Shar2 Posted July 6, 2013 Share Posted July 6, 2013 US Mk 23 MTVR Cargo Truck Trumpeter 1:35 History The Medium Tactical Vehicle Replacement (MTVR) is a family of all-terrain cargo trucks manufactured by Oshkosh for the US Navy and US Marine Corps. The MTVR was initially ordered to replace the existing medium truck fleet under the US Marine Corps programme. The vehicles were extensively deployed in Iraq and Afghanistan. The Oshkosh vehicle can transport troops, fuel, water, food and supplies. The vehicle will also be used to tow the M777 lightweight 155mm howitzer. More than 11,000 MTVRs have been delivered to the Marines and the Navy Seabees to date. The MTVR is available in nine variants including MK23, (the subject of this kit) and MK25 Standard Cargo Truck, MK27 and MK28 Extended Cargo Truck, MK29 and MK30 Dump Truck, MK31 Tractor, MK36 Wrecker, MK37 HIMARS Resupply Vehicle, 4x4 Short Bed Cargo, 9-Ton Load Handling System 6x6, and 16.5-Ton Load Handling System 8x8. The vehicles feature a welded all-aluminium cab mounted on a torsionally rigid channel section chassis frame. The conventional layout houses the engine at the front, crew cab in the middle and troop/cargo section in the rear. The crew cab accommodates three marines. The standard MTVR cargo variant has a length of 8.02m, width of 2.4m and a height of 3.5m. The curb weight of the basic cargo variant (MK23) is 12.6t. The trucks can be integrated with Oshkosh TerraMax UGV technology for conducting unmanned operations. The crew cab and cargo compartment are equipped with an MTVR Armour System (MAS) to protect the crew from 7.62mm M80 ball rounds and 7.62mm Armour Piercing (AP) rounds. The mine protection kit can protect the occupants from mines and improvised explosive devices (IEDs). The bottom of the vehicle is provided with aluminium armour and rolled homogeneous armour (RHA) to withstand the impact of grenades and mortar rounds used as mines. Powered by a Caterpillar C-13 six-cylinder diesel engine coupled to an Allison seven-speed automatic transmission and torque converter, and an Oshkosh single-speed transfer box. It provides a power output of 440hp. Each variant is equipped with Oshkosh TAK-4 independent coil-spring suspension, which provides superior mobility and allows each wheel to move independently on the uneven surfaces. The vehicle features anti-lock brakes with automatic traction control. The Central Tire Inflation System (CTIS) allows the driver to select tire inflation pressures according to vehicle payload and terrain type. The vehicle has a maximum speed of 105km/h and on-road cruising range of 483km. It can traverse a 60% gradient and 30% side slope with its maximum cross-country load and can ford waters up to 1.5m deep. It can be internally transported by C-5, C-17 and C-130 Hercules transport aircraft. The MK23 cargo variant is airlifted under-slung by CH-53 helicopter. The Model The kit comes in the now standard, and in my view, very attractive, and sturdy box with an artists representation of the MTRV Mk23 on the front towing an M-177 155mm howitzer. On opening the box is full to the brim with nine sprues of light grey styrene, three separate parts for the cab and bonnet, one clear sprue, six rubber tyres, one fret of etched brass, a small decal sheet and a length of copper wire. Each sprue and the separate parts are contained in separate poly bags ensuring that all the parts are well protected. All the parts are really well moulded, with no sign of flash, although there are quite a few moulding pips, which are slightly annoying, but a necessity due to the moulding process. Naturally for a truck the construction begins with the building up of the chassis. The two chassis rails are joined together by several cross beams, a representation of the engine sump and gearbox/torque converter and an intermediate gearbox with associated drive shafts and universal joints. Over the drive shaft another cross beam is fitted along with one over the gearbox and a U beam across the rear brackets of the main rails. Turning the chassis right side up another cross beam/cover is added above the drive shaft, whilst to the front the bumper is attached. The build then progresses to the suspension and wheel brake units. Each of the three sub-assemblies that go toward building the suspension units are very complex. Each suspension frame, (of which there are two per axle), is constructed out of a main part and two side frames. This is then fitted with the two piece spring, (which may take a bit of tidying up and would have been better moulded as a single unit), is attached between the upper and lower wishbones, the lower wishbone then has the shock absorber fitted between it and the upper framework. A short drive shaft is fitted with the ball joint and slid into the frame assembly and for the front axle, fitted with a lower steering bracket and upper steering arm. Once each of the six suspension assemblies have been built a transverse gearbox and two support rods are sandwiched between two of the assemblies per axle and cross frame attached to the bottom of each frame covering the gearboxes. The wheel hubs, brake units are then assembled and fitted to each ball joint. Each axle is then fitted to their associated position on the chassis and drive shafts are attached between the front axle gearbox to the intermediate gearbox, intermediate gearbox to the forward rear axle gearbox and between the forward and rear axle gearboxes. Auxiliary components are assembled, these include the fuel tank, which is a two piece affair, upper and lower, to which the two support mounts are fitted along with a four piece step assembly. The storage box is also of upper and lower construction which has the two support mounts and two catches before the air and hydraulic accumulators are attached. Both the fuel tank and storage box are attached to the left hand chassis rail. Two step frames and associated