IPMS19 Posted September 27, 2013 Share Posted September 27, 2013 -The Revell 32 Arado turned into an A0;The catapult is from HPH -This requires a few modification of the original model like the suppression of the wing armament and associated panelling, same to the forward firing armement and propeller - The model is intended to depict the Arado embarked on the Graf Spee before being camouflaged. 1 Link to comment Share on other sites More sharing options...
Nigel Heath Posted September 27, 2013 Share Posted September 27, 2013 (edited) Extremely fine looking model. I love the way you have one wing folded and the other extended and the open panels. Nigel Edited September 27, 2013 by Nigel Heath Link to comment Share on other sites More sharing options...
Live_bait Posted September 27, 2013 Share Posted September 27, 2013 (edited) Outstanding work, I enjoy looking at your model. More pictures please Edited September 27, 2013 by Live_bait Link to comment Share on other sites More sharing options...
Pete in Lincs Posted September 28, 2013 Share Posted September 28, 2013 Yes, More please. I like that a lot. Pete Link to comment Share on other sites More sharing options...
sinnerboy Posted September 29, 2013 Share Posted September 29, 2013 Luvly jubbly...bit special that! Am I right in thinking the HPH catapult has no hand rails and stanchions included...if that's the case can I ask what you used? Link to comment Share on other sites More sharing options...
IPMS19 Posted September 30, 2013 Author Share Posted September 30, 2013 Luvly jubbly...bit special that! Am I right in thinking the HPH catapult has no hand rails and stanchions included...if that's the case can I ask what you used? - Its true the hand rails and stanchions are to be made from scratch. - For this I essentially used metal wires of the same diameter for both vertical and horizontal parts - On the vertical parts I have inserted a small tubing piece of the inside diameter equal to the one of the wire with a hole drilled on each side of the tube were to insert and cement each middle bar cutted at the necessary lenght.The same was done for the top horizontal rail with only one hole in which the top of the vertical bar is inserted and cemented Link to comment Share on other sites More sharing options...
sinnerboy Posted September 30, 2013 Share Posted September 30, 2013 thanks for the reply....I also seem to remember that someone made the rails from materials purchased from something like " Cornwall model boats" which would possibly be an easier option, bearing that in mind, can I ask you what diameter are the rails and also what is the height of them ? thanks in advance rick Link to comment Share on other sites More sharing options...
IPMS19 Posted October 1, 2013 Author Share Posted October 1, 2013 thanks for the reply....I also seem to remember that someone made the rails from materials purchased from something like " Cornwall model boats" which would possibly be an easier option, bearing that in mind, can I ask you what diameter are the rails and also what is the height of them ? thanks in advance rick -Hi Rick, - If you have the opportunity to get some modelling boat material grab it as quickly you can ,it will avoid you some headheaches.... - For my catapult I've used for horizontal and vertical parts length of 1 millimeter mettallic wire, the vertical parts are 30 m/m with 2 or 3 m/m added for cementing in the deck -For the hand rail on the deck itself , the vertical parts and the top bars are made of 1,5 m/m copper square section tubing 30 m/m (+ 2 or 3 more) long for vertical parts.The thinner wires are same the ones on the catapult. - Drilling holes both side of the vertical bars allow you to use lenght of wire equal to the total lenght of the hand rails; - The square section is not the ideal solution but I had no rounded section of the right size at my disposal,...... I hope I won't be jailed for this crime..... Link to comment Share on other sites More sharing options...
sinnerboy Posted October 1, 2013 Share Posted October 1, 2013 ,...... I hope I won't be jailed for this crime..... oooh, don't know it's pretty serious! Thanks for the dimensions, they look just right in the photos cheers Rick Link to comment Share on other sites More sharing options...
Duncan B Posted October 2, 2013 Share Posted October 2, 2013 Fantastic, that must take up quite a bit of room. Duncan B Link to comment Share on other sites More sharing options...
