Mike Posted February 5, 2013 Share Posted February 5, 2013 US Anti-IED Devices & Antennae1:35 ET Model Due to the conditions in Afghanistan and Iraq, US vehicles have had to be retro-fitted with a group of sensors that are designed to counter IEDs that are triggered remotely either by RF frequencies, or even mobile phone signals. These are mounted on vehicles on booms held out in front, or antennas mounted on a high-point such as the roof or top of the turret.This set includes a full complement of the various types and should be sufficient to upgrade a complete vehicle or more if spread about. The parts arrive in ET Model's usual thick gauge polythene bag, and inside are two frets of Photo-Etch (PE) brass, plus a bag containing three more bags with 12 resin parts spread between them, a length of copper chain and two tiny springs. Construction of the antennae is relatively involved, and uses both brass and resin parts to complete most assemblies. A large panel antenna with a short mounting bracket is built up first, and here you will need a little 0.5mm rod to mount a small cylindrical sensor on top. You will also need some thin wire, of approximately 0.3mm diameter, more of which will be needed later.The "flag" style antenna that is often seen on booms at the front of a HUMVEE is next, and this is constructed almost entirely of PE parts, needing some careful and accurate folding of the parts, especially the beam that anchors it to the front of the vehicle. All of the bend lines are pre-etched to make the task easier, but care will be the order of the day. Two vertical pole antennae are supplied as resin parts with PE mounts, and here you will need one of the springs to simulate the flexible mounting base, and you should back that up with a piece of brass rod up the centre, drilled into the base of the resin. This is shown in the instructions, with a hand symbol next to it, which translates to "make it yourself", which made me chuckle. There is a spare pole included, which I guess is just in case you manage to snap one? Another long antenna is made up mostly from an 8cm length of rod that you must supply yourself, top and tailed with resin parts, mounted on a spring, and then on a small PE bracket. The third antenna is a thicker type, with a separate resin base and cylindrical resin top. This also has a PE base, which is the same part as used on the two others.The last antenna is reminiscent of an old TV aerial, having a central rod of 0.3mm (which you must source yourself) that has six dipoles along its length, the rear two at 45o to the forward four. It is backed by an umbrella shaped rear, and sits on a small tripod. This section will also require some lengths of 1mm diameter rod, so make sure you have some available. A "black box" control unit is also built up from PE, and linked to the antenna by some more wire that you must source yourself.ConclusionA very nicely done set, but there are lots of bits that you need to supply yourself, so be prepared. You could argue that these should have been supplied, but that would have only increased the price, and as these items are readily available elsewhere, it's little hardship, particularly if you're like me and have scratch building "stuff" on hand at all times.The small piece of copper chain isn't mentioned at all in the instructions, so either look upon it as a bonus for another project, or check your references to see if it is sometimes used in anti-IED setups.Highly recommended. Available soon from White Ensign Models in the UKReview Sample courtesy of 1 Link to comment Share on other sites More sharing options...
JaseGill Posted February 5, 2013 Share Posted February 5, 2013 Looks like a good set. Thanks for the review. Nice to see they have a UK Importer too. Brilliant. J. Link to comment Share on other sites More sharing options...
