ATPER Posted April 28, 2013 Share Posted April 28, 2013 hi. I am thinking of doing a 738 to 737 conversion of the Revell's kit. has anyone tried? (pics, please ) I know DrawDecals have a paper to see the exact cuts etc, am also using this..... what do you use / how do you proceed? thanks a lot Link to comment Share on other sites More sharing options...
Vesa Jussila Posted April 28, 2013 Share Posted April 28, 2013 I can't give you instructions, but you might find this useful: http://www.boeing.com/assocproducts/aircompat/plan_manuals.html Br. Vesa Link to comment Share on other sites More sharing options...
Jennings Heilig Posted April 28, 2013 Share Posted April 28, 2013 (edited) Note that it's not just a simple case of removing "X" windows - the window spacing is different on the 800 vs the 700. Use the measurements and fill the windows (which are too low on the fuselage anyway). Edited April 28, 2013 by Jennings Heilig Link to comment Share on other sites More sharing options...
XV571 Posted April 28, 2013 Share Posted April 28, 2013 As well as Jenning's drawings, you may also find Jessica's tutorial useful: http://www.britmodeller.com/forums/index.php?/topic/234925943-s-t-r-e-t-c-h-i-n-g-and-shrnkg-a-737-step-by-step/ In addition, check out the pinned thread by Viking on correcting the basic 737-800 at the top of this forum to help with some of the other issues like the engine nacelles. Link to comment Share on other sites More sharing options...
ATPER Posted April 29, 2013 Author Share Posted April 29, 2013 hm, thanks for all your replies. but is there not the problem that the nose is toooo low? I remember seeing somewhere an 1/144 model which looked really nose-down, way more than the kit does..... /the real thing does..... (but also don't know why it should, maybe due to difference in length?) greets, ATPer Link to comment Share on other sites More sharing options...
Viking Posted April 29, 2013 Share Posted April 29, 2013 I've done a 600, 700, 800, and 900 HERESince looking at the photo of the 700 I have removed and shortened/refixed the main legs just a little, as you say I also thought it sat a litlte nose down/tail high. It sits a lot more level now. Funny how photos make you look again!I'm also working my way through the classic 737, with a 200 and 500 and a 400 Just a 100 (Lufthansa) and 300 (Jet2) still to do.CheersJohn Link to comment Share on other sites More sharing options...
garryrussell Posted April 30, 2013 Share Posted April 30, 2013 If you're filling windows and cutting out the sections on a parallel piece as you are here on the front at least, it can be useful to make the cut in a slightly different place on each half. That way the staggered join will make the fuse stronger. Link to comment Share on other sites More sharing options...
Jessica Posted April 30, 2013 Share Posted April 30, 2013 but is there not the problem that the nose is toooo low? I remember seeing somewhere an 1/144 model which looked reallynose-down The problem is that the main landing gear seem to have been moulded in the extended unweighted position as if the aircraft was in flight. Shorten the legs a bit and the sit will be much better. Link to comment Share on other sites More sharing options...
Jennings Heilig Posted April 30, 2013 Share Posted April 30, 2013 but is there not the problem that the nose is toooo low? I remember seeing somewhere an 1/144 model which looked reallynose-down, way more than the kit does..... /the real thing does..... (but also don't know why it should, maybe due to difference in length?) No, the shape of the nose is as close to perfect as you or I are likely to see. The cabin windows sit about (from ancient memory) 5 scale inches too low on the side of the fuselage. I've compared the kit to loads of Boeing technical documents with every kind of measurement. The nose is just fine. If you saw a model with a droopy nose, it's because the modeler didn't get all the pieces flying in the same direction. Link to comment Share on other sites More sharing options...
RICHW Posted May 1, 2013 Share Posted May 1, 2013 This is how i joinedthe fuselage back together when i did my 737-600 i didi it with some bit of wood you need a 29mm hole cutter , helps to locate the fueslage backgether I used the same idea when doing the 737-900 but left the correct gaps and filled them also i modified the engines to make them more rounder on the intake by cutting away the bottom and adding a piece of plastic tomake it more round and filing it both modfied engines mounted on the wing Hope this helps Link to comment Share on other sites More sharing options...
Atom.uk Posted May 6, 2013 Share Posted May 6, 2013 (edited) This is my attempt ata -700. It will (one day!!!) be G-EZGF of Easyjet, which I flew on in 2000 and 2008. (Idon't think it had been washed in between, but that is another story!).I made a bit of a mess with the cutting, hence the plastic card insert at the back. I will watch your project with interest. Edited May 6, 2013 by Atom.uk Link to comment Share on other sites More sharing options...
evinX Posted May 9, 2013 Share Posted May 9, 2013 Heres my attempt at a 737-700 using the draw decals tutorial Link to comment Share on other sites More sharing options...
garryrussell Posted May 9, 2013 Share Posted May 9, 2013 G-EZGF is an Airbus A.319-111 delivered in March 2011 Link to comment Share on other sites More sharing options...
