Julien Posted February 3, 2013 Share Posted February 3, 2013 Iwata Eclispe HP-BS AirbrushFrom Air-craft.net Iwata describe the Eclipse series of airbrushes as Multi-purpose, high-paint flow, high detail professional airbrushes. For use in applying moderate to large amounts of paint to a variety of surfaces,and to various sized areas. The HP-BS is a gravity fed airbrush featuring a 0.35mm needle / nozzle combination with a 1/16oz sized cup. The improved funnel design of this cup makes for a more efficient paint flow, and easier cleaning. This reviewer is fairly new to airbrushing in proportion to the length of time I have been building models, and I have been a brush painter for the majority of my modelling career, considering airbrushing one of the dark arts! I have David Pennington ex of SBX models for getting me into airbrushing as he said it would improve my models, he was not wrong and this is my public thank you to David for this. I normally use the HP-CS with its large 1/3oz sized cup, so wondered why you would want the HP-BS, as it looked like the same airbrush with a smaller cup. In fact as well as a smaller cup the HP-BS is about 10mm shorter than the HP-CS. Now these differences do not seem a lot, however it makes the HP-BS seem a lot more light and nimble in your hands, great for painting smaller and more intricate details. I also like the smaller cup as it means I mix (and waste) less paint when doing smaller jobs. The airbrush arrives in a sturdy card box in a foam bed to protect it during transit. The build quality of looks very good indeed with them being made in Japan, that's pretty much guaranteed. The HP-BS is a standard 0.3mm nozzle and needle, with many of the parts looking like they are common across the range, which will help keep the cost of replacement of consumables down should you happen to need any. Conclusion I really do like this airbrush. I would recommend it for a second brush which is how I am using it, as is very good for painting smaller areas, and doing work which requires a bit more dexterity than its larger cousin. It should be noted there is no lid for the smaller cup, but then I don't use the lid on the larger brush, so its not an issue for me. You might want to get one if you're prone to spilling paint on your models. Review sample courtesy of 1 Link to comment Share on other sites More sharing options...
Julien Posted February 3, 2013 Author Share Posted February 3, 2013 Plus if you really want either the Eclipse HP-Bs or the Bigger HP-CS they are both currently on offer with Aircraft.net http://www.air-craft.net/acatalog/Iwata-Eclipse.html Bonus! Julien Link to comment Share on other sites More sharing options...
PoppaMoomin Posted February 6, 2013 Share Posted February 6, 2013 I bought one of these, did you get a lid for the cup with yours? Link to comment Share on other sites More sharing options...
Julien Posted February 6, 2013 Author Share Posted February 6, 2013 No the BS does not come with a lid like the CS does. Julien Link to comment Share on other sites More sharing options...
Julien Posted May 3, 2013 Author Share Posted May 3, 2013 A samll update on this airbrush. I have been using it on and off and find myself reaching for it if I know it can hold the paint for a job as its easier to move in my hand. I also find it saves me paint, as even for small jobs I was putting too much paint in my other airbrush. Julien Link to comment Share on other sites More sharing options...
