IanW Posted March 3, 2014 Share Posted March 3, 2014 Hi, I'm just completing my 1/35 Accurate Armout Stolly and need to fit a whip aerial. Could anyone please provide me the length a Clansman whip antennae should be when mounted on the Stolly? Thanks very much, Ian Link to comment Share on other sites More sharing options...
Mr Grumpylee Posted March 3, 2014 Share Posted March 3, 2014 (edited) Hi Ian, I thought they were about 1.5 meters but having Googled it, I wasn't right but I wasn't wrong, 1.2, 1.8 and 2.0 meters, hope this helps? Edited March 3, 2014 by Mr Grumpylee Link to comment Share on other sites More sharing options...
IanW Posted March 4, 2014 Author Share Posted March 4, 2014 Hi, That helps emormously, thanks you! Link to comment Share on other sites More sharing options...
rayprit Posted March 4, 2014 Share Posted March 4, 2014 when I used clansman radios on Ferrets, Land Rovers and Centurion tanks, they were provided in 2 x 4 foot sections which screwed together to make one aerial, some vehicles, especially command vehicles, would have upto 3 or 4 aerials fitted. In fact, if you check out pictures of early Centurions, you will see on top of the turret a tube/canister, just over 4 foot long for stowing aerials when not in use(behind radio operator and commanders cupola) Check out Ferrets, providing they have no sand channels fitted to the front, you will see similar tube or canister for the 4 foot sections beneath the attachments for the pick When I was in the forces, we were imperial measurements, so, knowing how quick the army moves, it maybe metric now. I left in 1973 and still had 1937 pattern webbing and backpack!!! Link to comment Share on other sites More sharing options...
Mr Grumpylee Posted March 4, 2014 Share Posted March 4, 2014 In my maths book, I reckon both feet and metre measurements are about right...ish! Link to comment Share on other sites More sharing options...
IanW Posted March 5, 2014 Author Share Posted March 5, 2014 Cheers guys! Link to comment Share on other sites More sharing options...
Dads203 Posted March 5, 2014 Share Posted March 5, 2014 As an ex operator, the Clansman whips were:- VHF 353 2m , HF 321 whip was 3m or 4m depending on the freq, this was reduced when on roads to avoid hitting power cables etc to 2m. They were the same one metre whip sections for the VHF and HF they just screwed together , we got issued a bit of kit that allowed us to angle the HF whips back or forward so we could use a 3 or 4m antenna whilst on road moves. HTH Dan Link to comment Share on other sites More sharing options...
Kingsman Posted May 17, 2014 Share Posted May 17, 2014 As another ex-Clansman scaleyback I agree with all of the above but I recall the vehicle VHF on my Landies and Sultan being 2.4m in 2x1.2m (i.e. 4 foot) sections. These antennas were hollow copper and tapered from base to tip. Stolly would have carried 351 or 352 manpack set on clip-in kit, not 353. Antennas, bases and TUAAM were the same for all VHF. TUAAM would have been pretty much directly below the antenna base, but inside. With 351 and 352 there was a small box between radio and TUAAM to trigger TUAAM tuning, usually next to the radio. Damned if I can remember its name. Wiring-wise, the radio battery would have been connected to vehicle power for charging, the set would have been connected from right side to the tuning device and then the TUAAM. Headphones connected to left side. Link to comment Share on other sites More sharing options...
Phil Evans Posted May 17, 2014 Share Posted May 17, 2014 Initiate Box for the 351/2 clip in-role and DCCU 14V or 28V for charging, depending on vehicle electrical system. I can't remember antenna element lengths though. Phil ex-REME Tels Link to comment Share on other sites More sharing options...
