
stevehnz Posted March 24, 2014 Share Posted March 24, 2014 (edited) Are you going to build this now, he says hopefully? Like you I've long lusted after one of these & Hasegawas H6K which I believe is equally as old & also still available. It'd be good to see a build of this. No pressure mind, just saying. Steve Edited March 24, 2014 by stevehnz Link to comment Share on other sites More sharing options...
Shar2 Posted March 24, 2014 Author Share Posted March 24, 2014 I am tempted, but have other projects in mind before this one. We'll see how it goes. Yeah, I've always the Mavis too, there's something about big flying boats. 1 Link to comment Share on other sites More sharing options...
Antoine Posted March 25, 2014 Share Posted March 25, 2014 Great review, as usual, Dave. Went down the same lane as you when I was a youngster, for the Emily, but also the Mavis. I did get the last Mavis release, and was thinking it would be enough. But it´s not, I'll order this one, too. Link to comment Share on other sites More sharing options...
XL929 Posted March 25, 2014 Share Posted March 25, 2014 That box artwork is gorgeous Link to comment Share on other sites More sharing options...
Stew Dapple Posted March 26, 2014 Share Posted March 26, 2014 Are my eyes playing up, or is that canopy framing moulded on the inside? Cheers, Stew Link to comment Share on other sites More sharing options...
Antoine Posted March 26, 2014 Share Posted March 26, 2014 (edited) To me, looks to be the usual hasegawa framing, which is very thin, and not so much rised. Sorry, raised..... Edited March 26, 2014 by Antoine Link to comment Share on other sites More sharing options...
Kampartiger Posted March 26, 2014 Share Posted March 26, 2014 Bought the reviewed Emily back in the late 1970s but it came in a FROG's box.What made me to buy it was a page from a commando's comic which showed a beached Sunderland firing full blaze on an Emily.wow!what can I say,I was only 9 and of course I didn't know the two seaplanes never met each other in the Pacific.I hope it is still there in the marsh behind my old house in Kota Kinabalu,Sabah,Malaysia.That was 40 years ago and it is still my favourite seaplane.Instead of moulding more f16s,hopefully hasegawa will make a fresh new one.Amen to that. Link to comment Share on other sites More sharing options...
Sgt.Squarehead Posted April 24, 2014 Share Posted April 24, 2014 What are Hasegawa charging for this dinosaur nowadays? Link to comment Share on other sites More sharing options...
Shar2 Posted April 24, 2014 Author Share Posted April 24, 2014 As long as you don't start moaning about it. IT's HERE Link to comment Share on other sites More sharing options...
Julien Posted April 24, 2014 Share Posted April 24, 2014 As long as you don't start moaning about it. IT's HERE Out of stock so must have been popular! Link to comment Share on other sites More sharing options...
Sgt.Squarehead Posted April 24, 2014 Share Posted April 24, 2014 I wouldn't say I've ever been particularly whiny about Hasegawa pricing (I've got Dragon for that! ).....I will admit to having been shocked and staggered a few times, but who (to be honest) hasn't? Link to comment Share on other sites More sharing options...
Gumbie Air Services Posted April 24, 2014 Share Posted April 24, 2014 That's a bit like buying the Airfix Sunderland, then paying Italeri's price!.... Still, I do want one! Link to comment Share on other sites More sharing options...
