dr_gn Posted August 3, 2013 Share Posted August 3, 2013 Guys, I've had to bogde together a new cowling for my 1:72 Specuial Hobby Curtiss Hawk becasue the original was too wide at the rear. There were two cowlings in the kit, the 'wrong' one for my version was a good fit at the rear, but wrong at the front. I cut the rear of this one and stuck it to the front of the original, and filled and blended the join with Milliput. It needs some cooling gills adding as a strip, and re-scribing, but the shape I'm now happy with: Trouble is, becasue the corrected profile tapers to the rear, I can't fit the engine in without filing the cylinder heads off. If I do this, then by the time it's pushed into the correct position in the wider, slightly bulged part of the cowling, there will be a gap between the heads and the inner cowl. Idealy if I could make a more flexible cowling using the modded one as a pattern/former then I could fit the engine by springing the cowling around it. I thought about Vac-forming, but using my modded cowling this would give one that was too thick by the thickness of the plastic used. Any ideas? Link to comment Share on other sites More sharing options...