George D. Posted May 9, 2013 Share Posted May 9, 2013 G-EZGF is an Airbus A.319-111 delivered in March 2011 Probably the 737 was sold outside UK and re-registered to a new country so the registration was free again to be used to another aircraft. It happens. Link to comment Share on other sites More sharing options...
garryrussell Posted May 9, 2013 Share Posted May 9, 2013 (edited) Nope, sorry, they can't re use the registration easyJet only had 3 srs.700 in 2000...first one in October. Must be confused with another machine?? In 2000 it was mostly Srs. 300 This is all the aircraft easyJet have operated Select Whole Fleet http://www.planespotters.net/Airline/Easyjet Edited May 9, 2013 by garryrussell Link to comment Share on other sites More sharing options...
XV571 Posted May 9, 2013 Share Posted May 9, 2013 I suspect Atom.uk may mean G-EZJF, this is a 737-700 although it wasn't delivered until 2001: http://www.airliners.net/photo/EasyJet-Airline/Boeing-737-73V/1765901/L/&sid=127c00a135ab7502e4d3177afd4c6256 It was sold on to Aerolineas Argentina in 2009. The aircraft delivered in 2000 were G-EZJA, 'JB and 'JC (which all went on to ARG with 'JF). George, As Garry says, in the UK you can only use a 'G-xxxx' registration once. If the aircraft is exported the identity is frozen. If it returns to the UK the aircraft can revert to its original registration or it can take a new one but no other aircraft can use that registration. The only exception is where a historic aircraft is represented by a replica, but even in this case the replica has its own separate registration with a special agreement from the CAA to display the 'historic' one. HTH Jonathan Link to comment Share on other sites More sharing options...
garryrussell Posted May 9, 2013 Share Posted May 9, 2013 Even in the case of historic it's unused form the old block or those not taken up For example the second Bristol Freighter for Instone took the historic marks of G-AMLK as the aircraft had been exported to NZ as a rare example of a Bristol 170 never having had a UK registration issued to it. That had been issued but the frame in question was converted on the line to the Superfreighter prototype and re registered G-AMWA. This allowed the re use of G-AMLK as the original had never flown as such and not taken it up. Even so that particular cases some confusion amongst historians. It use to be that an aircraft having had a British registration could not, unless special permission was given, have another mark issued and of course the reg not being normally reusable. When the rules regarding strict sequence allocations were pushed and out of sequence special marks were issued some existing aircraft did get new marks and some were re used, like for example G-BJCB on HS.125s for JC Bamford Excavators.. They reviewed the whole system and decided to continue with out of sequence for an additional fee and also officially allow existing aircraft to take any number of UK marks. However they stamped on the practice of re issuing marks and that has remained so ever since. , Link to comment Share on other sites More sharing options...
George D. Posted May 10, 2013 Share Posted May 10, 2013 Then that must be UK policy. As far as I know, in some countries when an aircraft is retired the registration can and may be used on another aircraft. I know that some aircraft of LH did get registration from older aircraft of the same company. Also some other that I can't remember now... I think RO or MA. Link to comment Share on other sites More sharing options...
garryrussell Posted May 10, 2013 Share Posted May 10, 2013 Countries have different rules Some like the USA are totally random with re issues, others like Germany are random with re issues within blocks due to weight of aircraft. Other like Spain are strictly alphabetical and won't re issue. You have to examine the rules of the country in question. Even though the Isle of Man is actually a sub register of the UK they do allow re issues, and the use of the letter 'Q' Link to comment Share on other sites More sharing options...
Atom.uk Posted May 26, 2013 Share Posted May 26, 2013 I suspect Atom.uk may mean G-EZJF, this is a 737-700 although it wasn't delivered until 2001: http://www.airliners.net/photo/EasyJet-Airline/Boeing-737-73V/1765901/L/&sid=127c00a135ab7502e4d3177afd4c6256 It was sold on to Aerolineas Argentina in 2009. The aircraft delivered in 2000 were G-EZJA, 'JB and 'JC (which all went on to ARG with 'JF). George, As Garry says, in the UK you can only use a 'G-xxxx' registration once. If the aircraft is exported the identity is frozen. If it returns to the UK the aircraft can revert to its original registration or it can take a new one but no other aircraft can use that registration. The only exception is where a historic aircraft is represented by a replica, but even in this case the replica has its own separate registration with a special agreement from the CAA to display the 'historic' one. HTH Jonathan It is G-EZJF - sorry to cause all this debate! Link to comment Share on other sites More sharing options...
Atom.uk Posted May 26, 2013 Share Posted May 26, 2013 It is G-EZJF - sorry to cause all this debate! and it was 2001 - I recall the cabin crew being pleased because it was a new aircraft. Whoops! Link to comment Share on other sites More sharing options...
