woody37 Posted September 28, 2013 Share Posted September 28, 2013 Resin F-101B Voodoo Cockpit Pavla 1:72 for Revell Kit Revell rereleased their kit of the Voodoo last year. This strange yet likeable aircraft was a two seat derivative of the Voodoo designed around the fighter intercept role. Key features of this aircraft were the two seat cockpit and extended afterburner sections which 'hung' out of the rear of the aircraft. This set offers a significant improvement to the kit cockpit. Moulded in light grey resin, the tub has noticeable improvements to the side consoles including throttles and more detailed switch panels. Both front and rear forward panels have very detailed instrument faces and the ejection seats are works of art including harnesses, seat cushions and complex framework / ejector rails. I'd recommend some dry fitting of the tub into the fuselage halves as traditionally, some filing of the resin tub may be necessary to get everything to close up correctly, but everything else should be quite straight forwards due to the minimal parts count. ConclusionIf you're a fan of the Voodoo, adding this to your build will offer a big improvement over the kit parts. The detail is quite stunning. Review samples courtesy of 1 Link to comment Share on other sites More sharing options...
