Gremlin56 Posted October 30, 2016 Share Posted October 30, 2016 A museum piece Matt, no doubt about it. I think you have set the benchmark here. Re: Only issue is the carrier film for the turret number is still visible, sure I can figure something out. What i do in this situation is get a pin and go over the decal making tiny holes, (invisible really). Then I brush Mr. Mark Softer and Mr. Mark Setter over the offending decal. The holes let the fluid get underneath the decal and "pull it down" onto the surface again. 1 Link to comment Share on other sites More sharing options...
longshanks Posted October 30, 2016 Share Posted October 30, 2016 Awesome Job !! Kev 1 Link to comment Share on other sites More sharing options...
Pegguins Posted October 30, 2016 Share Posted October 30, 2016 Absolutely brilliant stuff. I'm just about to embark on their 1:16 panzer 4 (I like the F2 version), have you any tips? I'm a little worried about paint order and PE bending. Link to comment Share on other sites More sharing options...
Matt182 Posted October 31, 2016 Author Share Posted October 31, 2016 Thanks Chaps Thanks for the tip Julian, I will give that a go. 13 hours ago, Pegguins said: Absolutely brilliant stuff. I'm just about to embark on their 1:16 panzer 4 (I like the F2 version), have you any tips? I'm a little worried about paint order and PE bending. It may be worth taking a look at Julian's Panzer IV build HERE to get a good idea of what is involved and how to approach it. My best tip would be to research the vehicle and try to understand how the real thing would of been built. It helps to think of it like it is on a factory production line. What parts would be painted together and what would be painted before fitting. Break down the build into separate sections like the engine bay, drivers compartment etc. Study the instructions and references carefully, identify all the parts relating to each area and colours of each component. Try to find out what each component is, where it fits in the model and what other parts it joins to. I found this helped me plan my build, so I always knew what needed to be done next and when certain items needed to be painted and fitted. I also found it quite interesting learning about the real vehicle. My other tip is be prepared for losing motivation. I had points where I didn't work on it for months. If you are beginning to find things are becoming a chore, put it down and take a decent break. Last thing you want to do is force your way through it. As for the PE, I find that in 1/16 it is quite forgiving. If your worried about getting straight bends it might be worth investing in a folding tool like this. Worth the money if you use PE quite regularly. Hope that helps! 2 Link to comment Share on other sites More sharing options...
Matt182 Posted November 1, 2016 Author Share Posted November 1, 2016 Hi guys, Weathering of the turret is near complete. Lots of pigments have been dusted on and some rain / grime streaks added. Spare track links have been painted in Tamiya burnt iron, ready for washes and pigments. I kept paint chipping to a minimum, instead going for a dirty, scratched look. i also added a few stains on the flat part of the roof. Turret should be completed tonight 7 Link to comment Share on other sites More sharing options...
Ridgback Posted November 1, 2016 Share Posted November 1, 2016 Fantastic work Matt, what are you sing for the stains, looks really good. 1 Link to comment Share on other sites More sharing options...
FrancisGL Posted November 2, 2016 Share Posted November 2, 2016 Really well attenuated, it is massive ..., cheers mate 1 Link to comment Share on other sites More sharing options...
Matt182 Posted November 2, 2016 Author Share Posted November 2, 2016 Thanks chaps 13 hours ago, Ridgback said: Fantastic work Matt, what are you sing for the stains, looks really good. The stains are Vallejo 'dark wash for dark yellow'. It's a medium brown acrylic based wash which I dabbed on and allowed it to spread out. I've had it sat in a draw for a couple of years so I thought I'd give it a go. The streaks are raw umber oils, thinned with turps. Cheers Matt 1 Link to comment Share on other sites More sharing options...
Matt182 Posted November 5, 2016 Author Share Posted November 5, 2016 Hi guys, Almost at the finish line now. Lower hull has been weathered. Tracks were painted in Tamiya dark iron, given a heavy oil wash and lots of pigments. I used the fire to help dry them quicker Wheels painted and weathered Wheels on along with sprockets and idlers Finally, the tracks went on Not much left to do now. Better photos will follow one it's complete Cheers Matt 8 Link to comment Share on other sites More sharing options...
FrancisGL Posted November 6, 2016 Share Posted November 6, 2016 Stunning look!!!, very well job!, , cheers Matt 1 Link to comment Share on other sites More sharing options...
Jusjay Posted November 6, 2016 Share Posted November 6, 2016 Wow looks incredible! 1 Link to comment Share on other sites More sharing options...
Etienne Posted November 6, 2016 Share Posted November 6, 2016 Hello, I followed the build as soon as I discovered it ... Just an amazing big cat, the possibility you gave to see inside the model makes it very special Good job !!! E 1 Link to comment Share on other sites More sharing options...
Spookytooth Posted November 6, 2016 Share Posted November 6, 2016 Absolutely stunning Matt, no other words for it. Simon. 1 Link to comment Share on other sites More sharing options...
Matt182 Posted November 7, 2016 Author Share Posted November 7, 2016 Thanks for all the great comments chaps Just finishing up the last few bits now. Tools added to the left side. I decided to fit the tow cable in it's normal position and also added the track cable. Aerial has also been added. That just about finishes the build. I still have some small details to add and a figure to paint but this is pretty much it. I will be posting up in RFI soon, with some better photos Cheers 11 Link to comment Share on other sites More sharing options...
FrancisGL Posted November 8, 2016 Share Posted November 8, 2016 Extraordinary piece!!!, It is impressive, the 1/35 models are totally eclipsed ..., cheers mate 1 Link to comment Share on other sites More sharing options...
Kasparov Posted November 11, 2016 Share Posted November 11, 2016 Smashing work Matt! That's a proper piece of kit to put on the mantle I think I'm going to do something with a big ol' cannon kit next, won't be anything near to what you've built though! There's a big display box yearning for a nice detailed piece of artillery waiting in the stash Seeing your work I can't wait to get started! 1 Link to comment Share on other sites More sharing options...
Pegguins Posted November 16, 2016 Share Posted November 16, 2016 Fantastic work Matt. Have you got any tips for applying the trumetal copper for shells? I've had a test on a few pieces of spare sprue and getting a nice cover doesnt seem possible. I try to brush it over black primed surface but i get horrible brush marks in it and small details (like the writing on the endcaps of the shell) seems to get drowned pretty easily. Link to comment Share on other sites More sharing options...
Silverstone 2 Posted November 19, 2016 Share Posted November 19, 2016 Fantastic work Matt! I really like the camo scheme you chose for your KT. Lovely work, particularly nice camo scheme on the L71 barrel. Are you tempted by the 1/16 Jagdtiger? I've got one on order for Christmas. I will be posting a build like the KT. Once I've finished the Bismarck:-) Good job in your KT it was an inspirational build for me. phil Link to comment Share on other sites More sharing options...
vfripouille Posted December 29, 2016 Share Posted December 29, 2016 Bravo mattI am impressed by the speed and accuracy with which you mount this modelCongratulations Eric Link to comment Share on other sites More sharing options...
pzspeed Posted December 31, 2016 Share Posted December 31, 2016 Wow just wow......I love the cut away. Seriously impressive build. Link to comment Share on other sites More sharing options...
Badder Posted January 1, 2017 Share Posted January 1, 2017 Congratulations on creating a fabulous piece of art! Beautiful work all round. I doubt I'll ever attempt such a kit...it being beyond my the capabilities of my wallet, so it's been a joy to see your work in progress. Thanks for sharing, happy new year, Rearguards, Badder Link to comment Share on other sites More sharing options...
