sunray Posted August 30, 2013 Share Posted August 30, 2013 (edited) Hi folks. Here is my effort of an Airfix Mosquito Mk XVIII. I used a clear canopy from Falcon, part of a photo etch set from Airwaves and also a bit of scratch building for the cockpit and guns (I lost the original guns which now live somewhere in my shed). Anyway here are the photos. Cheers Ian Edited August 30, 2013 by sunray 10 Link to comment Share on other sites More sharing options...
sturmovik30 Posted August 30, 2013 Share Posted August 30, 2013 quality building,inspirational! Link to comment Share on other sites More sharing options...
russ c Posted August 30, 2013 Share Posted August 30, 2013 Great job on that old kit ! Link to comment Share on other sites More sharing options...
Mottlemaster Posted August 30, 2013 Share Posted August 30, 2013 The vac canopy works a treat ,very realistic Link to comment Share on other sites More sharing options...
kev67 Posted August 30, 2013 Share Posted August 30, 2013 Looks great, did you re-scribe it as well Link to comment Share on other sites More sharing options...
trickydicky210 Posted August 30, 2013 Share Posted August 30, 2013 Lovely build on an old kit Link to comment Share on other sites More sharing options...
batcode Posted August 30, 2013 Share Posted August 30, 2013 nice build looks great Link to comment Share on other sites More sharing options...
sunray Posted August 30, 2013 Author Share Posted August 30, 2013 Thanks for the good reception guy. Yes Kev I did do a bit of re-scribing, not my favourite pastime. Also I can recommend the vac canopy from Falcon. This was my first attempt and I found it a lot easier to fit than the original. Cheers Ian Link to comment Share on other sites More sharing options...
nicE1 Posted August 30, 2013 Share Posted August 30, 2013 Very nice indeed! Link to comment Share on other sites More sharing options...
Winenut Posted August 30, 2013 Share Posted August 30, 2013 Top Notch!!!! Lovely effort. AND FANTASTIC PHOTOGRAPHY to show it all off. Awesome! Link to comment Share on other sites More sharing options...
stoohoo Posted August 30, 2013 Share Posted August 30, 2013 Really nice build of an old kit Ian, reminds me how much i'd like to build a Tse-Tse in the future, cant beat a honking great gun Link to comment Share on other sites More sharing options...
Steven Posted August 30, 2013 Share Posted August 30, 2013 love it great build cant believe its the Airfix kit.. Link to comment Share on other sites More sharing options...
JOCKNEY Posted August 30, 2013 Share Posted August 30, 2013 Really lovely job, had to remind myself it was 1/72 such is the detail you have achieved Link to comment Share on other sites More sharing options...
TCinLA Posted August 31, 2013 Share Posted August 31, 2013 Nice work but you need to get better control of the airbrush. You're shooting at too high a pressure and wikthout a fine enough tip. If you don't have a pressure regulator you need to get one. Shoot at 13-15 psi, thin your paint 50-50, and use a fine tip. The result will make your paint work the equal of your construction work, which is excellent. Link to comment Share on other sites More sharing options...
HL-10 Posted August 31, 2013 Share Posted August 31, 2013 You've done a lovely job on that old kit! I do like the Molins gun armed Mosquito. Link to comment Share on other sites More sharing options...
tonyb Posted August 31, 2013 Share Posted August 31, 2013 Very Nice Job Tonyb Link to comment Share on other sites More sharing options...
Spitfire31 Posted August 31, 2013 Share Posted August 31, 2013 Really nice build of that venerable but basically very sound kit! And the Falcon canopy works wonders for the overall impression.On the subject of general impression, though, British camouflage is better represented being masked rather than freehand sprayed. On your otherwise excellent model the camo demarcations are uncharacteristically diffuse – just compare it with any WWII era photos of the real thing.Good build!Kind regards, Joachim Link to comment Share on other sites More sharing options...
sunray Posted August 31, 2013 Author Share Posted August 31, 2013 Thanks again guys for the comments and advice, I will give them ago on my next build. Cheers Ian Link to comment Share on other sites More sharing options...
woody37 Posted August 31, 2013 Share Posted August 31, 2013 I do like seeing these old kits done well, this is gorgeous Ian Link to comment Share on other sites More sharing options...
Miggers Posted August 31, 2013 Share Posted August 31, 2013 (edited) Nice work but you need to get better control of the airbrush. You're shooting at too high a pressure and wikthout a fine enough tip. If you don't have a pressure regulator you need to get one. Shoot at 13-15 psi, thin your paint 50-50, and use a fine tip. The result will make your paint work the equal of your construction work, which is excellent. What TC said,other than that she's spot on. My a/brush is a Badger single action on a small compressor. What I do is paint a test piece in the base colour of the cammo(in your case that would be grey). Then once that has gone off,mix up and get ready to apply the other(in your case green)colour I tend to close the needle right down,set the pressure(Do that whilst holding the air valve down) and then slowly open the needle until the paint starts to "tint" the surface(of the test piece)then tweak the pressure and paint needle about until I'm getting a nice flow and steady ,light coverage (remember,less is more with an a/brush). To touch on what Joachim has said,get as many pictures of your subject as you can and compare as many references as possible,remember this: "Paint what you see,not what you think you see". I still think the old Airfix Mossie builds into a really nice kit and you've amply demonstrated that here Ian, (the undercart still a pig to fit?)that Falcon canopy works really well,miles better than the kit milkbottle. BTW,how the hell did you get those white rings on the spinners so tight? Edited August 31, 2013 by Miggers Link to comment Share on other sites More sharing options...
wagoneer Posted August 31, 2013 Share Posted August 31, 2013 Oh cool! My son is building the same, he'll be inspired to see your build and I'm going to get him the Falcon canopy you've used too. He's had real trouble with the undercarriage (being a bit heavy handed trimming parts off the sprue mostly) but it's coming along. Link to comment Share on other sites More sharing options...
sunray Posted August 31, 2013 Author Share Posted August 31, 2013 Oh cool! My son is building the same, he'll be inspired to see your build and I'm going to get him the Falcon canopy you've used too. He's had real trouble with the undercarriage (being a bit heavy handed trimming parts off the sprue mostly) but it's coming along. I had a bit of bother with the undercarriage as well. I got the Falcon canopy from Hannants (£12.50 approx). The good news is it isn't just one canopy, its quite a few including Spitfires, Hurricanes, Beaufighters, etc. Here is the one I got. I hopes this helps. Cheers Ian Link to comment Share on other sites More sharing options...
georgeusa Posted August 31, 2013 Share Posted August 31, 2013 I think you did a fine job on this old kit. Very nice work in such a small scale. I really enjoy this Mossie and this version. Have been thinking about doing a similar version in 1/48. Hope mine turns out as nice as yours. Link to comment Share on other sites More sharing options...
Viking Posted September 1, 2013 Share Posted September 1, 2013 Lovely Mossie! Cheers John Link to comment Share on other sites More sharing options...
stevehnz Posted September 1, 2013 Share Posted September 1, 2013 (edited) Nice mossie indeed & gosh, haven't we got the photos to prove it. Straight up though, that would have to be as good an Airfix Mossie as I have seen, nice. Steve. Edited September 1, 2013 by stevehnz Link to comment Share on other sites More sharing options...
