Shar2 Posted April 28, 2013 Share Posted April 28, 2013 Nakajima A6M2-N Type 2 Fighter SeaplaneHasegawa 1:48 Japan was the only nation to produce and deliver into service float-equipped single-seat interceptor fighter seaplanes (the British Spitfire float adaptation did not progress beyond the experimental stage). When in 1940 the Japanese navy initiated the design of a new interceptor seaplane (the Kawanishi N1K1 Kyofu, or 'Rex'), the need was also expressed for a stopgap aircraft and the Nakajima Company was instructed in February 1941 to develop a float-equipped version of the excellent Mitsubishi A6M2 Zero naval interceptor. As evidence of Japan's long-standing plans for territorial expansion through the Pacific, it had been recognized that in the inevitable 'island-hopping' war there would be few ready-made air bases from which to provide air cover during the occupation of the smaller islands, and that the construction of runways would be impractical. Although equipped with almost a dozen aircraft-carriers, the Japanese would be unable to use them in support of every single island invasion. After removing the wheel landing gear and fairing over the wheel wells of a standard A6M2, Nakajima mounted a large float under the fuselage by means of a forward-raked central pylon and a pair of V-struts below the cockpit; two cantilever stabilizing floats were also mounted under the wings. The standard Zero gun armament was retained, and the first prototype was flown on 7 December 1941, the day on which the Japanese navy attacked Pearl Harbour. Entering production as the Nakajima A6M2-N and codenamed 'Rufe' by the Allies, the new fighter still displayed a creditable performance, being first issued to the Yokohama Kokutai and deployed to Tulagi in the Solomons where the Japanese had first landed during the Battle of the Coral Sea. However, almost all the 'Rufes' were destroyed in a strike on the seaplane base by 15 Grumman F4Fs from USS Wasp on 7 August 1942. Better success attended the 'Rufes' which fought in the later Aleutian campaign, but losses soared as soon as American fighter strength could be built up. During the final year of the war, when American heavy bombers and naval aircraft opened their great attacks on the Japanese homeland, 'Rufes' of the Otsu Kokutai, based on Lake Biwa, were thrown into the battle as interceptors in defence of Central Honshu but suffered very heavy losses. Total production of 'Rufe' amounted to 327 before being halted in September 1943. The ModelThe kit, the third re-issue, comes in a very attractive box, that Hasegawa seem to be very good at, with an artists representation of the aircraft in flight. Inside, the main sprues of grey styrene are all contained in a single poly bag, which, whilst not the best way of protecting the parts there doesn’t seem to be any noticeable damage. Fortunately the clear parts are contained in a separate bag. The parts are very well moulded, with no sign of flash and only a few moulding pips. It appears that since the real thing is based on a A6M Zero, Hasegawa have used their Zero to be the basis of this model. This means that there are quite a few spare parts, such as the lower wing, engine crankcase, undercarriage, drop tank and numerous smaller items. The build naturally starts with the cockpit, which is very nicely detailed, with the floor, fuselage sides, rear bulkhead, seat, rudder pedals, and joystick. The instrument panel has raised detail, but the dials are each provided as separate decals, which, with a blob of Kleer or gloss varnish will make them look quite realistic. Onto the panel the breaches of the fuselage guns are attached along with the gun sight. The completed assembly is then sandwiched between the fuselage halves as they’re joined together. The upper forward fuselage decking is then fitted, along with the machine gun muzzles. The construction of the engine is next. This is built up with the rear exhaust ring, the two banks of cylinders and the crankcase at the front, complete with pushrods. The engine is then attached to the front fuselage and covered by the one piece cowling onto which the two exhausts are attached. At this point the two single piece horizontal tailplanes are fitted. Before fitting the wing parts together, the holes for the bomb racks, if desired, need to be opened up. The instructions also say that the trim tab recessed panel lines, and a couple of other panel lines need to be filled on the upper wings. With the two upper parts attached to the single piece lower section the separate, clear navigation lights can be attached, along with what look like horn balances. The completed wing assembly is then attached to the fuselage. The two halves of the main floats are joined together with, according to the instructions, 16g of ballast in the nose section. The two, two piece wing floats are also assembled. The floats are then attached to their respective positions on the lower wing and fuselage, the main float, along with its support struts and boarding ladder. If the bombs are to be fitted and these are constructed of the bomb racks, crutch plates and the two piece bomb halves with separate horizontal fins. Once complete these can be attached to the lower wings. To complete the aircraft, the propeller, made up of separate hub, blades and spinner, is attached and the three piece canopy is fitted along with the aerial mast, which passes through the rear Perspex. TO complete the model there is a very nice dolly for the aircraft to sit on, this is made up of the main horizontal beams, support cradles, suspension mounting, axels and main wheels. The aircraft can then be posed on the dolly. DecalsThe decal sheet is nicely printed, in good register. Along with the standard Japanese markings there are the individual instruments and identification numbers for four aircraft from the Yokosuka Flying Group. ConclusionNo matter that the kit has been released before it is still an interesting subject and will build into a very nice model. I imagine it will be subject to severe weathering for those that like that sort of thing, but that’s up to the individual modeller. Recommended. Amerang Hasegawa Review sample courtesy of UK distributors for Link to comment Share on other sites More sharing options...