foot plates are then assembled and fitted one on each side as are the two cab supports. The final parts fitted to the chassis before the build moves onto the cab and cargo bed are the air intake stack, intake frame and support, engine intake pipe, which is threaded through the right hand footstep frame and fitted to the stack, rear cab shock absorbers and the cross chassis footplate. The cab assembly starts with adding a couple of minor parts to the underside of the cab floor, then flipping over to fit the accelerator and brake pedals. The instrument binnacle is made up of three parts, the lower console, upper air vent strip and the instrument panel, the instruments of which are on a decal. The use of decal softening and setting solutions may work here as the details are raised, or it may be better to paint the main details and cut out the placards from the decal and add them to their relevant positions. The completed binnacle is then fitted to the forward floor part along with the steering column and its associated support bracket. The drivers seat is made up of the squab and back rest which sits on a concertina effect part, then fitted to the cab floor. The two seater passenger seat is made up of a single box structure onto which the back rest is fitted, attached to two square sectioned supports, and attached to the cab floor. The outer cab structure is a single piece moulding, onto which the circular gunners hatch, clear front and rear screens, two hand rails and the four supports for the machine gun mount are fitted. The machine gun mount itself is made up of the crossways support structure, two spent casing troughs, ring mount, with the gun support attached. The completed assembly is then fitted to the four cab supports with individual brackets on each corner. The inner cab is then slid into the outer, and having dry fitted these parts I can say that it is a very good and positive fitting. The doors are then fitted with their associated clear parts and attached to the cab. The exhaust stack is made up of two parts with a PE mesh wrapped around the bottom section and attached to the right hand side of the cab with the exhaust pipe attached to the bottom of the stack and cab into what would be the engine bay. The rear mud flaps, wing mirrors, with PE brackets, wipers, PE foot plates and exhaust stack outlet flapper complete the cab build. The cab assembly is then fitted to the chassis and the front end completed with the fitting of the bonnet, made up of a single piece moulding onto which a PE mesh and back plate are fitted to the inside of the radiator grille, the headlights, sidelights and the oil reservoir at the back of the cab. Moving onto the cargo bed, the bed itself, with moulded tie down rings is fitted with the front fixed, rear lower fixed and what look like removable sides, presume, depending on role. The rear drop down flap is then attached, whilst on the underside, the support and strengthening beams are fitted, as are the strapping points, plus the front and rear mudguards. Turning the bed right side up more strapping points are added to the lower sides along with twenty more mid way up the sides, front and rear. These are made up using the provided jigs and the copper wire, which whilst looking quite a labourious job will make the model very convincing. The completed cargo bed is then attached to the rear chassis. The build is completed with the assembly of the six wheels, each made up of an inner and outer hub and an out hub plate. The rubber tyres are then pushed onto the hubs from the rear. The tyres are very well moulded, with no seam lines other than what you’d see on the real things, and the words are legible, showing that the manufacturers name is correctly spelt. They maybe not to everyones tastes and will probably be replaced with aftermarket resin ones if they are released, but they do look good. Etch Most of the etched parts have been mentioned in the above text showing where the parts are used. The etch sheet itself is quite thick, but not overly so, which means it shouldn’t be too hard to bend. It would still be best to anneal the parts beforehand though, especially the exhaust grille, which needs to be wrapped around the plastic part. The perforated parts are really well done, to the point they look stamped and will greatly aid the realistic look of the completed model. Decals The small decal sheet contains not only the instrument panel mentioned above, but the vehicle reg numbers for each of the two colour schemes provided, but also placards and identification numbers placed around the truck. The decals are very clear, slightly glossy and of good opacity, whilst the backing film looks nice a thin. Conclusion This is a super kit, with lots of parts and detail. If used in conjunction with an M198 155mm howitzer, (at least until an M777 is released), it will make a good basis for a diorama or vignette. My only real concerns are the complete lack of tilt and tilt bars with which, from research, these vehicles are usually fitted. But I guess these can always be scratch built. Recommended. Review sample courtesy of 1 Link to comment Share on other sites More sharing options...
richellis Posted July 13, 2013 Share Posted July 13, 2013 This looks nice, I was looking at these on the net and quite fancy having a go now Ive seen inside the box Link to comment Share on other sites More sharing options...
zed Posted July 15, 2013 Share Posted July 15, 2013 Thanks for review, as a result, I have bought one, great kit. FYI, resin wheels and tyres are now available from DEF Models, DEF Model DW35049. As you mention, the only let down is the lack of tilt. Link to comment Share on other sites More sharing options...
Shar2 Posted July 16, 2013 Author Share Posted July 16, 2013 Glad the review helped. Thanks for the info on the wheels, now we just need an AM tilt Link to comment Share on other sites More sharing options...
